changing out maxima steering wheel?
Old 04-16-2008, 07:56 PM
mark_mck15's Avatar
i have a blow air bag steering wheel and just got my after market one in 2day...and advice on were i should start by taking off the old steering wheel?...or any whole instructions..thx
mark_mck15 is offline
Old 04-17-2008, 04:40 AM
No more Maximas...
pmohr's Avatar
Checked the FSM or a Haynes yet?
pmohr is offline
Old 04-17-2008, 11:31 AM
^^ It's all spelled out very clearly in those manuals..
It's pretty intuitive anyway. Just dive in and chances are you'll figure it out. Only specialty tools you'll need are a tamper proof T50 torx bit, and a steering wheel puller (free rental from Autozone etc)
The Wizard is offline
Old 04-17-2008, 07:03 PM
Snypa's Avatar
Hyanes Manual: http://cgi.ebay.com/ebaymotors/1993-...spagenameZWDVW
Snypa is offline
Old 04-17-2008, 07:10 PM
Offset Is Everything.
MrDicks95SE's Avatar
i didnt even need a steeringwheel puller. i just used a socket from my ratchet set. worked great.
from what i remember:
disconnect battery. pop off the covers on each side of the wheel. use T50 bit to take out the tamper-proof nuts (one on each side). slide airbag back out, disconnect harness. **you will lose your horn** unscrew 4 screws somewhere (i forget where but related to airbag)and then you should be able to get to the center nut holding the wheel in. leave the signal canceller in there as you would probably want that.
MrDicks95SE is offline
Old 04-18-2008, 09:55 AM
Ummmm..... How does a socket "pull" like a steering wheel puller does???
Old 04-18-2008, 10:50 AM
or rather my wheel was loose enough to "pull out" with my own strength.
Old 04-18-2008, 07:36 PM
mark_mck15's Avatar
ok thx peps
Old 04-19-2008, 03:29 PM
xenomax's Avatar
i also never use a puller. you can usually give it a good pull and the wheel will come off.
xenomax is offline
Old 04-20-2008, 09:24 AM
97' SE 5spd.
dblock1's Avatar
give it a good pull. Also a wack on the bottom with a rubber mallet also works good!!!
dblock1 is offline
Old 04-20-2008, 11:08 AM
aznsap's Avatar
just curious, why do people normally want to change their steering wheel?
aznsap is offline
Old 05-19-2008, 09:42 AM
Scott LaRock's Avatar
Crap, I got the steering wheel puller but I didn't get the torx wrench.
Scott LaRock is offline
Old 05-19-2008, 10:59 AM
black_maxed95's Avatar
blown airbag as said in first post?
or to do it for looks/styling and feel.
personally i wouldnt mind getting rid of my big ugly 96 wheel but good wheels are generally expensive.
black_maxed95 is offline
Old 05-19-2008, 01:21 PM
Can I have some help here? the T50 doesn't fix... can someone tell me what the do? the Nut seems to have a piece in the middle and the T50 isn't gonna fit over it.
Old 05-19-2008, 08:18 PM
Black Lion
maxprivate's Avatar
Its a torx security bit. thats why there's a hole in the middle of the bolt I believe. get one from nissan.
maxprivate is offline
Old 05-19-2008, 09:28 PM
make sure its the security torx. it should have a hole in the center. go back and get one.
Old 05-19-2008, 10:01 PM
bigshaunsmax's Avatar
just curious but if you change your steering wheel and eliminate the air bag arent you going to have trouble gettin a safety inspection sticker
bigshaunsmax is offline
Old 05-20-2008, 09:22 AM
I did say "tamper proof" for a reason in post #3.
Old 07-31-2008, 08:31 PM
REAL1's Avatar
ANYONE GOT PICS OF TOOLS OR ACTUAL HOW TO?
REAL1 is offline
Old 07-31-2008, 09:01 PM
Pics of tools aren't really needed. We've already spelled out which tools to get. Go to Sears, Autozone etc and ask for them by name.
The Cliffnotes of how to do this task is posted above. If you need more, I recommend you purchase a Haynes manual from Autozone, a used one from Amazon.com/ebay, or download the Factory Service Manual (FSM) for free and read the section that applies. All in all, it's pretty straight forward. Just get the tools, and dive into it. Chances are, you'll figure it out on your own.
trasmadean
02-01-2017 08:20 PM
Flores94
08-13-2015 01:17 PM
Flores94
08-11-2015 12:53 PM
MikesChevelle
08-06-2015 11:36 AM
RealityCheck
08-05-2015 06:18 AM
Quick Reply: changing out maxima steering wheel?
