04-09-2008, 05:45 PM
Maxima.org, my g/f's nightmare
Where can I get an AC Clutch disk????
Can't seem to find just the clutch disk, everyplace wants to sell the whole compressor. I gave up on trying to find a clutch disk removal tool .... seems nobody has them. (I'm sure the stealersh!t has them, but F them!)
Any and all help is much appreciated. This is driving me nutzo.
__________________
CAI, Test Pipe Cat, JDM N1 Cat back, FSTB, Aluminium dash kit, STS, Razo shift knob, Clear markers, CC mod, .ORG Stickers (bright blue), Blue LED switches / map lights, A6 Bi-Xenon retrofit, rebuilt 5spd - My write up --> http://forums.maxima.org/showthread....121&highlight=
Need a wiring harness for your Xenon / Bi-xenon retro? PM ME
04-09-2008, 06:29 PM
Can't understand your post.
Are you looking for the A/C clutch or the removal tool?
04-09-2008, 06:46 PM
obviously the clutch disk.. since the old one isnt coming off nice he wants to rip it apart and replace it with a new one...
__________________
04-09-2008, 08:45 PM
 YEP! That is what I need to do. I don't think the tool would help at this point due to the noise it will likely make after replacing it anyway. So, I figured I would get a new A/C Clutch and not have to worry about it one way or the other. If I use the tool and then replace the OEM disk and it makes noise ... well, you see where I am going.
__________________
04-10-2008, 03:04 PM
04-10-2008, 03:42 PM
thats not gonna help at all you need to pull off the old one with a special puller
__________________
04-10-2008, 04:36 PM
The a/c clutch holder tool ... is sorrta like what I need, but it's not a puller. Thanks anyway tho mate. The tool I need will actually hook under the disk and as you tighten a center bolt, it pulls the disk off. I even tried making a couple, but to no avail. So ... I still need the damn A/C Clutch Disk .... I want rid of the noise from that pulley bearing.
__________________
04-10-2008, 05:13 PM
just buy a compressor and throw it in.
04-10-2008, 09:47 PM
yea buy a 500 dollar compressor and pay another 100 bucks to get they system drained and refilled.. thats a great idea....
__________________
04-10-2008, 10:22 PM
.... no thanks, think I'll just go ahead as planned then.
__________________
04-11-2008, 05:39 AM
The Dirty Pearl
Quote:
$500 for a compressor? Can get them for $27 from my local junkyard...cheap enough that if it's a bad one, it was still worth trying.
04-11-2008, 06:17 AM
Isn't buying one used an issue though? If not, I'm kicking myself right now. I bought a remanufactured one yesterday for $175 + shiping, which is thought was a great price considering all the other reman ones I've found were between $300-450.
__________________
1995 Maxima GXE-L Automatic
Deep Blue Pearl (BM1)
MotoStorm Underdrive. Front Clear Signals. Chrome Guage Rings. Custom Leather e-Brake Boot. Various Splash Black Interior Swaps.
04-11-2008, 06:37 AM
That is a point Pmohr .... but still gotta recharge the system if I do that. Plus, if the bearing is bad on the junk yard one too, then I have to R+R it again ... Not a bad idea, but if I can find the clutch disk, I am thinking it would be a better way to go.
__________________
04-11-2008, 06:42 AM
Quote:
That link that he gave, I saw a puller right beside the holder tool.
http://www.autozone.com/in_our_store...ley_puller.htm
__________________
04-11-2008, 07:04 AM
Quote:
yea good thinking ur gonna get another one with a bad/noisy bearing....
__________________
04-11-2008, 07:05 AM
Quote:
Originally Posted by coachholland
i used that.. its TOO big and doesnt grab the clutch its self..
__________________
04-11-2008, 07:23 AM
The Dirty Pearl
Did you actually read what I wrote? If you do, then it was a waste of a mere $27. No big deal.
04-11-2008, 11:31 AM
^^^^^^^ yea plus 100 bucks to fill the system... read what i wrote on top...
__________________
04-11-2008, 03:18 PM
The Dirty Pearl
You can run the compressor long enough to determine whether or not it currently has a bad bearing without having to charge up the system.
04-11-2008, 04:54 PM
you have to remove the old one cuz there isnt enough room to mount a new one.... like i said iv already done the job and i know whats involved....
__________________
04-11-2008, 06:03 PM
The Dirty Pearl
Indeed, you'd have to R&R the compressor. If it didn't work, you'd be out <$50 and an hour of your time, basically.
04-12-2008, 02:19 PM
A/C Clutch Pulley Puller but thanks again ...
__________________
04-15-2008, 08:44 AM
So ... come on .ORG I need an A/C Clutch Disk ... help me out, where can I get one?
__________________
04-15-2008, 11:23 AM
dealer 300 bucks... like i said try going to the junk yard and seeing if you can remove any...
__________________
04-15-2008, 03:52 PM
That lays into the same issue tho .... how to get the old one off without F'n it up to the point I have to spend $300. The old one is still on and making noise, I really don't like it, but I'll live with it for now. Of course, if anyone has any ideas of how to remove the OEM disk and not F it up, I'm open to options here. Sabash, didn't you do your AC Disk? How??? Where did you get the replacement?
__________________
04-15-2008, 04:42 PM
man i tapped some holes and put 3 bolts through it and made a puller to remove it... i kinda lucky but i bent the damn think a little.. now i can remove it w/out messing with it... i had to bend it back to normal but it wasnt easy..
__________________
04-15-2008, 05:44 PM
