Anyone with a HHO intake kit?
#201
Oh by the way...
Ever wonder why dubai is now being converted as a tourist spot?... the wells are running out.
Here's a second start Google: "When will oil run out?"
#202
I've wondered this myself, however, I have the EFIE's now so it's a moot point for me.
EFIEs adjust the voltage that reaches the ecu. So an EFIE acts like a an old carb adjustment. You can control, to a degree, how much fuel the ecu is sending to the engine. Therefore, when the engine burns hydrogen and the resulting exhaust becomes saturated with oxygen. The driver can adjust the EFIE to tell the ecu that everything's ok instead of the ecu thinking the car is running lean and dumping more gas into the engine.
#203
Why don't we start drilling in freeking alaska? I've heard that Alaska alone has enough oil to supply the US for MANY years to come. I'll have to find where I heard that...
#204
Oh Yeah, there's enough in alaska, but this are all political.
US is waiting for the oils to run out in the middle east, so they will have control of oil again afterwards.
US already learned its lesson from the past. The oil wells did ran out in TX that they thought is an infinite supply. Same pattern is showing up now in the middle east.
#206
Sorry, what I said was sort of confusing..
You're right, I'm NOT using an HHO kit.
I'm saying that I save the same amount of gas as people that do have an HHO kit. Perhaps HHO kits have the potential to save more gas than I can without one, but I haven't seen that proven yet.
Basically I'm just saying that I don't think I am "nursing oil companies" by not having an HHO kit when I save just as much gas as most people messing with HHO kits.
#207
I know how the EFIE adds a bit of voltage to the signal to fool the ECU into thinking everything is running good. But I'm saying how would I know what much to add using the EFIE. Most of them have an adjustment ****. I don't want to run the car too lean and damage something.
Also, to everybody here, please, please, please, don't turn this into an opinion thread. I know it's easy. I just don't want this thread to turn into a flame-fest and then have it locked. There is useful information here for those of us trying this out and there is also a healthy amount of negative commentary regarding this topic from others, which is perfectly fine. I have no problem listening to other's comments on how stupid or ridiculous it may be because several of those comments have actually gotten me to change my design for, what I feel, is the better. So to everyone who has posted, either in favor or against this topic, thank you, and all I'm asking is to keep it factual and on-topic.
#208
#209
hey guys, ive been checking out this thread every once in a while and i am also sorta on the doubtful side of this being an effective solution for cars. however I have taken plenty of physics and chemistry courses as a nuclear engineering major and i do understand how these work. I also want to do this because I love to tinker with nerdy stuff.
Ive decided that over this summer I will put some thought into this and hopefully in a few months have this on my car and see how it affects it. I am also very performance oriented with my car (see my sig) so eventually I will be seeing how it affects it that way also. I will also test it out with my NGK AFX wideband and a safc neo.
I have started the build for my HHO cell, basically the only major thing I have left that I need is some good electrodes. I just made it out of PVC adapters and various fittings. It is copmletly sealed with PVC glue and silicone caulk. Last night I painted it black and clear coated it for my viewing pleasure. In a few weeks when i have money I am going to buy some of the 316L tubes off of ebay.
Anyways, this is what I have so far:
The black wires I have connected to it now are for an old cell phone charger to test it out. I tested it out with cut up pop cans for the electrodes in tap water with salt and it all works. Obviously that is a very crude setup but was just to test it. I will eventually use distilled water, NaOH, and like mentioned, some 316L SS electrodes when I am ready to get this thing in full swing.
#210
#212
Nice!!!...
Show us the HHO Gas Production numbers...
1.) Liter of HHO / Min
2.) AMPS and Volts
3.) Mileage improvements
4.) And other observations.
and more!
2.) AMPS and Volts
and more!
#213
i highly doubt it will be a substitute for your main cat. you are still going to produce the NOx from the gasoline.
#214
Tha'ts kinda confusing...
"you save as much gas as most people messing with HHO kits."
Are you saying that your engine is the baseline for HHO savings? eventhough you dont even have an HHO installed?... Not sure if you can call that a fact either.
Wow, you probably have a magic JoeCell in your car.
I wish I have a car like that.
#215
It is going to be a while (atleast a month or two) before I have this on my car (atleast on a regular basis). For now it is just a bedroom experiment until I have it built efficient enough and durable enough for my car. I still need to make a system to make sure no water would get sucked into the engine. I also need to make a bubbler canister yet.
#216
All I'm saying is this: I'm noticed about a 3mpg increase by driving slower and removing 70lbs from the car. The amount of gas I save by doing that seems to be just as good as the amount of gas other people save by using an HHO kit. Perhaps I haven't seen the full potential of an HHO kit though.
#217
Also, I suppose that after I or another member has finished testing it on their vehicle, we could give you the initial base settings and you could tinker it at your own will.
#218
what is a decent metal type to use for the electrodes that is still cheap and easy to get a hold of. tonight i am finishing making my bubbler and right now it is being painted to match my main cell. tomorrow i want to start producing hydrogen. ive done a basic test run previously with pop cans cut up but what do you guys use that is better. Im eventually going to get some 316L SS tubes off ebay but im looking for something cheaper until i do that. I was thinking using some solid copper wire twisted into a spiral. Would that be decent or are there easier/cheaper/better solutions.
#219
#220
Anything stainless to start off with, you can get stainless steel lightswitch blank wall plates from Lowes or Home depot. Construction hangers also work for the plate design.
#221
Ok, what is a 316L tube and what is the purpose of it? I tried looking them up on a search, and couldnt figure it out...
I did purchase a scan guage today to hook up to my vehicle... I'm going to try this project on a 1999 Chevy Tahoe, think its a waste? I dont want to try it on the Corolla as of yet, cause it was the wife mothers car (whos deceased now) and screw up that car.
#223
So I have finished the construction of my booster. I just have to take the plates off and clean them up. Some of my plates spacing looks odd because the washers I bought are not all the same size. It's not as pretty as Smack's but I am just hoping that it performs the same. Is there anything that you would change on it?
By compartmentalizing, do you mean to keep the same amount of arrays just put them where there is a compartment between two of them?
#224
Powerman, I suggest to insulate the bottom strap too...
Why? This is like putting the two active electrodes very closely, and making your cell inneficient, floaters wont produce gas or little gas because they are now almost getting bypassed, because there's now a shorter current path from neg to positive. Remember, the center plates is -, and the strap at the bottom is +
You want to put the active electrodes as far as possible from each other, behind the floaters. Just seal off the straps.
BTW, is the bottom strap touching the center plates? (looks like it to me?)
i'm seeing sparks!... that's a short!...
For a true series cell, I just dont want to confuse you further, I know it's confusing at first. But, you can look at Patrick Kelly's documentation about Practical Guide to Free Energy Devices, (Chapter 10) , from page 10-30 (chap10,pg30). You'll see how a true series cell should be.
http://www.free-energy-info.co.uk/Chapter10.pdf
Patrick spends a lot of time writing all this free energy stuff, he's actually the one who wrote all the docs for smack booster, boyce electrolyzer, hotsabi, and others...
Thanks to Patrick!
Just go to the main page to get all the info:
Hope this helps.
Thanks to Patrick!
Hope this helps.
#225
It does help. I will insulate the straps once I get everything cleaned up. The bottom strap is about 2mm from touching the plates I will have to coat it. I am not 100% finished; just the hard part. I will have to make the spacing even on every plate, I just have to look at the washers and use the same size. In the packs I bought some are skinny and some are thick.
#226
wow guys:
I got my cell working so i was testing it out. Im using tap water with NaOH (100% Lye) and am using some SS light switch plates for basic electrodes. The HHO is bubbled through water mixed with isopropyl alcohol (to make it extra flammable ). I was testing it out and I held a lighter up to the tube and i made it give off a huge backflash, it actually freaked me out.
So what do i do next, I do it again, but this time I record it on video. The one i got on video is extremely small compared to the huge one that scared me.
(waiting for youtube to upload it right now)
#228
youtube has to process the video, im not sure how long this takes, ive never used youtube to upload before. but ill have it up the instant its ready.
EDIT: uploaded, let me know what you think:
http://www.youtube.com/watch?v=VaN6KjDVb-s
I love how you can see the flame travel the length of the clear tube
#229
heres another video, only 10 seconds this time. Its a bigger backflash. It doesnt sound as loud as it was in real life in the video but look at the glass of water on the table when it explodes, you can see how the explosion shook the whole table.
http://www.youtube.com/watch?v=wVmDfD09WwU
...heres a screen shot.
so tomorrow, im going to make a better electrode similar to what powerman has. Right now its very similar but just uses 3 plates. In the future I also want to make an arrestor to stop the backflashes from happening and I also need to make a catch can for the water incase any would get in the final tube so I dont get water in my engine when this is finally in my car.
Is anyone else making any notable progress?
#230
Nice!!!.. Here's my video for water torch... i'll upload some more in a bit.
http://www.youtube.com/watch?v=eo66T...x=0&playnext=1
#231
Nice!!!.. Here's my video for water torch... i'll upload some in a bit.
HTML Code:
<object width="530" height="370"><param name="movie" value="http://www.youtube.com/p/8F2C7496F529B7FB"></param><embed src="http://www.youtube.com/p/8F2C7496F529B7FB" type="application/x-shockwave-flash" width="530" height="370"></embed></object>
are you planning on eventually making a system for your car?
btw heres a link that is easier to use for your video:
#232
Thank you... I thought you can embed youtube video here... but it didn't work.
Link edited, it actually composed of 2 series video...
Im building another one for my altima actually as we speak, almost done.
Just see my first post on this thread about my the gain I got from my other car.
cool, I like the torch idea with using the nozzle to inflate *****.
http://www.youtube.com/p/8F2 C7496F529B7F B
#233
use a grainger valve as the torch so you can turn it off/on... I saw another site/video that use water as fuel with more power output than that! I believe the guy was using a laser to ignite water or using ultrasonic waves... I'll find it again!
#234
If you are refrering to SirHoax on youtube,he is using plasma to generate HHO on one of his vids.
There's already an on/off switch, plus I dont need another torch contraptions, the purpose of this cell is not really for a torch, it's going into my other car. Since I already made a little flashback arrestor out of plastic tubing and stainless wool (the black tube next to the needle), why not make a torch just for curiosity, and using the stuff that I have lying around.
The cell in that video is not yet done, as you can see, its just a 1/4 of the a temporary container ($4 from walmart), it will be a series cell... the cell is actually going into an acrylic container that i'm building right now.
#235
Sorry that was just funny as hell to see... LOL Reason being, is I was thinking it was going to boom just before it did... I cannot wait until I can get started on mine... I think I said it, I have the scan guage on order and should be on its happy little way...
#236
Interesting thread but a few concerns:
- Alternator drag increases as current draw increases. You are not using "free" unused energy from your alternator, a 10Amp draw will make your engine work harder to spin the alternator
- I'm not comfortable with letting engine vacuum simply pull in as much HHO as is generated by the electrodes. Without a proper metering system like a "fuel injector" for your HHO, there's no safe method of ensuring AFR's don't get out of whack
- You are installing devices to trick your O2's into reading richer than they are so the ECU runs the motor leaner. Great idea for saving gas but see point above - how do you ensure that:
1. Your HHO injection is precise enough to keep AFR's safe
2. Your HHO gas quality is consistent. What if you get a bad batch of water/baking soda or your electrodes start to deteriorate. Now, you may only have HHO gas that is 50% as "potent" as the last batch and you run your engine dangerously lean
3. The ECU is smart enough to revert to gasoline only mode when your water bottle runs empty
Ideally, you'd need a feedback system tied into the ECU that can safely meter the amount of enrichment that the HHO system provides and cuts back on gasoline. Without that, I think you run a high risk of leaning out.
IMO, it's too much complexity for little gain.
#237
#238
There are lots of amps in the alternator that actually goes to waste, our HHO gen is just taking advantage of it. Taking too much current from the alternator creates more drag??? FALSE!!!.... So, if I have a wind turbine, and if take current more than it can provide, does it come to a close stop? wind turbine and alternator are the same concept. Stator and Rotor are not really physically attached to each other to cause a drag when you pull current! The energy is already there, and your engine already worked for it, its already paid for, if you dont use it, it'll just go to waste.
Now you just realize that your car is wasting energy most of the time by spinning the alternator.... The engine will spin it, even there's nothing demanding for current.
It's not really free energy per se, but it's wasted energy if not utilized.
Oh by the way, 9mpg additional is not bad, from an HHO gen that's taking 8-9Amps, generating 1.3LPM of hho... on a Corolla 2000.
Can you call that little gain? maybe if the petrol prices are still in the $0.99/gallon
#240
The stronger the magnetic field, the more current is generated and the harder it is to turn the alternator. The voltage regulator determines how strong the magnetic field is in the alt. In general, it's ~1HP for every 20A so it's not that huge a draw but it is a draw nonetheless.
My concern is that the HHO kits around don't have enough safeguards in place for me to put this in my car. I have dealt with complex kits before - I put a water injection kit on a turbocharged car with a standalone ECU. But I did have a low boost program with more conservative fuel curves for when my WI kit ran out of water/ethanol. I don't see that in this HHO kit.
Btw, not intending to derail what you're doing, just bringing up some concerns. Keep up the great work.
