Go Back   Maxima Forums > Maxima Discussions > 4th Generation Maxima (1995-1999)
Thread Tools Display Modes
Old 03-12-2008, 11:10 PM   #1
Your friend list is empty
Kevlo911's Avatar
How to: Create custom LED Map/Dome lights[Tons of pics]
This is my howto on how to create custom map/dome lights with premade LED boards. I found the LEDs thanks to AZDAVE on HIDplant.com. Thread here:
http://www.hidplanet.com/forums/viewtopic.php?t=38557
I was never satisfied with the color or the output of the bulbs in the 4th gen map/dome lights so I decided to do my own.
I am NOT liable for anything YOU do to YOUR car so do this at your own RISK.
Tools/Parts:
Phillips Screw Driver
Flat head screw driver
Soldering Iron
Solder
50ohm resistors(or 100ohm) - See http://www.rcaz.com/images/electroni...r_solution.jpg
Led Cluster: http://cgi.ebay.com/Fantastic-Cluste...QQcmdZViewItem
Hot glue gun
Wire strippers/Cutters
Shrink Wrap(optional)
Installation:
Remove the map light by just pulling it down. It will come out easily. Get the boards and glue one board in the middle. Take another board and remove it from its base. Glue this one in next to the first board.
Solder one ground to another.
- Yes I know it looks like **** but I don't want any comments on it
Run the wires through the holes and solder in as shown. The grey wire with the blue stripe is POSITIVE and the solid wire is the NEG.
Daytime pic - no flash
Daytime with cover on.
__________________
97 Pearl White Max GLE
191WHP and 201WTQ
Bi-Xenon retro for sale!!!
LED tails for sale for 97-99 as well:
http://forums.maxima.org/4th-generat...-interest.html
Kevlo911 is offline   Reply With Quote
Old 03-12-2008, 11:10 PM   #2
Kevlo911's Avatar
Dome light:
Now on to the dome light. Remove the cover on the dome light and then remove the 2 phillips screws holding it in place.
You can mount the leds however you want. I wanted to keep the stock parts in so I did it this way. I cut off one end of the board making sure I didn't cut any traces EXCEPT the ones that connect the (+) and (-) on each side. Be careful when doing this.
This is how I installed the boards. Connect the grounds to eachother and you want to make sure you connect the grounds to the WHITE wire and the white wire ONLY. If you don't you would be able to retain the ON and Door open function. The hot glue also keeps the connections from touching so they wont short out.
Run the wires as shown.
Install like shown. The Grey/blue wire is positive once again.
Test just to make sure I wired it properly haha.
PLENTY of output
Now go back and install it in the car...
__________________
191WHP and 201WTQ
Old 03-12-2008, 11:11 PM   #3
Kevlo911's Avatar
Output pictures:
Backseat - map light output.
From the outside of the car - map light only.
From the sunroof closed - map light only
Drivers side front - Dome light only
Next to dome light - dome output
__________________
191WHP and 201WTQ
Old 03-12-2008, 11:18 PM   #4
Kevlo911's Avatar
More output
From front of car - dome only
Back seat - map and dome on
From outside the car - map and dome on
From the front of the car - map and dome on
http://kevlo911.ic3donline.com/image...e/IMG_1926.jpg
Random shot of my 2 color gauges lol.
This cost me about 10 bucks so I considered it a success.
__________________
191WHP and 201WTQ
Old 03-12-2008, 11:19 PM   #5
Send a message via AIM to Hammy
Sweet, Check you Pm.
Hammy is offline   Reply With Quote
Old 03-12-2008, 11:24 PM   #6
Kevlo911's Avatar
more!
__________________
191WHP and 201WTQ
Old 03-13-2008, 01:05 AM   #7
looks really nice man.
__________________
*2002 SE 45K Springs
http://forums.maxima.org/5th-generat...ml#post6626906
Jan-2009
Snypa is offline   Reply With Quote
Old 03-13-2008, 09:57 AM   #8
Send a message via AIM to MOHFpro90
Nice thread kev.
Love the gator in the front seat.
__________________
FOR SALE: Ksport coilovers! $225 + s/h!
00VI | 5.5Gen BBK | Axxis Ceramic | Raxles | Ksports | 00 5 spokes | AE'd | Cleared Tails | Shortram | 9007 conversion | LED interior | SNOMAX's LCAs
MOHFpro90 is offline   Reply With Quote
Old 05-23-2008, 07:00 AM   #9
Kevlo911's Avatar
__________________
191WHP and 201WTQ
Old 05-23-2008, 08:00 AM   #10
Send a message via AIM to G4nismo
just ordered 50 3mm white 6000mcd LEDS and going to redo everything, pretty much what you did, cause setup right now is crap and is falling apart.
where did you get your breadboard by the way? radioshack perhaps?
__________________
Warpspeed y-pipe, magnaflow cat, cattman b-pipe, apexi WS2, 00VI, shortram, Suprastick V4, DR mod, hayden 404,
ksports coilovers, FTSB, RTP rotors, 2K3 rims, LED interior
G4nismo is online now   Reply With Quote
Old 05-23-2008, 08:04 AM   #11
Kevlo911's Avatar
Search "9 chip led" on Ebay and you will see the boards I bought
__________________
191WHP and 201WTQ
Old 05-23-2008, 08:08 AM   #12
Quote:
uhhhh those already have leds on them.... there actually dirt cheap though.
__________________
Old 05-23-2008, 08:13 AM   #13
Kevlo911's Avatar
Yeah, I didn't know if you knew or not.
I usually get breadboard from radioshack, but I haven't done a project that required them in a while
__________________
191WHP and 201WTQ
Old 05-23-2008, 08:26 AM   #14
2003 Nisan Maxima
Send a message via AIM to Teaner Send a message via Yahoo to Teaner
wouldnt have been easy to make the led's a plug and play so you didnt have to splice everything?
are the back of your bread boards adhesive?
good work overall, nice modification
Teaner is offline   Reply With Quote
Old 05-23-2008, 08:29 AM   #15
Kevlo911's Avatar
I don't mind soldering, it is a good solid connection. To make it PnP I would have to break a bulb and then solder the wires to the base of a bulb
__________________
191WHP and 201WTQ
Old 05-23-2008, 09:07 AM   #16
2003 Nisan Maxima
i just bought some led boards off of an org member im sure it was failry simple to make. its for a 5th gen though.
F/S: LED Interior Light Similar to Metal Max's
Old 05-23-2008, 09:15 AM   #17
Kevlo911's Avatar
Too much money and too many LEDs.
__________________
191WHP and 201WTQ
Old 05-23-2008, 12:26 PM   #18
2003 Nisan Maxima
MY POINT was to just show you how easy plug and play could be done.
you can never have to many led's
Old 05-23-2008, 01:29 PM   #19
Send a message via MSN to oallauddin
sweet, this is a cool little project
__________________
oallauddin is offline   Reply With Quote
Old 05-23-2008, 01:57 PM   #20
Send a message via AIM to kzoosho Send a message via MSN to kzoosho Send a message via Yahoo to kzoosho
Umm yes you can and this is coming from someone that has led everything.
__________________
99 GXE Auto V1 370cc injectors and Modded vb.
97 5sp SE New build Holset HX52 and spray. More to come.
91 GXE Auto bone stock beater
Led retro's Pm me
kzoosho is offline   Reply With Quote
Old 05-23-2008, 02:52 PM   #21
man his price is over the top IMO. you could simply buy your own leds and breadboard and do your own for less than $15. excluding tools.
__________________
Old 05-24-2008, 07:51 PM   #22
aznsap's Avatar
Send a message via AIM to aznsap
ya, i bought LEDs for cheap and PC Board and did this project a few years back.
kevlo you did a great job. i'll add my pics so people have more reference as well.
how i did the courtest lights (in the door). you can google up 'led calculator' to figure out what ohm resistors you need depending on how many led's are in your array.
test fitting of the pc board i cut out in the map light. i had to do some dremeling and use one of the stock screws to hold the pcb in place.
back of the pcb. keep the soldering clean and make sure the contacts are firm. i recommend using flux and running the + and - in opposite directions.
how i put everything together. make sure you have a resistor in there
the what it looks like in, all ready to go
__________________
FOR SALE (pics): 4g upper and lower IM, 4g IACV, white (qno) hood, '95 TCM, oem crank pulley and belts, auto gear select indicator and shift mechanism
aznsap is offline   Reply With Quote
Old 05-24-2008, 07:53 PM   #23
aznsap's Avatar
test fitment of the pcb in the dome light
you know what im too lazy to post the rest of my pics so if you want to check them out on my cardomain here:
http://www.cardomain.com/ride/352601/10
__________________
Old 05-24-2008, 08:05 PM   #24
Master Will
metallic97gxe's Avatar
Send a message via AIM to metallic97gxe
been thinking of the same mod myself great write up and pics
__________________
William G - Metter,Ga. November 2002 Maxima Of The Month
GOT TROPHIES? 8 Years, 96 Shows, 78 Trophies, 5 Plaques
All $6.5k In Mods Done By Me: ENZO Intake. STILLEN Y-Pipe. 2 OPTIMA Yellows. OBX Axle Back. ASPEC FSTB. PANASONIC Deck. AUDIOBAHN Fiberglass Kicks. KICKER Fronts. KENWOOD Rears. AUDIOBAHN Bass Driver. Fiberglass Enclosure. HIFONICS Zeus 5 Ch. Amp. Motorized Amp Rack. 2 JL AUDIO 10w1v2 Subs. Hinged False Floor. FATMAT. 3 7" TVs. TVIEW DVD Player. SONY PSONE. 18” Wheels (225/40ZR18). SS Lines. D/S Rotors. TEIN S-TECH. KYB AGX. STILLEN Lip. IONIC DYNAMICS Valance/Side Skirts. TRENZ Billet Grill/Valance. GALANT GTZ Spoiler. Sport Bike Mirrors/Gas Door. XENTEC 6K HIDs. Gen 2 Tails. WHELEN Strobes. LEVOC Shift Knob. JOSHUA TREE Aluminum Dash. Sport Pedals. Reverse Indiglos. EVOLUTION-AUTO DESIGN Sill Plates/Floor Mats. Black Leather.
97' Maxima-Maxed Out
99' 4Runner-Rolling Thunder
MySpace
IT’S YOUR CAR, TIME, AND MONEY MOD IT HOW YOU WANT
Go Get The New Nickelback CD Dark Horse!
metallic97gxe is offline   Reply With Quote
Old 08-06-2008, 08:57 PM   #25
Great write up! Just got my map light installed on my 5th gen. The only difference is that there isn't any blue stripe on my pos+ wire. No prob though.
rexolicious is online now   Reply With Quote
Old 10-05-2008, 06:46 PM
