Transmission dripping. With PICs
#41
on my last trans that broke, i had a bad axle seal. well it was no biggie since i would just top it off every once in a while and i thought i'll get around to it when i break the axle again but the one week i forgot to add some, i was doing some highway pulls and BAM the trans seized on me in the middle of the highway. that was fun. a 10 dollar part ended up costing me 500+.
rear main seal is the big seal behind the flywheel where the crank is.its simple to do and since you're doing the 5spd conversion you'll be in there already so might as well do it. Lue told me to come up there and lend a hand in the spring lol
Interesting thread. I too have the same type of leak. When I changed my axles during the summer I notice a wet spot of oil where the auto transmission meets the engine. Someone mentioned RMS as well as crank seal, I was under the impression they both are the same. I doubt that I have that black flywheel inspection plate since the car is auto, so how can I see if its the RMS or not?
I will be doing a 5spd swap in the spring, so I would like to know which seal I need to purchase. Any writeup on changing it? Where exactly is this? between crankshaft and flywheel?
#42
Generally when you hear 'crank seal', it's referring to the front seal, where the crank snout comes through the timing cover or block.
Likely it isn't the RMS, but the half moon seal on the oil pan.
It's slightly less than simple to do while the trans is off, as you have to support the engine while dropping the upper oil pan to replace the seal (properly). Replace it without dropping the upper pan and you're asking for a bigger leak.
#44
You still have the inspection cover, otherwise you'd never be able to get to the flexplate-torque converter bolts.
#45
No, the RMS goes around the crank directly behind the flywheel, as in any other engine. The half moon seal that seals the RMS retainer to the upper oil pan is what leaks, and that's possible to replace without dropping the trans.
#46
So should I be changing both of them since i will have everything apart while doing the swap?
#47
That's up to you. The RMS rarely leaks, and the oil pan seal usually just barely weeps, so it's up to you whether or not you think it's worth the few hours of work to replace the seals.
#49
12296M is the RMS. It shouldn't be leaking as you said.
11121+A is the half moon seal and most likely my leak source. Will I need to buy the nissan gasket sealant to install it? Will the old one give me a problem to remove cleanly?
#50
You can just use regular RTV, doesn't really matter. The old seal should just pull right off.
#51
I have the exact same leak. I thought it was my RMS before I read this.
Pmohr, it sounds like you are saying the rear oil pan seal (half-moon) is a common source of leaking engine oil on these engines, is that correct? I suppose you would have to remove that support that runs from the back to the front of the engine bay to drop the whole pan.
#52
Yes, you have to drop the crossmember to drop the upper pan.
#53
Diagnosing the same leak
I too have the same leak on an auto. I have a pic of my d/s axle seal which is dry so I can rule that out. But take a look at my UDP. If you look at the lower part through the spaces of the UDP, it looks wet. I don't recall seeing that in the past. From this pic, does this mean my upper pan gasket is leaking?
d/s axle seal:
http://s262.photobucket.com/albums/i..._axle_seal.jpg
UPD:
http://s262.photobucket.com/albums/i...rrent=UDP1.jpg
Thanks for any help.
d/s axle seal:
UPD:
#54
^^^ mine looks much worse and I don't even care. watch the oil level and that and I don't think you will see any change really. Use of high mileage oil might help you to slow/stop the leak too.
#55
Thanks for your thoughts.
James92SE
142
01-02-2024 09:23 AM
03-12-2020 12:06 AM
06-06-2017 02:01 PM
ag90fox
09-09-2015 12:22 PM
