some update pics////duel fx35's intercooler,front kit in
WEll as some of you all know Im in the middle of a huge winter project. Here is some of my shots of the duel retro and skyline kit install after getting my new itercooler.This projector have turned out to be huge.Just to reacap the list
Built turbo vq35de with:
aris 9:1 extream duty pistons
eagle rods
Brain cower stage two cams
jwt upgraded valve springs
Bc stain less steel valves
Upgradded manifold
Balanced and blue printed
Blah blah and lot of other stuff.
Looking for about 600-650whp just for the **** of it. I know that if wont hook that power but ill be drag racing on about 450whp
Ok d2 coil overs, upgradded z32 brakes,Skyline body kit,and the new lights of course.350z anv 18inch rims.
On the duel retro I have done two fx35 per light with a 8000k bulb(they are not on in the pic) They are in a r34 chrome r34 headlight with the bowls removed. The light output should be like wow.
eagle rods
Upgradded manifold
Yeah thanks man but my third gen kick *** too. some times i wish i still have that car if I could have done some type of custom intake manifold I think I could have got the old 3rd gen in the low 12's
Lumberg™ Lookin good... in for the updates. What color you painting it or are you keeping it the blue?
Looks good. Some things are not my taste, but you are one to be different I commend that. Build looks good, and the retro looks crazy. My only concern is that the output may be TOO much for eyes to handle (there is such a thing as too bright, trust me). You also won't be able to flash people. I suppose only time will tell, though. Great job, and I can't wait to see the finished product!
Also the fx35 projector does not have the bulb control the high and low beam. The moment you give it power to the shutter it will project a high beam. SO you would be able to flash people.from low to high beam. Also im wiring it up for one set to cut on with the car and then you can cut the stalk on for the second set. Then from their you will be able to flash high beams with out the bulb going out or changing over due to the fx35 shutter! hope this helps
What you're saying makes sense but it's total overkill. You're pretty much never going to need that second set. As it is, one set of bixenons is enough for your human eyes at night. A second set may do more to harm your eyes than good to light things up, unless you aim the second set retardedy high and wide, which is a waste, IMO.
The Frye
09-02-2021 11:03 AM
