02-07-2008, 10:42 AM
how to force car to start with bad starter? tut for removal/location?
I need to know if there's a way to manually start the car if my starter is bad. I'm pretty sure it is. Just need to know where it is, if there's a write up on it, and if i can start it somehow so i can take it home to fix (i've searched and read that whacking the starter might make it start.). Might have to do it in the parking lot. I've done one replacement before so I know it aint too bad unless it was like my celica. Thanks.
02-07-2008, 10:44 AM
if manual, push start the car
Put car in ignition ( like putting key in when you have a remote starter)
Put car in neutral, start pushing it to give it a rolling start, once nice speed reached, jump into driver's seat, put the car in first gear and release the clutch..
that should work..
good luck
02-07-2008, 10:49 AM
thanks. unfortunately it's a auto. hehe, i would've popped it if it was a manua too.
02-07-2008, 10:55 AM
its not hard to replace just remove the entire upper air box, everything thing to the throttle body. then its sitting right there on top of the transmission, well towards the back a little bit.
there are two bolts holding it in and the bolt holding the positive cable on. then a connector for the ground.
you'll probably need a breaker bar to get the two bolts loose.
02-07-2008, 10:59 AM
The Dirty Pearl
Points: 21,049, Level: 91 |
For removal, read the FAQs. http://www.motorvate.ca/mvp.php/516
For starting, put the key in ignition (KOEO), arc from the B+ to the starter motor lead with a screwdriver or something else. Unless the starter is absolutely dead, eventually it should crank up.
Will it not crank up at all, or what?
02-07-2008, 11:13 AM
One Day I Shall See 15'zz
Pmohr way is probably the best way. Also you can hit the starter directly to see if that helps. Will not work though if your starter is completely gone...
02-07-2008, 11:33 AM
doh! didn't know it was auto :S
02-07-2008, 11:46 AM
Quote:
Does that apply to autos too? Can you crarify that?
02-07-2008, 11:48 AM
It's so easy to change the starter on a maxima. Don't pay, do it yourself.
__________________
97_Roadrunner
SHIFT_BOOST
^^^Yup, I've meet the legend!
02-07-2008, 12:31 PM
The Dirty Pearl
Quote:
Applies with vehicles with both auto and manual trans. Short it out manually and unless it's totally shot, eventually it will work. I've never had a starter that it didn't work on with just the first try, myself.
02-07-2008, 01:12 PM
97' SE 5spd.
^^+1 Definetly will work its how i started my car for a month wile i was working out my cold start problem.
02-07-2008, 02:20 PM
can you clarify exactly how that is done with a screwdriver? i thought the positive lead of the starter already goes to the positive terminal on the battery. Or maybe I'm thinking wrong...
02-07-2008, 02:28 PM
The Dirty Pearl
Quote:
The positive lead on the solenoid does indeed have B+ already going to it. You arc from that to the starter motor lead with a metal object.
02-07-2008, 03:26 PM
97' SE 5spd.
the batery goes to the solenoied via the thick black w/ red stripe wire. The starting circuit is activated bye the thin 12 awg wire just tuch them together jumping out the entire circuit. Just make sure the key is in the start position. There might be a spark but its cool and wont hurt. I had to run a wire from the batery and from the prong on the solenoid. I did this so i can start the car from inside instead of freeze my *** off
02-08-2008, 12:55 AM
thanks guys. i got it started by whacking a metal rod on the starter. hehe. then took the air duct. the pain in the butt were the connectors, so hard to remove. then had to get a 18 inch rachet because i couldnt get the large bolt off.
car starts fine now with new starter although there is a whoose noise that i never had with my old one. i figure as long as it starts, it's okay. my starter was the 8 teeth one not the 10 teeth one.
thanks for all the info everyone. glad this forum is so close.
05-28-2008, 07:33 AM
I'm looking at replacing my starter too ('96 I-30). Is their a diagram of the arc process to get the car started? Or can you spell it out a bit more for a newbie? How do I "arc" from the positive terminal of the battery to the starter motor lead? And where is the lead located? I know my screwdriver is not long enough to connect from the starter to the battery so I'm not sure what to do?
Also, what's a "breaker bar"?
btw, anyone know what you have to do to get thread starter permissions? I can reply to existing posts but can't create new ones. I've clicked the activation email obviously...
05-28-2008, 10:06 AM
u have to have 15 posts to e ablr to start a thread. and i believe u arc the two terminals on the starter with a screwdriver. two arc from the batt u would have to get a length of wire to the starter motor lead from the batt.
__________________
 Scoobz
95 Maxima SE *sold 9-16-08*
06 Sentra SE *til i buy my next MAX*
05-28-2008, 01:46 PM
A breaker bar is basically just a long lever arm, to provide enough leverage to "break" the bolt (figuratively, not literally). I have a metal bar about 18" long, with a 3/8" socket swivel head. Put a socket extension on that, and it'll get just about anything off. IIRC, I just needed a full sized ratchet to get the bolts off. If you put the ratchet wrench on pointing towards the firewall and pull it towards the front of the car, you can get the best leverage.
05-28-2008, 07:03 PM
Update: I did the job today after work (car was parked in my office parking lot before it quit). I was short a 10mm socket (for all the air box/breather bolts) and couldn't get the 17mm long bolt to turn. The guy parked next to me came out of the office and asked if he could help. Turns out he had exactly the tools i needed to finish the job (a 10mm socket and a larger socket wrench). For torque on the long bolt, he ingeniously suggested slipping the hole end of a large wrench over the socket handle. It gave me just enough leverage to turn the long bolt. Everything else went smooth after that.
The key was removing all of the breather box components. Car started like a charm. Great, great feeling of accomplishment. Especially thinking about the money I saved. Now I have a lifetime warrantied starter. I'll never have to buy another one!
Thanks for this forum!!!
MaximaOrg
Nissan Maxima
Paid Advertisement
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
