Where to get nissan qx windshield nozzles?
Old 01-16-2012, 07:21 PM
Justaguy's Avatar
After reading a few posts about the QX nozzles, I went to my dealer website and there is no mention of this nozzle, at least not for 95-99 maximas....so my question is...
Where did you guys buy the QX nozzles? (was there a specific model?)
I heard about the murano ones, but you have to file them...so I'll stick to QX..if I can find them!
Justaguy is offline
Old 01-16-2012, 08:32 PM
I'll take either lol I just need some new ones.
ChrisMan287 is offline
Old 01-17-2012, 02:04 AM
infinimax96's Avatar
I would also like to know this information. My nozzles have not worked in months.
infinimax96 is offline
Old 01-17-2012, 06:50 AM
njmaxseltd's Avatar
If the pump is working the fix is pretty simple.
Remove them and soak them in hot soapy water for a while.
Use a pin to poke any hard debris out of the holes, then a quick shot of compressed air. They should be good as new. Aim them correctly, a bit high on the windshield, so they work good at highway speeds.
njmaxseltd is offline
Old 01-17-2012, 07:53 AM
Justaguy's Avatar
did all that..These nozzled sucked from day 1 when I bought the car new..I want a better mist on my windshield.
Justaguy is offline
Old 01-17-2012, 01:15 PM
SLOW
Nealoc187's Avatar
what's unique about the QX nozzles? different spray pattern?
Nealoc187 is offline
Old 01-17-2012, 01:31 PM
aackshun's Avatar
Misting apparently instead of a squirt.
aackshun is offline
Old 01-17-2012, 01:35 PM
Justaguy's Avatar
The factory nozzle have two very straight sprays and the QX ones have more of a spray that covers the windshield and gives you a better clean.
Sort of like when you buy windex and you have a choice of spray-mist or direct squirt.
Now, if you live in the north where salt, slush and snow is a daily battle, and that nozzle is literally life and death here, so when you need to clean your windshield, you want it to do a good job. The factory ones just give you a peehole view.
You have you live here to understand it.
Justaguy is offline
Old 01-17-2012, 01:50 PM
Just go with the Murano nozzles. You only need to file down a tiny bit. Part # 28930-CA000.
Old 01-17-2012, 02:13 PM
tigersharkdude's Avatar
Chris is that P# for both nozzles? or would I need to order 2?
tigersharkdude is offline
Old 01-17-2012, 04:21 PM
Kevlo for President
Kevlo911's Avatar
I have an 03 QX4 and it is NOT a misting nozzle...
Kevlo911 is offline
Old 01-17-2012, 09:03 PM
I'm pretty sure you just have to order two. IIRC, the part number is the same.
Old 01-17-2012, 09:32 PM
CrazxyDominican's Avatar
do the ones for the moranos mist? which do mist?
CrazxyDominican is offline
Old 01-17-2012, 09:35 PM
The part # that I posted is for ones that mist.
03-12-2020 12:06 AM
BkGreen97
04-02-2016 05:47 AM
wingnut2006
09-19-2015 06:13 AM
coasterswim
09-02-2015 07:43 AM
Quick Reply: Where to get nissan qx windshield nozzles?
