Need help on my Rear o2 sensor
Old 02-02-2008, 10:24 PM
maxx0831's Avatar
Aight my dudes, I need a new rear heated o2 sensor for my max. Its a 96 gle maxima. I went on oxygensensors.com to buy them. I put in my info and then it says select application and under it says " from 06/96" and the other says " To 06/96" I checked the sticker on my driver side door and it says 05/96. So i want to kno which is which for my max even though it sound like a simple question. Also how is the universals, are they good or jus stick wit the OE sensor Also is the POST CAT the rear sensor?
maxx0831 is offline
Old 02-02-2008, 10:29 PM
shortyblu95's Avatar
you want the to 06/96. Dont waste time with universals and not knowing if you soldered the wires right or connected correctly. OE is seff the way to go. Its the sensor thats actually in the cat on the 95-96 models, only the 97-99's have a sensor in the actual B pipe.
shortyblu95 is offline
Old 02-02-2008, 10:46 PM
maxx0831's Avatar
ok thanks, wen I check on the application for the "to 06/96" they have 3 sensors. I need the rear heat o2 sensor. I see Pre cat front, pre cat rear and Post cat. Which is the one i need for the rear bc i heard theres liek 2 in the front and one in the back
maxx0831 is offline
Old 02-02-2008, 11:00 PM
yea theres two sensors up front, one in each bank of the y pipe. Also one in your cat. The one you need to replace is "Post cat"
Old 02-02-2008, 11:07 PM
maxx0831's Avatar
thanks a alot bro really needed this
maxx0831 is offline
Old 02-02-2008, 11:09 PM
no prob i hate when i used to come accross dumb stuff like this where i didnt know what the technical term was for something and had to go searching around to figure out what was going on ect. Goodluck with the install
Huttig2009
09-25-2015 03:31 PM
iflexsteel
09-15-2015 03:37 AM
Maxilano
08-31-2015 07:33 PM
doobadoo
08-15-2015 06:43 PM
Quick Reply: Need help on my Rear o2 sensor
