Battery and E-brake indicator lights
Old 01-14-2008, 04:51 PM
DJMaxGLE's Avatar
My battery and e-brake indicator lights will come on at random times and stay on for a few seconds. They turn on simultaneously and then turn off again. Do I have a bad battery, brake fluid leak, what? Any guesses?
DJMaxGLE is offline
Old 01-14-2008, 04:58 PM
99BlackMaxMS's Avatar
Your alternator is crapping out. Get one asap before you get stranded somewhere.
99BlackMaxMS is offline
Old 01-14-2008, 05:11 PM
Nopike's Avatar
^^^ may be right, but make sure the posts of your battery are clean and you have a good connection to the battery.
Nopike is offline
Old 01-14-2008, 05:20 PM
DJMaxGLE's Avatar
Yeah I was thinking I should check the battery terminals. Now, the lights aren't always on, just periodically. So would the alternator be working fine while the lights are off?
DJMaxGLE is offline
Old 01-14-2008, 06:00 PM
xkazik's Avatar
Thats the alternator. had the same problem , some time soon the lights will stay on and u your car will shut off.
xkazik is offline
Old 01-14-2008, 06:59 PM
hermtm2's Avatar
It will be alternator's problem. I ignored the signs and drove onto downtown. Like 15 min. later, the engine was stopped on the traffic. The car was towed.
hermtm2 is offline
Old 01-14-2008, 08:03 PM
maxima92se's Avatar
Alternator. Well the charging system.
maxima92se is offline
Old 01-14-2008, 08:10 PM
heynow's Avatar
Alternator. Lights go on when the alty can't output the needed juice.
heynow is offline
Old 01-14-2008, 08:21 PM
andrei3333's Avatar
I will say this: Alternator related, unless the ligthts are always on no matter what you do!
read between the lines if you like...
andrei3333 is offline
Old 01-14-2008, 09:01 PM
Delvin's Avatar
Get your charging system (alternator) checked before you go out there and start replacing things. Most of the time the lights on the dash start to come on like that when the voltage starts to get below a certain point which is an indicator that the alternator is starting to go bad. But to be sure go somewhere that will check the system out for you at no charge (Autozone is one place) so you can know for sure that the alternator is the problem.
Delvin is offline
Old 01-16-2008, 01:48 PM
DJMaxGLE's Avatar
I took the car into a mechanic today and they said the alternator works just fine. The temperatures have been in the single digits and teens lately. Could that have an effect on any electrical parts?
DJMaxGLE is offline
Old 01-16-2008, 02:18 PM
97_Roadrunner's Avatar
Your belt or the tentionner might be your cause....
97_Roadrunner is offline
Old 01-16-2008, 03:28 PM
andrei3333's Avatar
Im tellin you man, check the sub harness, when this exact thing was happening to me the alty tested fine as well, i still replaced it and it was not the case
CHECK the subharness that connects to the alty...trust me, save your self the agony
Count down to your car dying has begun . t - 3 months or so !!!
The Frye
09-02-2021 11:03 AM
mvm062
11-30-2020 09:00 AM
markevans999
09-10-2015 04:29 PM
Maxima30
09-07-2015 06:13 PM
JoshG
09-05-2015 10:10 PM
Quick Reply: Battery and E-brake indicator lights
