Oxygen Sensor simulator Questions.
Hello 4th Gen Orgers,
A friend of mine has a 4th Gen 1997 maxima. He just ordered an O2 simulator from http://www.o2simulator.com/
My question is, how many O2 simulators does the 4th gen 1997 have and how many need to be simulated in order to show no codes for the cats. I am assuming that all 4th Gens are federal emissions unlike the 5th gens that have cali (4 oxygen sensors) and federal (2 oxygen sensors).
Thanks for your help guys, I could not find much through the searches.
On the 5th gen cali maxima by the radiator, if i recall correctly, the first 2 (from the left) are y-pipe and precat sensors. the other 2 are after precat and cat. I am asking if the schematic is the same for the 4th gens. I dont want to wire the wrong sensors up.
I found this information for the 98's, can anyone confirm if this is true about the 97's?
http://mysite.verizon.net/vze7erz1/id13.html#simulated
Thanks for the response. Hes coming tomorrow and needs it done ASAP and I promised that I would help so I figured I would ask all the questions now so I can determine what to do on the spot.
If it's Fed spec, you can't access the downstream O2 sensor harness from the engine bay, you'd have to get to it from under the car or from inside. The harness runs through a grommet into the interior of the car right by the cat.
Should be, I'd imagine. You can get an FSM at vq35de.com/ESM and check out the wiring diagram to be sure.
http://forums.maxima.org/showthread....r+Installation
I am looking at the diagrams and I am confused. Not sure which bank refers to which sensor. I will look tomorrow maybe it will all make sense. THanks so much for your help.
my03maxima
04-29-2020 12:48 AM
trsandrew
04-08-2016 06:45 PM
trsandrew
10-25-2015 02:47 PM
