Go Back   Maxima Forums > Maxima Discussions > 4th Generation Maxima (1995-1999)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 07-23-2009, 10:23 PM   #161
Quote:
Originally Posted by grey99max View Post
OK - that's clever - now I really would like to see photos of this mod. What did you use for a cam sensor, and how did you mount it? I guess that you had the rear of the exhaust cam machined to match the 3.0 cam signal?
Your right about the cam machining, it basically involves replicating when TDC occurs so the ECU knows when to fire each cylinder and synchronising with the crank sensor. With VCT, if the intake cam was used when ever the cam changed position, the engine would go into fault mode once the cam and crank signals go out of phase on the VQ30 ECU. The RB25 ECU could 'work' with just an intake cam input BUT you would need an inifinte amount of maps to adjust ignition advance and retard as the only engine position signal was moved in relation to the actual engine position. Hence why I went with the exhaust cam, which the RB25 NEO engine also uses for cam position
If you look at the FWD VQ35 head casting, it conveniently has the perfect spot right next to the intake cam sensor to mount a cam sensor once the head has some suitable machining Looks almost like the 350Z Rev-up exhaust cam sensor setup actually
__________________
Nissan N14 Pulsar - VQ35DE, 6spd HLSD, Kelford Spec C cams, 12.7:1CR & E85 tuned
Smashed Holden VY SS LS1 Twin Turbo Ute - 641rwHp@12psi Pics
New LS3 6.2 Camaro, Boyd Harm wheels and a big single Turbonetics huffer...
throttlehappy46 is offline   Reply With Quote
Old 07-24-2009, 10:32 AM   #162
The LandShark has teeth..
grey99max's Avatar
My Cosworth heads have holes for both sensors - that why I'm curious about your mods. I bet it's quite complicated to get the cam machined to match the VQ30 intake cam timing wheel. Did you use an intake cam sensor for this mod?
Pretty cool stuff, actually....
__________________
'99 GXE, Tune-by-Tape MAF mod, 3.5L w/cams, SSIM, 255Walbro,AERO FPR, VLSDauto, Edge TC, DR-mod, Shift_Fast, dual-B&M cooler, JClawbars, cryoed axles, dual-NX nitrous, dual heated15lb bottles, OBX headers, 3"Warpspeed exhaust, PLXR-300 wideband, IlluminasStrut/springs, 24.5"M&H, ProgressRSB, HawkHPS, Clarion50Wx4 head w/Alpines, Fosgate sub. Spare tire+jack,3300 lb car. 355WHP-dyno.
12.394 @113.22 ( 114.51 now) w/3.5
http://i48.photobucket.com/albums/f2...9/DSCN0527.jpg
grey99max is offline   Reply With Quote
Old 07-26-2009, 04:49 PM   #163
Shift_custom
well how did the ecu workout for Nealoc?? any updates? times?
__________________
" 97 in progress"
97Maximus is offline   Reply With Quote
Old 07-26-2009, 09:41 PM   #164
SLOW
Nealoc187's Avatar
Send a message via AIM to Nealoc187
it hasn't arrived yet
__________________
95 SE - Stock 3.0L w/ USIM - T61/P-trim @ 14.5psi - 93 octane
11.76 @ 121 - 1.82 60' - ET Street DOTs
12.15 @ 123 - 1.95 60' - Nitto DR
3.5L swap with I/Y/E
12.92 @ 104 - 1.69 60' - M&H Slicks
13.60 @ 103 - 2.15 60' - Street tires
96 GXE - I/Y/E/MEVI/JWT ECU
13.42 @ 102 - 1.87 60' - M&H Slicks
13.82 @ 102 - 2.17 60' - Street tires
95 GXE - Stock winter beater
14.28 @ 95 - 2.07 60' - Street tires
High Flow Fuel Injectors
Injector Cleaning & Servicing
www.DeatschWerks.com
Nealoc187 is offline   Reply With Quote
Old 07-27-2009, 08:32 PM   #165
Not trying to start anything but you guys should read the maximasdownunder.org forums. According to them, he is not very trustworthy and keeps making excuses for everything. He's been banned on several local forums.
__________________
Back to STOCK!
Carlos is offline   Reply With Quote
Old 07-27-2009, 10:30 PM   #166
Send a message via MSN to Blackwind
Quote:
WOAH!!! BLINDSIDED!!!
you have links to prove your claims? otherwise its just hearsay.
__________________
"9 out of 10 Housewives approve of this product."
Blackwind is offline   Reply With Quote
Old 07-27-2009, 10:53 PM   #167
The Dirty Pearl
pmohr's Avatar
As he said, just read the forum...
http://www.maximasdownunder.org/foru...kirom&start=15
Quote:
Originally Posted by jordan
ANOTHER forum you're going to troll eh? What's that, 5 you've been banned off for talking sh*t so far? You obviously have a camera to take photo's (as is evident by the 'new' pictures on your Photobucket), yet you STILL can't take ONE SINGLE ENGINE BAY SHOT.
What about the bloke you agreed to show the cars in person, then made up excuses for two days straight and in the end turned your phone off?
I'm not here to troll, just warn people not to waste their time with threads built on hopes and dreams. Now, I'll happily delete this post if you can actually prove anything you've claimed - the LSx powered R34 GTR would be a good starter...
EDIT: By the way, just a taster.
http://www.boostcruising.com/forums/...owtopic=411474
http://www.neovvl.org/forums/viewtop...er=asc&start=0
Quote:
Originally Posted by Twincam16
So Mr Iamhappy46.
After you were shamed out of boostcruising, pulsar group of australia, australian ls1 forums due to your blatant lies, this is where you have come to hang out now?
Funny i reckon.
You sit and say that you cant come to the other forums due to the work internet being cut off, strang that you manage to come here.
To all the members on here that are even considering beliving what he says, ask for photos. He will always make a reason as to why he cant provide pics.
A member off boost went to meet up with him to put to rest all his constant lies, and once again, he never came thru with the goods.
Be weary maxima folk. He is nothing but a virus in the community that is able to tell a good story.
Heh:
Quote:
Originally Posted by Maximus
damn thats disappointing
funny how the yanks believe he has all the answers and are more then willing to help his efforts with the ECU. i guess they are more gullable
i cant help but wonder whether he is telling the truth, what did we have to lose by keeping him on here
Quote:
Originally Posted by Maxima1984
So true! Glad we got rid of him; probably was that 'iamhappy46' guy from Pulsar Group of Australia and whatever other alias's he's gone by on other forums... dreamer.
One such forum he's banned on, speaks to his credibility:
Quote:
throttlehappy - 27th May 2007 - Banned for abusive comments, making useless posts & discussing illegal activities. Also had a habit of using unsuitable avatars & user titles.
Also banned on pulsar.org.au and some others.
Not taking sides, just doing the googling.
__________________
Quote:
Originally Posted by 2damax View Post
This jerk is right so often I just search threads hoping he gets something wrong so I can catch him
Quote:
Originally Posted by kizzmyazz View Post
ok so what i found out is that because of the FMU, i dont need to get injectors because it will neutralize the oil pressure to prevent detotnation
FSMs | A32 CEL Decoder | Howto Videos
pmohr is offline   Reply With Quote
Old 07-27-2009, 10:57 PM   #168
Shift_custom
this is what i have found. http://www.maximasdownunder.org/foru...t=3038&start=0
although all they claim is that he never produced pictures to prove if he really had what he said. from looking at his pics on his profile on here he has pics of most of the things hes posted about.. the only thing hes thorough about is TT LS1 tho.. He has a couple of pics of a vq35de and an engine bay shot (which they clamed he couldnt produce) So long story short someone followed him around bad mouthing him and the australian maxima site banned him because he couldnt produce evidence also (pics).. but from looking at the history of this thread he doesnt seem to be in a rush about anything.. soo.. IMO hes just a busy guy and got a bad wrap.. idk view the link.. take your own opinion.. im going to bed!
__________________
" 97 in progress"
Old 07-27-2009, 10:58 PM   #169
Shift_custom
^^pmohr beat me to it..
__________________
" 97 in progress"
Old 07-27-2009, 11:02 PM   #170
wow did not see that coming
__________________
Old 07-27-2009, 11:58 PM   #171
Shift_custom
the more i read the thread on maximasdownunder.org the more i realize how childish they are on there.. its like theyre just bored or something.. i mean the mod banned the guy on he said/ she said bull**** (rumors).. he never did any of what ppl claimed on the aussie website.. so why ban him.. ppl can change.. i mean come on in a matter of 8 days from joining their website jordan banned him for not posting pics of an engine bay he claimed to have?? really? get over yourself.. if this guy was a fake as everyone claims he is, then how is he making all this so-called "bull$hit" up and having a logical conversation with grey99max about cam sensor locations, and pm nealoc about a test run for a protoype ecu.. i say if he produces with nealoc then the guy is legit and that the mod 'jordan' on the aussie forums needs to grow up and quit overreacting to rumors.. again my .02
__________________
" 97 in progress"
Old 07-28-2009, 05:32 AM   #172
Quote:
i do agree with ya on this.
__________________
Old 07-28-2009, 07:14 AM   #173
Actually, I am only banned on two forums... and that includes MDU.
Just to clarify, the MDU site has timmyp34 stating that people have lost money because of me but yet he has no proof to back that up. My lawyer has viewed the site and a nice little defamation case is winging its way to him already for that comment unless he wants to provide evidence to the judge on who it was with a signed affadavit from said person detailing the events No doubt he is a sheep and too stupid to realise someone else led him up the garden path!
Dont get me started on Twincam16... I have proof of enough 'wrong info' dished out by him to fill a text book. He told a Pulsar forum member to use SR20DE valves to rebuild a DET head, not realising that DET valves are sodium filled and thus use a different valve stem. As I dont post on the Pulsar forum anymore(by choice!) I contact Twincam16 via PM on boostcruising to correct him, the attacks on boostcruising started just after that actually. Strange...
Boostloosing as it is affectionately known, is a bit childish. I actually signed up for the tech section where 95% of the responses in the tech section are from me and 99% of the answers were accurate and often saved forum members money!
Yes... I had 'legal issues' with my driving licence for a LONG time and I had a good reason for not posting pictures of a my personal cars. The TT LS1 was a work vehicle
I also have a nice Ricoh CX1 camera and a Sony video camera to ensure that the conversions I have done are accurately covered and documented...
I am sure that Travis(turbos13hatch) can comment on what its like to have people copy the work and effort you put into doing a high quality conversion kit, so YES I have been very coy on how much info I provide as I would like some exclusivity in our local market for atleast a few months.
The old Pulsar has already been photographed for a car magazine, I am just waiting on the results of a local car drag racing event(Jamboree) before the article is made public with an update on the new engine setup.
Now, since I have the offer on the table that US customers can pay via paypal OR deal with Lucas from Bikirom direct... then I struggle to see how I am gaining anything other than the fact I did something different and the info is shared in the community. The HOURS I spent thinking outside of the box to get this conversion sorted, with Maxima owners getting the advantages as well speaks of what my real passion is... CARS.
I have offered the ECU's to Nealoc and others for no cash down at all for the sole purpose of testing the ECU's in the USDM. If they are happy with the product, then cash exchanges hands. Does that sound like the actions of a nigerian scammer?
I do actually work crazy hours, which is not even in the automotive industry. Cars are a passion that takes up most of my spare time, which I have minimal of anyway. As such, not being on the ls1 or boostcruising forums, I have a lot more time for action
PS: I even PM'd Jordandalley via this forum and offered him access to my LOCKED Photobucket folder to view the cars(every Pulsar I have converted so far!) on the condition the info is not shared yet. No reply... thats why I have no interest in returning to MDU even if I get unbanned.
Also, in post 168... the section about why I was banned is untrue!
I never abused anyone, I NEVER EVER discuss illegal activities(due to the legal stuff I had going on!) and the rest of the stuff is also wrong. Not even sure which forum that is from since I cannot acces boostcruising or ls1 forums until my home ISP is restored.
__________________
Old 07-28-2009, 07:37 AM   #174
The interesting part about the Pulsar forum is:
http://forum.pulsar.org.au/showthread.php?t=52593
I developed a system for Pulsars to upgrade the stock ignition system with the Crane Cams LX91 ignition coil with detailed instructions, nearly every forum member now sports this upgrade.
Also notice the last time I logged in?
__________________
Old 07-28-2009, 08:15 AM   #175
You can't friend yourself
Kevlo911's Avatar
We don't need to bring old baggage over, it seems you are helping us just fine...
__________________
97 Pearl White Max GLE
I has car
LED tails for sale for 97-99 as well:
http://forums.maxima.org/4th-generat...-interest.html
Kevlo911 is offline   Reply With Quote
Old 07-28-2009, 10:38 AM   #176
im still on the list when these ecu's come out.
__________________
Old 07-28-2009, 11:39 AM   #177
I would love to get one aswell. Im just not going to get my hopes up.
__________________
Back to STOCK!
Old 07-28-2009, 11:54 AM   #178
Shift_custom
agreed man.. keep me on the list.. enough said.. like kevlo911 pointed out, let it rest.. i even stayed up and read the majority of the "boostloosing" forum also.. and that timmyp34 guy seems like a big douchebag.. just a punk kid really lol.. it was like the pot callin the kettle black.. the more info you provided him the more he kept wanting.. there was no shutting him up lol.. your wealth of knowledge cant be 'made up' in my opinion.. no one research's a subject as much as youve shown on here just to lie about not having a car.. lets not turn our forum into a 'soap opera' as one of the guys on MDU called it.. keep up the goodwork! i have a spare ecu waiting
__________________
" 97 in progress"
Old 07-28-2009, 02:45 PM   #179
grey99max's Avatar
Same goes for me - his knowledge and skills show through the other BS. I understand him wanting to protect his developments - I agree.
Stick around, bud.
Old 07-29-2009, 01:21 PM   #180
Shift_custom
soo.. whats the update.. did you get your cams,flywheel, etc back from the machine shop yet? aka have you started the rebuild already. oh btw is lucas waiting on your input for the start of the V4 board production?
__________________
" 97 in progress"
Old 08-01-2009, 12:09 AM   #181
Machine shop still has the front bank exhaust cam but other than that, the engine is sorted out and awaiting time for the workshop to install it.
Lucas spent a month in Europe on holiday(my holiday was spent working on cars lol)
He is back now so I can send him the next VQ30 ECU I have here and get a few more V4 boards sorted out for testing / sale etc.
__________________
Old 08-01-2009, 07:12 PM   #182
SLOW
Nealoc187's Avatar
were you able to get the one coming to me sent back out?
__________________
Old 08-05-2009, 08:45 AM   #183
maxine'sMan's Avatar
wow.. wasn't expecting all that drama when I came back to this thread. Good things come in good time. I'm sure this project isn't easy which is why I have been patient and simply offer to help with whatever I can. We aren't always innocent of this here either, look at what just went down with the RB26 in a maxima thread over the past week.
I say keep up the good work man!!
maxine'sMan is offline   Reply With Quote
Old 08-06-2009, 11:07 AM   #184
Working 92 hours a week at the moment Nealoc, the girlfriend is taking it to the post office for me as soon as she has a spare 5 minutes. Hopefully US Customs are happy with the documentation this time!
It is 3.05am here, thats how busy I am and my last 25 minutes before I got to sleep are spent on car related stuff then back to work in 6 hours to do it all over again.
__________________
Old 08-18-2009, 09:01 PM   #185
ECU was sent this morning Nealoc, Lucas has two more ECU's ready for fitment and testing. If everything is fine 4 weeks from now, I think it will be considered a success.
__________________
Old 08-18-2009, 11:13 PM   #186
SLOW
Nealoc187's Avatar
awesome, looking forward to it.
__________________
Old 08-18-2009, 11:27 PM   #187
Send a message via AIM to kzoosho Send a message via MSN to kzoosho Send a message via Yahoo to kzoosho
Let me know how things go Neal, U know i am always looking for something to spend money on.
__________________
97 SE Auto Built Auto
97 SE Holset HX52|N2O|6 SP|Built 3.56|More to come
91 GXE Auto bone stock beater
91 GXE 5sp Another beater
Led retro's Pm me
kzoosho is offline   Reply With Quote
Old 09-05-2009, 10:41 PM   #188
Send a message via AIM to mightyMax95
updates? i'm always looking for something for kzoosho to spend money on.
__________________
Originally Posted by mightyMax95
well, i got the water pump in
Reply Posted by streetzlegend
if the car starts, ur not a nooblet anymore!
i'm just gonna start answering all ?'s i have for you with, "ebay"
Reply Posted by kzoosho
lol, u could
Originally Posted by Matt93SE
Took me a ton of money to learn that physics will ALWAYS win against a FWD car.
mightyMax95 is offline   Reply With Quote
Old 09-16-2009, 09:58 PM   #189
Shift_custom
Well 4wks was yesterday.. And still no updates of whether the ECU even worked for Nealoc
__________________
" 97 in progress"
Old 09-16-2009, 11:12 PM   #190
there have been some issues with shipping and customs. Neal will inform us as soon as he has received the ECU and successfully completed testing.
delays happen, that's R&D for you.
__________________
lol, u could
Old 09-17-2009, 02:29 AM   #191
Dont transport ECU's with plywood strapped around them to stop the scanners from 'blanking' the EPROM chips. I also suspect they opened up the packaging to ensure I was not sending 5Kg's of stuff the D.E.A would be interested in either.
__________________
Old 09-17-2009, 05:57 AM   #192
SLOW
Nealoc187's Avatar
Nope no updates other than US customs keeps screwing with getting the ECU to me. They have sent it back to Australia twice now. They are really delaying my turbo 3.5 project and I also want to test the ECU out NA before I returbo lol. Trust me I've updated ya'll continuously on stuff way less important than this, once I have something to update you on I'll be posting full analysis.
__________________
Old 09-17-2009, 08:47 AM   #193
Shift_custom
no worries guys.. this was all news to me.. just curious.. thats bs tho.. twice? geez! where the hell is caesar at? cant he test this thing? lol.. thanks for the update tho
__________________
" 97 in progress"
Old 10-16-2009, 02:41 PM   #194
SLOW
Nealoc187's Avatar
we're not going to whore up this thread like this... something will be posted when there is something to post.
previous posts deleted
__________________
Old 10-22-2009, 09:16 AM   #195
Shift_custom
something is always better than nothing.. i feel sorry for ppl who have worked their builds around the production of this ecu.. including you nealoc.. i still ask the same question of.. why dont we contact ceasar to test this thing so that we can keep the ball rolling and get it tested in a US car? that seems a lot easier than keep running into a wall over customs battles..
__________________
" 97 in progress"
Old 10-22-2009, 10:05 PM   #196
very interesting!!!
kisas is offline   Reply With Quote
Old 10-23-2009, 12:43 AM   #197
I am 99.99% sure there will be no problems with fitment and running for 99.99% of US cars and there will be no issues with Australian cars. However, V3 of Bikirom did have a few issues upon initial release which did have problems(The Bikisoft program was at release 3.4.11 from memory prior to V4's release) and I would REALLY like to avoid that with you guys since the shipping cost across the Pacific would make it a hassle.
At the moment, I am aiming for a few more tables mapped out in the factory binary but I require Lucas(Bikirom creator) for that part, which is time intensive. Then, mapping out the binaries requires my time to work out what the values affect. For example, throttle enrichment tuning is the small squirt of fuel added when the throttle position increases, as a large volume of air is initially sucked into the engine before the MAF registers the additional air flow. The MAF has already metered the air but as it is used quicker, more fuel is required. This is an electronic version of the old carby accelerator pump
So although Nealoc should have his ECU by end of next week, there will ALWAYS be development going on from the Australian end as we map out values that are worth altering. I am working on a little side project when I have had spare time which will make the need for a 95/96/97 VQ30 ECU not mandatory either since RB25 R34 ECU's sell cheap. The RB25 ECU looks like it can be reprogrammed to take the VQ30 cam timing signal, which means VQ35 swaps into 4th gens will be less complicated.
EDIT: Just spoke to Lucas, I have EIGHT (8) ECU's being sent to him for fitment in the next few dyas once I get home next. I will be home for 3 months after November as the mining jobs I have been doing are starting to dry up and I actually would like to spend my commission money some time. If there are any members in the Las Vegas area during mid december that are interested in a free install and custom tune, then feel free to contact me
__________________
Old 10-23-2009, 08:54 AM   #198
DUDE!!!! ILL LET YOU STAY AT THE HOUSE!!!!! im in vegas hit me up!!!!!
__________________
Old 10-30-2009, 08:38 PM   #199
Shift_custom
so these boards for the VQ30 will be V4 boards with the V3 software? When is the V4 software expected to release? Also.. when you are in Vegas can we save on shipping across the pacific.. Can you ship the 8 from the states? If so ive got the money let me know.. Actually I already have a 95 ECU waiting for this so.. Oh still never heard back from you about the screenshot for the VQ35 volumetric efficiency data..
__________________
" 97 in progress"
Old 11-12-2009, 03:55 PM   #200
..bump..
Been nearly a month so worth a bump I think
killerVQ30DE is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
