Go Back   Maxima Forums > Maxima Discussions > 4th Generation Maxima (1995-1999)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 05-08-2009, 07:37 PM   #121
SLOW
Nealoc187's Avatar
Send a message via AIM to Nealoc187
Quote:
Originally Posted by throttlehappy46 View Post
JWT chips are protected, they scramble the chips so if you tried to download them the binary is scrambled. Their boards 'decode' the scramble to make sense of it. Hence why you need to send a JWT back to them for reprogramming.
Nistune I believe are still working on getting their boards functioning in the VQ30 ECU's.
Bikirom is quite easy to tune and I intend on supplying a base tune that is 95% accurate for 95% of most I/H/E modified engines. That data logging ability will allow you to 'log' data and then send me the log file if you require help doing a custom touch up
For instance, moving the MAF closer or further from the throttle body will require a small adjustment of the throttle enrichment map, etc.
I have 2 weeks off at end of this month(been involved in a huge contract at work), will aim to have first five ECU's with V4 boards ready for US based testing mid July.
I've sent you a couple emails, I know you're busy though. I hope we can work together to get it tested still. Let me know.
__________________
95 SE - Stock 3.0L w/ USIM - T61/P-trim @ 14.5psi - 93 octane
11.76 @ 121 - 1.82 60' - ET Street DOTs
12.15 @ 123 - 1.95 60' - Nitto DR
3.5L swap with I/Y/E
12.92 @ 104 - 1.69 60' - M&H Slicks
13.60 @ 103 - 2.15 60' - Street tires
96 GXE - I/Y/E/MEVI/JWT ECU
13.42 @ 102 - 1.87 60' - M&H Slicks
13.82 @ 102 - 2.17 60' - Street tires
95 GXE - Stock winter beater
14.28 @ 95 - 2.07 60' - Street tires
High Flow Fuel Injectors
Injector Cleaning & Servicing
www.DeatschWerks.com
Nealoc187 is offline   Reply With Quote
Old 05-24-2009, 08:52 PM   #122
Hey Nealoc187,
Your definitely on the list. I aim to send you through the first ECU as soon as it is assembled
Holidays start next week
__________________
Nissan N14 Pulsar - VQ35DE, 6spd HLSD, Kelford Spec C cams, 12.7:1CR & E85 tuned
Smashed Holden VY SS LS1 Twin Turbo Ute - 641rwHp@12psi Pics
New LS3 6.2 Camaro, Boyd Harm wheels and a big single Turbonetics huffer...
throttlehappy46 is offline   Reply With Quote
Old 05-24-2009, 09:17 PM   #123
Send a message via AIM to 98SEBlackMax
Hey Nealoc187,
I've been looking forward to this.
How long is the waiting list for this ECU? Also is it possible to send the daughterboard to me so I can solder it in? or do you want us to send the ECUs to you?
__________________
- Joe
1996 KH3 Maxima SE - 222 WHP / 208 WTQ SAE corrected @ 209,000 miles, VQ30DEK swap
(5 spd - project car, never ending money pit )
2007 KH3 Frontier NISMO 4x4 - ??? WHP / ??? WTQ
(6 spd - daily driver)
98SEBlackMax is offline   Reply With Quote
Old 05-25-2009, 11:13 AM   #124
Send a message via MSN to Blackwind
just an odd question. does climate affect tuning with ecu upgrades? meaning; will a car in a humid enviroment perform differently than a car in a desert enviroment?
__________________
"9 out of 10 Housewives approve of this product."
Blackwind is offline   Reply With Quote
Old 05-25-2009, 11:20 AM   #125
'Trynna' is not a word
mtrai760's Avatar
Quote:
Short answer: Yes.
__________________
98 SE - VQ35
2k SE - Stock... pretty much
Boost, juice, conversions, been there, done that.
mtrai760 is offline   Reply With Quote
Old 05-26-2009, 02:08 AM   #126
If your capable of some baisc soldering, then the daughterboard can be sent over and then you just need to send the original base map(its extracted via the software) then use the activation code to enable the board.
Air flow meter does compensate to a large degree but yes, some adjustment can be required in extreme humidity changes etc.
__________________
Old 06-08-2009, 08:51 AM   #127
Around 1am in the morning here...
VQ35 VCT system is functional, I actually have a much more efficient way of running the VCT system now that references the AFM voltage at a given rpm point and with some basic data logging self learns how much PWM is required for maximum torque at the given 'cell' rpm points Interpolatation between cells is linear.
To do this calculation, I actually set the VCT system up the same way Bikirom uses its boost control system, with the CMPOS signal looped wired up like a MAP sensor and solenoid PWM varied between ranges to keep CMPOS ref within range.
VQ30 ECU info later this week, few late nights should make some heavy progress
__________________
Old 06-15-2009, 01:48 AM   #128
Rowan's Avatar
Great work. Interested in the Vq 30 ECU options.
Rowan is offline   Reply With Quote
Old 06-15-2009, 07:20 AM   #129
Quote:
Me also. If you need any help, let me know. I have electronics experience as well as firmware engineering. And there's just something about modifying the stock ECU that appeals to me.
__________________
Pay? For labor?
ajm8127 is offline   Reply With Quote
Old 06-15-2009, 10:24 PM   #130
VQ30 ECU A18-E11-ER1 as per the JWT ECU database, on page 2 of this thread.
One V4 Bikirom board
One V4 Bikisoft Program
Testing and dyno tuning this week
Will be using the Tomei cams for now in my VQ35 with the V3 settings used to make sure it runs properly with the 'known good' tune I have in the RB25 ECU. Test it on a VQ30 Maxima next week and then send the first one out to Nealoc187 for USA testing
VQ35 testing has made a further development last night though, VCT is now a function of airflow from the MAF. If air flow is not increasing voltage(ie dropping airflow under increasing TPS voltage) then VCT solenoid PWM is altered to increase airflow and load, for maximum torque at all times. This also allows cam timing to be optimised for part throttle and allows extensive use of the volumetric efficiency table to give better fuel economy.
__________________
Old 06-16-2009, 04:49 AM   #131
VQ30 ECU A18-E11-ER1 as per the JWT ECU database on page 2.
Martha stewart says:"And thats a good thing."
__________________
Old 06-16-2009, 07:54 AM   #132
maxine'sMan's Avatar
Hopefully you still have me in this line up, I have been waiting for this since you started posting about it in 2007. I have cash, ECU's, and access to a dyno ready to go whenever you are ready! Just let me know,.
Cheers.
maxine'sMan is offline   Reply With Quote
Old 06-16-2009, 08:56 AM   #133
KRRZ350's Avatar
Send a message via AIM to KRRZ350
I'm still anxiously awaiting this as well, in fact I've come close to getting rid of the maxima and picking up a galant vr-4 just so I can tune with dsm-link
KRRZ350 is offline   Reply With Quote
Old 06-16-2009, 10:10 AM   #134
You can't friend yourself
Kevlo911's Avatar
I am down to get rid of my EU as soon as we can confirm it works. Let me know if you need any help
__________________
97 Pearl White Max GLE
I has car
LED tails for sale for 97-99 as well:
http://forums.maxima.org/4th-generat...-interest.html
Kevlo911 is offline   Reply With Quote
Old 06-17-2009, 04:43 AM   #135
Quote:
Cheers.
Yeah, your definitely on the list
Quote:
Will be in contact soon
__________________
Old 06-17-2009, 12:01 PM   #136
SLOW
Nealoc187's Avatar
Anxiously awaiting this. If I get it within enough time to do some thorough street testing I'll test it at a 2 day track even that I'm doing on July 18 and 19.
__________________
Old 06-25-2009, 09:40 AM   #137
V3 board in the '2nd' ECU which is getting a V4 board shortly. You can see the USB port sticking out of the stock 'slot'
Attaches via the two left hand side screws and the daughterboard solders into the factory main board via a ribbon cable
__________________
Old 06-25-2009, 08:12 PM   #138
wow. ive been watching this thread since the beginning. this is going to be good. please, add me to your list of people to contact when this has been tested on US soil. thanks!
__________________
|VQ35DE w/3.0 timing Components|Vortech V2 SC w/ 3.33" pulley|440cc Injectors|AEM Methanol Injection|y-pipe|3inch exhaust|KSport Damper|Stillen Lip Kit|Carbon Fiber Hood|Work Equiped
emdot is offline   Reply With Quote
Old 06-25-2009, 08:37 PM   #139
The LandShark has teeth..
grey99max's Avatar
Damn - this will be the Holy Grail of VQ30 ECUs !! Since I'm using a stock '99 ECU with my much-modified car now, I am super interested in this mod
Watching closely for developments - this could do wonders for my coming Cosworth-based 3.5 engine.
(have spare ECUs - '99 and '98, $$$, and some electronics experience picked up doing medical device design and production).
__________________
'99 GXE, Tune-by-Tape MAF mod, 3.5L w/cams, SSIM, 255Walbro,AERO FPR, VLSDauto, Edge TC, DR-mod, Shift_Fast, dual-B&M cooler, JClawbars, cryoed axles, dual-NX nitrous, dual heated15lb bottles, OBX headers, 3"Warpspeed exhaust, PLXR-300 wideband, IlluminasStrut/springs, 24.5"M&H, ProgressRSB, HawkHPS, Clarion50Wx4 head w/Alpines, Fosgate sub. Spare tire+jack,3300 lb car. 355WHP-dyno.
12.394 @113.22 ( 114.51 now) w/3.5
http://i48.photobucket.com/albums/f2...9/DSCN0527.jpg
grey99max is offline   Reply With Quote
Old 06-30-2009, 04:56 PM   #140
Shift_custom
I would love to get my hands on one of these! As everyone says.. Keep us updated.. Great work!
__________________
" 97 in progress"
97Maximus is offline   Reply With Quote
Old 06-30-2009, 11:10 PM   #141
Very interesting!!!
I tried to get Calumsult to do something very similar to this but he's been too occupied and focused on SR20 options.
I would definately be interested in this! I was about to purchase an EU, but I think I'll wait. I can really benefit froman extended rev limiter I hate the cut off at 6400.... The car pulls great and then all of a sudden, BAM! its like a huge tease!
Subscriing to get in line for this! I'm willing to solder the board myself as well.
I imagine there will be a huge waiting list for this! If there's already a list, please put me on it. hehehehe
__________________
915Max is offline   Reply With Quote
Old 07-01-2009, 10:21 AM   #142
Shift_custom
^^ agreed put me on the list please
__________________
" 97 in progress"
Old 07-02-2009, 04:51 PM   #143
RIP Kevin007
ajcool2's Avatar
Send a message via AIM to ajcool2 Send a message via MSN to ajcool2 Send a message via Yahoo to ajcool2
Subscribing for results.
__________________
DCMAX FTW
The Green Lantern 14.98@90mph 60' 2.14 AUTO (Before the 00VI) 170 HP 3140lb w/driver
The 3.5 Swap 15.508@90mph 60' 2.3 AUTO (Bad KS and stock catback) 210whp, 213wtq
The Dark Phoenix 13.462@102mph 60' 1.9 AUTO 257 RWHP 3280lb w/driver
Fear me.
My VQ35 Swap Progress Thread Now Complete!
ajcool2 is offline   Reply With Quote
Old 07-05-2009, 10:36 PM   #144
Back to Stock
xlcrew's Avatar
Send a message via AIM to xlcrew
didnt see this covered, but will this type of set up work for a 5th gen 3L? very curious, would like to get rid of my SAFC II and raise the rev limit
__________________
sex is like math, u add the bed, subtract the clothes, divide the legs, leave your solution, and pray you dont multiply!
xlcrew is offline   Reply With Quote
Old 07-06-2009, 03:38 AM   #145
Any car or wiring loom that can run a 95/96/early 97 VQ30 ECU will work. All late 1997 onwards ECU's are different internally. I have bought seven ECU's so far and still grabbing as many as I can that are reasonably priced. Anyone who wants just the Bikirom board, will require a suitable VQ30 ECU that has the expansion slot.
Suitable ECU's that will take a board: http://jimwolftechnology.com/wolfpdf/ECU-ID.PDF
Middle of page 6 for I30 ECU's
Bottom of page 8 for Maxima ECU's
Top of Page 9 for Maxima ECU's
All of the above ECU's will accept a Biki board, the 'stock' binary actually varies between boards though so 'sharing' tunes may cause problems. Hence if your ECU part number has not been 'cracked' yet, the stock tune will need to extracted so we can modify it to suit the Bikirom board.
__________________
Old 07-06-2009, 09:16 AM   #146
I have been waiting on this to start my 00VI swap. Can you give us an indication as to when you expect it to be completed? Cheers!
__________________
97SE 5spd, Clear corner, Red/clear tail, Tint, Warpspeed CAI & Y-pipe, Courtesy B-pipe, UR Pulley, Koni/Eibach, FSTB, Metal master pads, 18X8.5 Nismo Altima SE-R (17lbs), 235 40 18 Conti CompSport2, Stillen Lip Kit sitting in my garage.
kajeno is offline   Reply With Quote
Old 07-06-2009, 08:33 PM   #147
Hey Nealoc,
Can you email me your postal address please? Get this one sent off so you have some time to play with the tuning for your car and make your deadline
__________________
Old 07-06-2009, 10:13 PM   #148
SLOW
Nealoc187's Avatar
I sent it to you in a PM.
__________________
Old 07-07-2009, 05:26 PM   #149
Not a GM sack rider...
is there going to be a limited run of v4 boards or would I still be able to get one a few months down the road?
DAVE Sz is offline   Reply With Quote
Old 07-07-2009, 05:35 PM   #150
V4 boards will be around for a few months yet, I believe Lucas normally orders them in 500 lots. They do sell quickly though but he normally places a replacement order before he runs out. V4 only took so long due to a complete redesign from V3 with the mini-SD memory card slot and a few other features in the V4 boards
__________________
Old 07-07-2009, 06:17 PM   #151
cool. I have a spare ECU so when the time comes, and if you're still doing this, I'll let you know...
Old 07-07-2009, 08:58 PM   #152
cant remember if i asked this,will the 98's be able to use this ecu with no worries on changing any wiring?
__________________
Old 07-07-2009, 08:59 PM   #153
The Dirty Pearl
pmohr's Avatar
There are a pin or two that are in different locations (rear O2 signal wire, IIRC) but otherwise a 95/96 ECU will run in a '98 no problem.
__________________
Quote:
Originally Posted by 2damax View Post
This jerk is right so often I just search threads hoping he gets something wrong so I can catch him
Quote:
Originally Posted by kizzmyazz View Post
ok so what i found out is that because of the FMU, i dont need to get injectors because it will neutralize the oil pressure to prevent detotnation
FSMs | A32 CEL Decoder | Howto Videos
pmohr is offline   Reply With Quote
Old 07-07-2009, 09:04 PM   #154
Quote:
i hope so.
__________________
Old 07-16-2009, 08:37 PM   #155
From a IM I got last night... may as well explain it to everyone
Just to clarify how I am using a VQ35 timing chain arrangement to run the VQ35 with VCT, without causing Cam/Crank sensor sequence conflicts in the VQ30 ECU when VCT is active...
I cheated... front bank head casting and exhaust cam is modified. Its also how I got the RB25 Cam position signal originally when I was running the RB25 ECU Replicate the stock ECU Cam signal and your set
Hopefully, Nealoc gets his ECU in time and we can make some more US progress along with an independant review
__________________
Old 07-16-2009, 09:32 PM   #156
grey99max's Avatar
So... you cut down a 3.0 intake gear (for the timing marks) and hung it on the left exhaust cam gear, then mounted the 3.0 cam sensor to match the correct 3.0 ECU timing? or something like that?
Sounds good - Pictures ??
Old 07-21-2009, 09:51 PM   #157
Close The 3.0 timing gear on the opposite end of the exhaust cam would be spinning in the opposite direction which puts firing sequence out. For it to work, I actually had the exhaust cam itself notched to replicate 3.0 CMPS signal waveform(originally used the RB25 waveform which is common knowledge locally which is why my RB25 ECU equipped VQ35 got up and running a lot quicker)
__________________
Old 07-23-2009, 09:25 AM   #158
grey99max's Avatar
OK - that's clever - now I really would like to see photos of this mod. What did you use for a cam sensor, and how did you mount it? I guess that you had the rear of the exhaust cam machined to match the 3.0 cam signal?
What would it take to get a '99 Maxima ECU modified for the Biki board? A free sample ECU to dissect?
__________________
Old 07-23-2009, 10:08 AM   #159
Kevlo911's Avatar
Problem with the 99 is that I believe they changed brands and that the insides are closer to an 00 than a 95-early97
__________________
I has car
Old 07-23-2009, 06:30 PM   #160
97 onwards do not have an expansion board socket... characterised by the 40 pin connecter on the board furthest from the ECU plug. The R33 Skyline ECU was also in the same situation, with no expansion socket although an R34 ECU with a different ECU supplier is chippable.
Engine, cams and new flywheel are due back from machining and balancing early next week. This forum helped in my decision to upgrade the oil pump if I am going to be spinning the engine hard Plenty of pictures to post once the engine is in the workshop and being re-assembled Even upload some videos now my video camera docking station is functional.
__________________
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
