my RPM's high??
Old 04-25-2008, 10:37 AM
flyby's Avatar
my RPM's high??
96 5 sp- So heres the deal about a week ago i had a rough idle due to a bank 3 misfireso i replaced the knock sensor (that sucked!), pvc valve, simply cleaned the spark plugs, sprayed down the maf with cnc and replaced the serpentine belt i recently noticed my rpms seem high? is 80 at about 3500 normal? btw My cel light is still on, but no rough idle and it seems to drive fine.
flyby is offline
Old 04-25-2008, 04:29 PM
MorpheusZero's Avatar
Originally Posted by flyby
So heres the deal about a week ago i had a rough idle due to a 3 bank misfireso i replaced the knock sensor (that sucked!), pvc valve, simply cleaned the spark plugs, sprayed down the maf with cnc and replaced the serpentine belt i recently noticed my rpms seem high? is 80 at about 3500 normal? btw My cel light is still on, but no rough idle and it seems to drive fine.
Yes, 80 at ~3300 is normal. Replacing engine parts is not going to change your gearing.
MorpheusZero is offline
Old 04-25-2008, 04:39 PM
njmaxseltd's Avatar
Umm, at 80 my tach reads just a bit over 2500.
njmaxseltd is offline
Old 04-25-2008, 04:51 PM
dot dot dot ...
NmexMAX's Avatar
My thoughts:
http://forums.maxima.org/showpost.ph...95&postcount=3
http://forums.maxima.org/showpost.ph...42&postcount=4
Unless your tranny is fried / slipping, I still stand by my above links.
NmexMAX is offline
Old 04-25-2008, 04:56 PM
Well clearly you need to be included in this discussion since your transmission is the only one offered in a 4th gen.
Old 04-25-2008, 04:59 PM
dot dot dot ...
NmexMAX's Avatar
4AT
NmexMAX is offline
Old 04-25-2008, 05:00 PM
Old 04-25-2008, 07:06 PM
njmaxseltd's Avatar
Originally Posted by NmexMAX
4AT
Common sense seems to be missing in the 4th gen section lately.
Thank you NmexMAX
Old 04-25-2008, 07:32 PM
Thank you NmexMAX
I don't get it. Was that really over your head or are you just playing along?
Old 04-25-2008, 11:04 PM
Snypa's Avatar
here we go
Snypa is offline
Old 04-26-2008, 01:07 AM
hot_wax_tree's Avatar
kph!!!
hot_wax_tree is offline
Old 04-26-2008, 07:18 AM
flyby's Avatar
btw im a 96 5speed and i was asking because before i did all that i remember my rpms being a tadbit lower but my car was running like **** for a while soO thanx for the input ........im reminded of a famous song sang by an elequent jackie chan and chris tucker and it goes a lil something like this.. . WAR ha what is it good for absolutely nothing say it AGAIN! VIVA LA
flyby is offline
Old 04-26-2008, 11:22 AM
dot dot dot ...
NmexMAX's Avatar
Moral of the story: 4AT = less RPM vs 5MT @ highway speeds,
NmexMAX is offline
Old 04-26-2008, 11:27 AM
Yes... we know that...
Old 04-26-2008, 11:32 AM
dot dot dot ...
NmexMAX's Avatar
So then
NmexMAX is offline
Old 04-26-2008, 09:20 PM
i has college
EnervinE's Avatar
Hey, just cause it's true doesn't mean Nissan was on crack when they picked the 5th gear ratio.
EnervinE is offline
Old 04-26-2008, 10:39 PM
No more Maximas...
pmohr's Avatar
So then
pmohr is offline
Old 04-27-2008, 09:50 AM
flyby's Avatar
eh- still driving 80 at 3200 in 5th gear...........
flyby is offline
Old 04-30-2008, 03:15 PM
tradical1's Avatar
I have an auto 4spd, and it drives at around 2850 at 80 MPH.
tradical1 is offline
Old 04-30-2008, 05:03 PM
We have been over this. Around 3300 is normal.
is going on here
HE IS 5 SPEED
AUTO PEOPLE STOP CHIMING IN WITH USELESS DRIVEL
Old 04-30-2008, 05:10 PM
tradical1's Avatar
is going on here
HE IS 5 SPEED
Chill out, dude! Everyone knows auto is different. I was surprised that there's 500 RPM difference - that seems like a lot to me.
BTW, I CAN WRITE IN CAPS, TOO
Old 04-30-2008, 05:20 PM
Plenty of auto tards are lackadaisically chiming in only saying what their top gear engine speed is at 80, implicitly suggesting that the OP's gearing is off. This makes the thread potentially confusing and really isn't constructive in the least.
Unfortunately it seems you lack the prerequisite of having something important to say...
Old 04-30-2008, 05:26 PM
dot dot dot ...
NmexMAX's Avatar
So he's a 5MT, what's the difference aside from a few RPM? It's still a mechanical relation so I still stand by my statement. The only amendment is that instead of the tranny slipping, we will say clutch slipping, other than that, it's the same, so what's the point of this thread?
NmexMAX is offline
Old 04-30-2008, 05:29 PM
The difference is about 500rpm, which is enormous. Your previous statement is obvious to anyone who understands how a transmission works and is absolutely correct.
Old 04-30-2008, 05:36 PM
dot dot dot ...
NmexMAX's Avatar
Of course, we can revisit the first days of the org, and say that This is one of the only vehicles where the EPA rated the 5MT LESS than the 4AT on highway MPG ZOMG, this is why.
NmexMAX is offline
Old 04-30-2008, 05:39 PM
I suppose... as long as we note that the 5MT has passing power in top gear and the VQ is smooth and robust enough that it could sit at 4k all day long and no one would notice..
tradical1's Avatar
There's a lot of slamming going on here, so I think I should clear something up...
A transmission type alone doesn't necessarily have a significant effect on the relationship between the engine RPMs and speed. What matters is final gear ratio.
Now that that is said, can't we all be friends?
Old 04-30-2008, 05:46 PM
What matters is the final drive + current gear ratio + torque converter slip + rolling diameter. What matters to the speedo is everything save the rolling diameter, which is programmed in as a constant.
We are aware of this man.
Old 04-30-2008, 07:30 PM
Coolsaber57's Avatar
Hmm....I'm an auto and mine drives at ~3000 at 80mph...
Does that mean something's wrong w/ my tranny? or...?
Coolsaber57 is offline
Old 04-30-2008, 07:33 PM
No more Maximas...
pmohr's Avatar
Mine is at ~6400 RPM at 80 MPH. Suggestions?
pmohr is offline
Old 04-30-2008, 07:47 PM
flyby's Avatar
im done thanx for the info guys
flyby is offline
Old 04-30-2008, 10:30 PM
modenaf1's Avatar
1.) It is your gearing, as nmexmax said, nothing will change. Unless you physically alter the gears in your transmission, you will always turn the same RPM at a given indicated speed.
2.) Automatic transmissions are commonly geared taller than manuals and that is why automatic maximas turn less RPM at the same speed as a manual. I don't know why they do that, considering a manual doesn't have the same parasitic losses as an automatic, meaning in theory you should be able to to run even taller gearing than the auto, but whatever. That would be sweet if we could turn like 2500RPM at 80. That would be wonderful gas mileage. Oh well.
Not in top gear you're not, if so thats some NASTY slippage goin on.
modenaf1 is offline
Old 04-30-2008, 11:17 PM
Few reasons:
1) Autos of the previous century typically have one or two less gears than a manual. If they had a shorter first gear than a manual then the gearing would be really far apart which would lead to even worse acceleration at speed.
2) Autos of said era tend to focus more on luxury where manuals focus more on performance. Turning over ~2500rpm on the freeway is considered a lot more luxurious than turning over ~3300. The manual is geared shorter because people driving a stick will generally be more tolerant of that sort of thing (partially for reason #3).
3) It's important to have a usable top gear in a manual, since people are lazy and don't want to downshift every time they have to pass someone. With an auto you just go into kickdown, the torque converter unlocks and the transmission downshifts seamlessly for you, so the cruising gear need not be as usable as with a manual.
4) You want to turn over 2500rpm at 80? Do a 6 speed swap.
yeah pmohr you're not joking or anything are you?
Old 05-01-2008, 04:16 AM
No more Maximas...
pmohr's Avatar
Not at all. Then again, that is in second gear...
pmohr is offline
Old 05-01-2008, 06:46 AM
Missing a few gears? My old honda reved at like 7000 at 20mph...
...in 1st gear.
Old 05-01-2008, 06:47 AM
dot dot dot ...
NmexMAX's Avatar
NmexMAX is offline
Old 01-18-2009, 06:26 PM
Bassbreaker's Avatar
with the overdrive on, my 95 auto can sit at 2500 going 80 no problem...seems normal to me....but my gas milage is still $hit...i do have an EGR Solenoid ECU code tho, maybe thats doing it to me...
Bassbreaker is offline
Unclejunebug
04-02-2016 05:42 AM
maxinout93
10-31-2015 02:04 AM
ef9
10-04-2015 08:43 AM
Need help
23
10-02-2015 08:56 AM
Quick Reply: my RPM's high??
