Accident side damage/steering broken(Pics)
Old 12-10-2007, 08:26 AM
crazy97's Avatar
I just had my first accident in 14 years..
My rear end spun(stock tires)at the bottom of a hill with a right turn to it, the car turned way to the right, I cranked the wheels like H to the left..at the same time I was skidding along the snowbank in the right lane...as soon as the car came down to the pavement...front tires grabbed hard(Blizzacks)and shot me to the left sideways across the road and the car behind me smacked me in the drivers side bouncing me head off the driverside door window and the car ended up in the median turned around backwords...I feel fine. Front door is bashed in, there's a small dent in rear door and the part that holds the mud flap is dented in. I was about 5 blocks from home and when I started driving home after the report was taken I soon realized that my steering was very unresponsive and after I pulled over, I could see my wheels were going in different directions ...so I had it towed home.
Sorry, the car is dirty as hell..roads have been nasty and it's 12 degrees out so I haven't washed it in a couple weeks. I'm waiting for a body shop to look at it that is a few blocks from me and they are going to come here since I can't drive it.
DONT EVER PUT SNOW TIRES JUST IN THE FRONT (
crazy97 is offline
Old 12-10-2007, 08:32 AM
wants an I35
ROCKART's Avatar
sorry to see that. gonna cost $$$$$ to fix.
i did a similar thing with my 93 in a blizzard, but i hit a fire hydrant instead of another car. was in the same spot tho, and the metal bolt from the hydrant gashed a huge hole in the door, all the way to the speaker area. was quoted 1300 dollars to fix just the panels. i ended up selling it a couple of months later for 500 bux.
ROCKART is offline
KRRZ350's Avatar
Awww man, I'm sorry but that looks like identical to the damage to my last parts car, which was a pretty clean ride but I deemed it totalled, to much $$ to fix and it definitly needed to go on the frame machine.
In addition to a broken control arm & tie-rod, the kick panel by your left foot is probably bashed in and the part of the unibody that the control arm mounts to is more than likely tweaked.
Basically, allthough I can't be positive without pics from underneath & with wheel off. If you want that fixed right it's probably going to cost more than the car is worth even using JY parts. Sorry man
KRRZ350 is offline
Old 12-10-2007, 01:06 PM
Snypa's Avatar
how is the drivers side door window? @ "bouncing me head off the driverside door window "
Snypa is offline
Old 12-10-2007, 01:10 PM
crazy97's Avatar
Glass is fine, the window only goes down half way though.
The car has full coverage... But I don't know what they will fix on something older like this.
crazy97 is offline
Old 12-10-2007, 01:16 PM
4th Gen Parts King
Maxima_Joe's Avatar
Steering is probably a bent control arm and tie rod. If you need a front door PM me.
Maxima_Joe is offline
Old 12-10-2007, 01:21 PM
boost me.....
96blackmaxSE's Avatar
Man, sorry to hear that. I just rear-ended some lexus-drivin' attorney last week....bad news.
It seems as though everyone is wrecking their cars now....
At least you didnt hit any other cars/people and you didnt get ****ed up in the wreck....I'd say you're pretty luckly. On the other hand, I hate to say it but your car is most likely totataled...it looks like your frame is definately bent in addition to your tie rods, LCA, wheel hub/bearing, strut, steering assembly if your wheels are going differen directions typically thats not a good sign...
96blackmaxSE is offline
Old 12-10-2007, 01:36 PM
crazy97's Avatar
Thanks man.. I'll definitely keep that in mind.
Thanks, I'm definitely lucky not to be messed up...My wheels aren't bent at all...They just turn differently, one is connected to the steering and the other is not. I havent looked under there yet.
crazy97 is offline
Old 12-10-2007, 02:27 PM
RNMMax's Avatar
sorry about the car. agree it's probably totaled.
RNMMax is offline
Old 12-11-2007, 03:07 PM
crazy97's Avatar
I found both tie rods are connected but one is bent causing one wheel to be going left and the other going right. I don't see any frame/unibody damage or even control arm damage luckily. I'll have to replace my tie rod and bring it somewhere good, the shop that I talked to yesterday forgot about me...
Tie rod bent
Actually the control arm looks bent in the picture...
crazy97 is offline
Old 12-11-2007, 03:40 PM
vqmaxman's Avatar
The car should not be totaled. The car is turning in different directions is because the lower arm and the hub are disconnected. I would consider some more pics. The only way the car can be totalled is cause the frame is twisted and deepending on the accident. The pics are not enough to discribe the problem. The hub is probally shot.
vqmaxman is offline
Old 12-11-2007, 05:42 PM
Peebs187's Avatar
96blackmaxSE Man, sorry to hear that. I just rear-ended some lexus-drivin' attorney last week....bad news.
Just slid through an intersection at an off ramp. A nice steady 5 mph slide. I'll post pics in the next couple days. Not sure what i'll be doing with it yet.
Peebs187 is offline
Old 12-11-2007, 05:59 PM
4th Gen Parts King
Maxima_Joe's Avatar
If you need some parts pm me. Or if you want to get rid of it i would be interested as well.
MN weather sucks.
Old 12-11-2007, 06:10 PM
boost me.....
wow...I thoughtIt would be worse but those pics dont look as bad as I thought...that door will still cost a pretty penny. A shop quoted me 950.00 for a new drivers side door skin put on and painted...good luck
Old 12-11-2007, 06:14 PM
4th Gen Parts King
Maxima_Joe's Avatar
Well hes getting a good deal then. I live about 240 miles from him and will deliver a pearl white door to him for $150
Old 12-11-2007, 06:32 PM
boost me.....
Yeah, no doubt. Deliever me a black one.
Unfortunately I also I go to an expensive body shop tho... so they always try to shaft me I usually get them down by a couple 100s since the guy likes my car, Ive brought him over 5K in business. muahahaha
Old 12-12-2007, 04:27 AM
wirelessdude04's Avatar
dam thats pretty bad man. Glad your ok though
wirelessdude04 is offline
Old 12-12-2007, 06:28 AM
KRRZ350's Avatar
Originally Posted by crazy97
Tie rod bent
Again, that looks identical to the damage on my last parts car, I'm sure that lca is damaged, as well as the kick panel area and probably the rear mounting point for the lca. Look very closely at that rear bushing for the lca to see if anything is tweeked.
KRRZ350 is offline
Old 12-12-2007, 07:29 AM
Snypa's Avatar
i think you should have an easy fix....shudnt need to be totalled at all, unless there are things you DONT know of.
Snypa is offline
Old 12-12-2007, 10:45 AM
MaxFanatik's Avatar
i ahd the same type of dmg i had to get a new innner and outer tie rod and thats it and an alignment.
MaxFanatik is offline
Old 12-12-2007, 11:07 AM
What's next!?..
JPMax's Avatar
Doesn't look too bad. fanatic is in your state and has plenty of parts cars lying around. I'd get a list of parts needed and contact him. Probably lookin at around $500-1000 for parts and labor. Maybe less.
JPMax is offline
Old 12-13-2007, 11:49 PM
4th Gen Parts King
Maxima_Joe's Avatar
http://www.cardomain.com/ride/348507/13
Old 12-16-2007, 07:19 PM
crazy97's Avatar
Update:
Fanaticrockford came over last night with the two doors and even installed them! The doors he brought are in great shape, there's some gooey stuff on the edges and a little smudge of dirt here and there that you can see in the pictures that will clean up easily. I also picked up a fender at a place near me and that went on too, the fender had some scapes on it but it will do for now. One problem that came up was with the drivers door, it wouldn't shut right no matter what we did. Looks like the area where the hinge bolts up to was pushed in enough to throw things off. A trip to a bodyshop will be nessesarry for that.
I might only need a tie rod now, the control arm looks bent in the picture but not up close..go figure.
Special thanks goes to Fanaticrockford for the huge help he was!
crazy97 is offline
Old 12-16-2007, 07:37 PM
maxx0831's Avatar
wow congrats, looks great and u saved ya self a whole lot of money
maxx0831 is offline
Old 12-16-2007, 10:40 PM
Snypa's Avatar
great job fanatic, you saved a life or two.
Snypa is offline
Old 12-16-2007, 10:55 PM
member
slow97maxima's Avatar
looks 1000 times better
slow97maxima is offline
neilraz
09-11-2015 07:36 PM
maximusrising
09-02-2015 09:55 AM
A32goldylocks
09-02-2015 06:39 AM
Quick Reply: Accident side damage/steering broken(Pics)
