Whose got the highest mileage?? Any issues?
Old 05-27-2010, 11:38 PM
  #321
stamar's Avatar
Originally Posted by maxima278
My wife has a 96 GXE, or GLE, I'm really not sure. We bought it for $650 right after we sold her 2003 I35 to get rid of car payments. It had 293k, at least 2 bad coilpacks, quarter tank of bad gas, custom seats and interior that were destroyed, bald tires, core support damage, suspension bushings and struts that were almost nonexistent. The owners pulled it out of their garage after 3 years of sitting and were going to crush it if no one bought it over a weekend.
I've spent almost a grand on it by now, and it rides like new with all new struts, front end bushings, balljoints, a good rack I pulled from another car, some almost new tires, and an alignment. I also did a little core support straightening via dodge ram truck and tow strap, installed a set of seats I bought off craigslist for cheap, cleaned the headliner, replaced the dash vents, power antenna (then promptly ripped it off on a treelimb), and did a LOT of cleaning.
It's now a polished turd with 297k and running strong. Still needs a little more straightening up front, a flex pipe and a few leaks fixed, but you would be amazed if you saw it before and after.
Other maximas:
95 5 speed black/ black- 105k to 155k (current owner has around 225k)
90 black on black 5 speed- 186k at sale
95 GLE, 193k, bought with blown hg.. fixed and sold
89 GXE, 244k at sale- mint condition car
90 SE 5 speed- 222k- owned for a week
97 black on black 5 speed- 193k, currently under construction
i bought my 98 i30 for $50
ive replaced the starter and the alternator, and all the fluids, paid some registration and smog
about 700$ out the door. It runs perfectly 198k miles now.
suspension, paint interior pretty much everything was all up to date. I dont have any records for the car but most everything is up to date. I see napa on the cv joints so they were replaced, all the brake pads look 90%
front shocks are oem but function fine so I dont know if they have 197k miles on them they might
back are tokico blue so they are newer, much stiffer too
it does have the famous knock sensor code.
oh the engine was a factory replacement at 140k miles... when i took the filter out it said k n .... almost everything about this car is a gem... basically stock. rear seat looks completely unused.
stamar is offline
Old 05-28-2010, 09:04 AM
  #322
Lizziebeth13's Avatar
'95 GLE Automatic (ugh) w/ 213,429.
Bought in 2002 when someone killed (front end smashed) my beloved '90 240sx. Off the top of my head, have had to replace CV joints, ignition coil, water pump 2x, starter...all I can remember without my file folder. Car looking a little ragged because of a tire blowout I had last year on the interstate...huge dent in lower 1/4 panel, smaller dents in the door, ripped the door handle off, pockmarked the paint. Think I'm having ignition coil problems again, too;lots of engine stuttering, sometimes doesn't want to start. Wish I had the extra funds to make it right! Got spoiled by my 240.
Lizziebeth13 is offline
Old 06-09-2010, 09:54 PM
  #323
bm.murdoch's Avatar
97 w/ 194k My parents bought it in 99 with 12k on it! i started driving it with roughly 106k.
I have had quite a bit, but i still love the car. Replaced O2 sensors twice, coil pack on cyl 3, a couple of clutchs, front rotors, your regular tune up stuff, some smaller little things, and she's starting to burn oil a bit... lets hope that doesnt get too bad!
bm.murdoch is offline
Old 06-25-2010, 03:22 AM
  #324
kap
kap's Avatar
96 se w/ 254k
my radiator was broken, then fixed.
if i park my car in a hot area for a long time, it takes about 10 min till i can start it. might be the starter.
other than that, it still runs smooth.
kap is offline
Old 06-25-2010, 06:34 AM
  #325
ElectricalBen's Avatar
287,000 miles... Valve cover gaskets replaced, Just the other day have a small oil leak, only engine problems
Replaced:
Drivers radiator fan
All struts
All new bushings, es poly ones front and back,
Es engine mounts my stock ones were almost completly gone
all new brakes and rotors
2 new calpiers in the back
new e brake cable to drivers side rear
new axles in the front
new sway bar end links
new tire rods
cleaned egr, throttle body and everything else around
had to fix the exhaust multiple times
and a few others... basically a new car except this oil leak haha hope it works out I really like this car
it needs a starter relay in the heat its a challenge to get started have to keep turning the key
ElectricalBen is offline
Old 08-10-2010, 10:01 PM
  #326
worldspeaker's Avatar
248,000 miles with no major issues. Has an oil leak in the valve covers but that is pretty much it.
worldspeaker is offline
Old 08-10-2010, 11:02 PM
  #327
najee1062's Avatar
99 GLE 120k
Done:
KYB G2 front and rear
rebuild rear calipers
rear and front rotors
rear brake hardware kit replaced
coil pack (6)
Battery
(1) radiator fan motor replaced
Needs:
LCA
Sway bar links
tie rods
motor mounts rear and maybe front
clean egr tube and maf sensor
pvc valve
engine degrease
najee1062 is offline
Old 08-10-2010, 11:11 PM
  #328
5150pa's Avatar
157k
Axles, rotors, struts, suspension, brakes, wheels (goddamn salty winters)
New starter
New battery
New plugs
Not too bad.
5150pa is offline
Old 08-15-2010, 10:10 AM
  #329
mikeg75's Avatar
169,000 miles
- front O2 sensor replaced by prev. owner under warranty
- crankshaft position sensor
- oil pressure sending unit
- water pump @ 155,000 miles
- EGR solenoid @ 164,000 miles
- Engine coolant temp. sensor @ 164,000
- Windshield replaced (pockmarked to death)
- Exhaust from cat-back just replaced with after market parts
To be fixed / replaced
- Rear O2 sensor just came up after replacing exhaust
- Valve cover gaskets and intake gaskets
- Small clunking noise coming from front on/off don't know from where yet
Took the car from Phila to NC last summer and plan to take it to New Hampshire in a couple weeks. Rides great but gas mileage is down to 15-18 mpg. Love this car and still wash/wax it by hand.
mikeg75 is offline
Old 08-16-2010, 02:43 PM
  #330
FreeMax's Avatar
97 SE auto. @ 148K. Starter, belts, O2 sensor, right front bearing, front breaks. Need to fix some leaks and replace the plugs. Can't complain though. The car was free.
FreeMax is offline
Old 08-24-2010, 01:24 AM
  #331
ugufru's Avatar
1995 SE 167K miles! Running well, except problems starting in cold weather. Haven't sorted that out yet, but getting a 1005 code. Cleaning out the EGR tube soon. Water pump and radiator replaced at 150K. Just did the brakes for the 2nd time (replaced left rear caliper). Had to have the front motor mount/radiator support bar welded last year. Never wrecked, but it's got a few scrapes (my bad). Can't see why it won't keep going now that I'm learning how to fix everything that goes wrong. Gonna need new valve cover seals, and possibly a new timing chain, but the thing still drives smooth and revs all the way up to redline. Love this car!
ugufru is offline
Old 08-24-2010, 04:29 PM
  #332
N3SQV's Avatar
98 177,000
D/S differential bearing
P/S Lower Ball Joint
Blower resistor
MAF
N3SQV is offline
Old 08-24-2010, 04:44 PM
  #333
ColombianMax's Avatar
Havent updated in a while but I'm a couple miles short of 337,000, no major problems other than routine maintenance.
ColombianMax is offline
Old 08-28-2010, 09:19 AM
  #334
19GLE97's Avatar
wow u guys got alot of miles, mines a baby at only 117,000 but it has no issues whatsoever(fingers crossed)
19GLE97 is offline
Old 08-28-2010, 09:56 AM
  #335
mas324's Avatar
212K
Problems: Coils packs and an oil leak (minor)
mas324 is offline
Old 08-28-2010, 11:17 AM
  #336
sbreeeezy's Avatar
Wow, i look at the posts on here and i thought i had a lot. 116k on a 98' guess not lol.
sbreeeezy is offline
Old 08-28-2010, 11:23 AM
  #337
exsjulio's Avatar
235K, track racing it!! pushing the motor hard!
exsjulio is offline
Old 08-30-2010, 04:52 AM
  #338
myblzurchn's Avatar
I'm over 223K, I've only had it for 2500K and I have to replace the carrier bearings in my 5 speed. So I swapped over to a VLSD 5 speen instead.
myblzurchn is offline
Old 08-30-2010, 06:07 PM
  #339
96MaXiclean's Avatar
239,421 k 96' auto. Runs like it just came off the showroom floor, no lie, its a 4/96' build, so i think i got lucky.
96MaXiclean is offline
Old 08-30-2010, 10:39 PM
  #340
tvrds's Avatar
98 black se manual - been in the family since we bought it in 99
187k miles
clutch replaced once
suspension in process of being completely redone
-changed all 4 shocks - illumina rear gr2 front for now
-tokico/custom maxima lowering springs
-sway bar bushings/endlinks
-about to replace all control arm bushings and ball joint (ES and moog)
-evap canister in the back is busted and throwing a CEL but i really can't be bothered - valve nuts are spinning inside the canister, dumbest design ever
-knock sensor needs to be replaced
-inner tie rod boot is torn - need to change it soon but not really in a hurry (see other imminent repairs)
the car sat on the driveway for 1 1/2 years. when i started it back up it made a nasty lifter/ticking noise, changed the oil and noise has quieted but is still there. could be nothing, could be timing chain tensioner but i'm not sure yet.
going to autorx the engine and tranny soon to clean out the engine and hopefully seal up a very slow tranny leak (not differential bearing)
original axles are still fine, not even a torn boot.
I've put $700 in parts into getting the car back up and running including the full suspension parts, o2 sensors, battery, spark plugs, tires, fuel filter and miscellaneous other parts like spoiler hardware. I'd say that's pretty damn good considering how much usage my family's gotten out of it.
tvrds is offline
Old 09-04-2010, 09:13 AM
  #341
04SL's Avatar
04 with 199k so far no issues except struts
04SL is offline
Old 09-04-2010, 09:56 AM
  #342
Bobo's Avatar
This thread is in the 4th Gen Forum. It strikes me that 4th Gen owners in excess of 300,000 miles only need respond.
For what its worth, I have 84,107 mostly highway miles on my one-owner 95SE 5-speed.
Bobo is offline
Old 09-04-2010, 05:20 PM
  #343
Trini Boom's Avatar
That is great man...I wish I had one with that kind of mileage..
Trini Boom is offline
Old 09-05-2010, 06:15 PM
  #344
MAXIMA_STYLE's Avatar
i got a 96 Se QN0 5MT with 208k on her and runs STRONG only issues i have is i need radiator support replaced, a new clutch and what appears i have a gear oil leak on the casing that looks like someone had the tranny apart at one point and didnt seal it properly so ill do that when i do the clutch, aside from that the only "major" thing is my ebrake doesnt work due to a missing cable somewhere which i havent found the time to check
MAXIMA_STYLE is offline
Old 09-23-2010, 05:43 PM
  #345
blocster's Avatar
98 Max 5spd 190K mi. Both left side Wheel bearings, Knock sensor, Map sensor, Tranny rebuilt twice due to leak out of driver side axle, struts, starter X2, alternator X3
blocster is offline
Old 09-23-2010, 07:14 PM
  #346
illmortal's Avatar
I'm currently @ 228k
The current problem I have is suspension. I assume it's due to the fact that the previous owner lived in New York city and those roads are horrifying. I received my I30 back when it had 159k miles on it, by the time it hit about 180k miles, that's when the front suspension went out, and I must say, it is NOT wise to drive around with bad front shocks + weak springs.
Right after replacing the front shocks and springs (OEM) the rear suspension went out not even a month later. I still haven't gotten around to replace it due to a lot of traveling (business). And currently, the suspension is just nuts... huge body roll on turns, the car bounces really hard and repetitive when I drive over speed humps.
I believe it was 10k miles later that my hood shocks finally gave out. Woke up one morning to clean the engine bay with some degreaser + pressure washer, popped my hood open, lifted, and right as I let go, the hood dropped shut. So the shocks had enough strength to hold it for almost 3 seconds until they gave out.
A/C Compressor died @ about 200k miles.... and that took me a while to replace, which was horrible living in Florida with no A/C during the summer + humidity.
My starter also started to go @ around 215k miles but thanks to this forum I learned how to replace it.
My valve cover gaskets started to leak @ 225k and just recently had that replaced + fuel filter, this time around I got a 96 300ZX fuel filter.
Due to New York + Florida (living by the beach) part of my muffler has nasty rust spots, but hasn't been "falling apart", just a lot of rust... as well as my exhaust piping.
And finally I have a CEL, which at first it showed MAF sensor, Crank position sensor, and a few oxygen/heater sensors, but after replacing the valve cover + fuel filter and resetting my ECU, it came down to just MAF sensor, but then I reset it again after cleaning it with a can of MAF cleaner + throttle body cleaner, and now I got the CEL again... but I haven't checked codes yet. I'm going to wait for Friday maybe Saturday to check on my CEL due to a lot of raining out here in Northern Oregon. Supposedly it'll be sunny and dry over the weekend.
Just as a note though, I remember getting the CEL for MAF sensor (which at the time, I remember seeing them for around $400+, so couldn't replace it) after replacing my OEM air intake system with a pop-charger intake, but it was after almost 50 miles of driving that day.
I think I should have reset the ECU after installing it because it might have been giving me a "false positive", in other words, nothing is really wrong other than maybe the MAF got confused from the replacement of OEM to aftermarket? Not sure... =\
So all in all I'm just left with replacing the suspension (this time I'll re-do the front as well but going aftermarket with H&R springs, since it's sporty + best comfort compared to others) The shocks I still have to research... I wish KYB AGX wasn't so expensive since supposedly those are really good for not just spirited driving but also everyday driving.
And after I check codes on CEL, whatever it is, I'll replace that as well.
Other than that... my baby is still going strong. Right now I'm checking on gas mileage which kinda sucks because I still have the tendency to push her hard. Where I live there's a lot of farm vehicles and semi-trucks that go slow as ***** and plus I don't like driving behind vehicles that prevent me from seeing ahead of them (semi-trucks being one of them). So I believe I'm not gonna get an accurate reading on MPG.
illmortal is offline
Old 09-24-2010, 03:47 PM
  #347
redcoat's Avatar
1995 Maxima. No major problems...apart from front passenger door lock, which I'm still trying to fix!
redcoat is offline
Old 09-24-2010, 07:42 PM
  #348
Phromethius's Avatar
'96 SE 193k Lower control arms, CV joints, MAF sensor replaced due to drop in KN filter of course. O2 sensors were replaced by Dealer as I bought it, SUPER long story there. Other than that runs like a charm. oil leaks out of a gasket from time to time but its also a 14 year old daily driver which I've owned for 9 of those years.
Phromethius is offline
Old 09-24-2010, 07:45 PM
  #349
oh by the way! my driver door lock just freaked out on me too, breaking down the door panel tomorrow. It sunk into the panel and I heard a screw drop.
Old 09-25-2010, 01:52 AM
  #350
Prophecy421's Avatar
96 5 speed
185,000 Has an oil leak
Needs:
Radiator, Clutch slave cylinder, hood struts
Done:
Coilpacks, Waterpump, RS windowmotor/regulator
Prophecy421 is offline
Old 09-25-2010, 01:13 PM
  #351
xProdiigY's Avatar
230,XXX miles with out any problems.. lucky? I think so.
xProdiigY is offline
Old 09-29-2010, 05:21 PM
  #352
jameskenney's Avatar
180k both rear brake calipers
both rear rotors
both cv axles
a/c compresser, air dryer, exp valve
ignition switch (electrical half)
fuel level sending unit (cracked when i bought it)
fuel pump (might as well while i was in there)
thats all so far (knock on wood)
jameskenney is offline
Old 09-30-2010, 02:25 PM
  #353
soto2635's Avatar
120,000
coil packs
serpatine belts
thats it
soto2635 is offline
Old 10-02-2010, 01:26 PM
  #354
NeptuneMan's Avatar
98 GLE.
164,182 miles.
Driver / Passenger front struts.
Radiator fan motor.
Spoiler brake light.
Existing:
Transmission fluid leak, unknown cause. =(
NeptuneMan is offline
Old 10-02-2010, 05:25 PM
  #355
Cams's Avatar
Got my 97 new and it has 205xxx on it now. I have done...
Alternator
Starter
P/S front wheel bearing
Ignition switch
Radiator core support
Sun roof as a complete assy.
And last but not least "the oil leak."
Thank goodness I am ASE certified and turn wrenches for a living. Fixing that oil leak sucked and I have a whole shop at my fingertips.
Cams is offline
Old 10-04-2010, 10:06 AM
  #356
BlackMamba's Avatar
bought it with 80k, 182k
alternator
starter
both axles
struts
water pump
o2 primary ( havent fixed)
one coil
valve cover seal
clutch/bearing AC compressor ( havent fixed it)
motor mount
leaking fluid of clutch ( havent fixed it)
BlackMamba is offline
Old 10-04-2010, 01:23 PM
  #357
96 SE JET's Avatar
97 se 198,xxx rear struts, knock sensor, and egr needs to be cleaned have parts need to get work done.
96 SE JET is offline
Old 10-05-2010, 10:49 AM
  #358
nperry519's Avatar
96 SE
Just bought it a week ago 262K runs nice at hight speed but so far the only issue I am having is:
That real hard shifting mainly from 1st to 2nd
And you can really feel bumps on riding through the city
nperry519 is offline
Old 10-05-2010, 10:04 PM
  #359
bradenman1's Avatar
99 5spd se 234k on it needs a clutch and power steering replacement and needs valve cover gasket i believe, im getting some kind of oil leak either trans, motor oil, or PS fluid probably all of them the car has been driven pretty hard haha
still drives well ohh and cvs and o2 sensor replaced and now needs another reading high voltage??
bradenman1 is offline
Old 10-13-2010, 09:37 AM
  #360
MystiWink's Avatar
I have a 1996 SE with 297K miles OEM Engine and Trans, only replaced the clutch and some other minor repairs.
MystiWink is offline
Quick Reply: Whose got the highest mileage?? Any issues?
