Go Back   Maxima Forums > Maxima Discussions > 4th Generation Maxima (1995-1999)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 11-22-2007, 11:15 PM   #1
Hesitation while accelerating
My girlfriends 96 Maxima (auto trans/140k) -
Has a hesitation while accelerating probably once a day.
It almost feels like a transmission issue, because power drops for a second, than kicks back in like its kicking back into gear...although it wouldnt surprise me if it was a sensor issue.
Happens both on the highway, and city driving.
Most commonly between 2nd and 3rd gears.
I've checked the ECU for stored codes hoping that I'd find something to narrow the search but came up with none. Was thinking possibly a MAF, or Knock Sensor. She did have one about 5months ago regarding the EGR, but the code was reset and never came back. I havent pulled it to clean it yet, because it looks like a major PITA.
Plugs are only about 15k old, and the fuel filter was done about 10k ago.
I've cleaned the MAF this evening in hopes it'll make a difference.
Any other suggestions?
JoshBarber is offline   Reply With Quote
Old 11-23-2007, 09:19 AM   #2
no pointers?
Old 11-23-2007, 10:41 AM   #3
Send a message via AIM to 99maxk2
coils?
-pull them out and take a look at them
__________________
99maxk2 is offline   Reply With Quote
Old 11-23-2007, 11:37 AM   #4
Send a message via AIM to kzoosho Send a message via MSN to kzoosho Send a message via Yahoo to kzoosho
SO you havent puled codes lately?
__________________
97 SE Auto Built Auto
97 SE Holset HX52|N2O|6 SP|Built 3.56|More to come
91 GXE Auto bone stock beater
91 GXE 5sp Another beater
Led retro's Pm me
kzoosho is offline   Reply With Quote
Old 11-23-2007, 12:05 PM   #5
I know plugs only have 15K, but If you can't find any other cause you may try changing them. Only $15 for a set of quality copper plugs and about an hour of work. Sometimes you just have to eliminate all the possible causes one at a time to solve the problem. When in doubt try the easy cheap stuff first.
It's probably the plugs misfiring or an injector/fuel problem with many possible causes.
Nopike is offline   Reply With Quote
Old 11-23-2007, 12:09 PM   #6
- I pulled the coils. Is it common for them to intermittently act up?
How can you test them? I noticed one looked more brown compared to the other 5.
- I did pull codes from the ECU manually. It came back 0505 so no stored codes.
- where are you seeing sets of plugs for $15? You mean $15 EACH?
Old 11-23-2007, 12:23 PM   #7
Installed high quality NGK (NGK 6953) copper blugs in my 98 Max SE, total for six with tax $12.33. $1.89 each. One hour job - tops worth a try.
Old 11-23-2007, 12:28 PM   #8
Copper plugs are only supposed to last like only 30K miles compared to platinum 60k or more, but as easy as plugs are to change in a Maxima, who cares. Some people prefer copper.
Old 11-23-2007, 12:34 PM   #9
never seen them anywhere near that cheap -
it's not the plugs anyway. it did it before and after replacement
Old 11-23-2007, 12:57 PM   #10
OK then it's not the plugs, trust me on the prices of copper plugs as opposed to platinum or other metals. As far as checking coils you would need an ohmmeter and know how to use it. FSM says Check resistance between pin 1&2 if not zero ohms (shorted) then coil is OK. I would compare readings between several coils they should all be fairly similar. Anyway if you have faulty coil you should throw a code saying which cylinder is misfiring. If that happens then you can swap coils and see if trouble moves to another cylinder. With no code this does not work.
Old 11-23-2007, 01:04 PM   #11
As far as fuel injectors go FSM says listen to each one while the car is idling. Place a wood stick or other suitable device on the injector so you can hear it. You should hear a clicking noise. All injectors should sound about the same if not I would suspect that injector. These intermittent problems are difficult to repair. If you are having this problem despite changing plugs and fuel filter I guess coils and injectors are the next place to look. Maybe you have a clogged injector have you tried a good cleaner?
Old 11-23-2007, 01:09 PM   #12
FSM also suggests checking ECU connections including grounds when having intermittent problems. If it was my car I would pull the connectors from the ECU and plug them back in just to make sure I have good contacts.
Old 11-23-2007, 01:13 PM   #13
I could be wrong but I don't think it's a transmission issue, more likley a misfire or injector.
Old 11-23-2007, 03:07 PM   #14
khantalha+'s Avatar
Send a message via MSN to khantalha+ Send a message via Yahoo to khantalha+
my 96 auto did that to me couple times found out it was a faulty TPS sensor...
__________________
95 SE (VQ35DE EATER) - 96 GXE (Weekend Fun) - 98 GXE (Daily Driver/Grocery Getter) = sold
Quote:
Originally Posted by irish44j View Post
khantalha, in case you didn't see my other post - your signature is not appropriate for this forum and needs to be deleted. Please take care of it...
Lots of NEW/USED 4th Gen Parts , Click here, if dont see what ur looking for then PM me...
khantalha+ is offline   Reply With Quote
Old 11-23-2007, 03:24 PM   #15
JoshBarber, you're experiencing EXACTLY what i just fixed. It feels like you car goes, looses power (stutters almost) then quicks in vtec, haha.
-NOOOO, it is not normal for the coil to be brown. I had a misfire in cylinder 5 and when i was replacing the coils... guess what... cylinder 5's coil back was brown.
-your cheapest option is to replace that particular coil pack and see what it does after that. I took the expensive route and replaced all of them, but do what you want.
-any other problems could be a bad injector or manifold needing re-done... $$$ tho. trust me, start with the coils.
__________________
Old 11-23-2007, 03:25 PM   #16
o yea... and i was throwing the 0505 code also
__________________
Old 11-23-2007, 05:11 PM   #17
Quote:
very valuable info! thanks a bunch. I'll pull that coil again tomorrow and take a look. its very surprising that it never threw a code though.
how much can you get a single coil for? maybe I'll try to find on at the junkyard to give it a shot.
Old 11-23-2007, 05:15 PM   #18
how did you know you had a misfire in cyllinder 5 without a code?
Old 11-23-2007, 05:44 PM   #19
it threw that code before it actually threw the misfire code. the misfire code threw when it got REALLY bad, like the car would barely go down the street. nissan told me thats what it threw. sorry for that confusion.
I work at a shop and got the coil at price, which is 45 bucks i think. if you don't know anybody that can get parts for cheap, then itll be about 100 bucks a coil. like i said, if your not looking to spend much money, start with replacing the bad coil and go from there.
__________________
Old 11-24-2007, 10:08 AM   #20
BTW - this hesitation she claims happens at 2k rpms, and will not happen if she turns the OVERDRIVE off....only happens with the overdrive on. Does this info point to anything in particular?
Old 11-24-2007, 10:36 AM   #21
ehh, mine was finicky. it started about a year and a half ago and wasn't bad at all. It just recently started getting really bad and that's when I started paying more attention to it. Mine never did it depending on what was done, it just did it when ever it decided too.
I know that when i was at lights it would do the hesitation and jump RPMs, but if i put my car in neutral, it wouldn't do it.
If your problem is persistent and you are positive it will do it, get a coil and replace that brown one, then see what you have. I am almost 90% sure that is giving you a problem.
Do you have an local friends willing to lend you a coil for a few hours?
__________________
Old 11-24-2007, 10:42 AM   #22
does this look like signs of a misfire?
Old 11-24-2007, 11:35 AM   #23
That's exactly what mine looked like. I wish i still had it, but I chucked it.
Just curious, which cylinder is that coming from?
__________________
Old 11-24-2007, 01:50 PM   #24
I tried a different coil pack from the junkyard and same deal. No change.
The plugs are good so Im not sure why that one was burnt looking unless its been that way since before she bought it.
It's the front pack, on the passenger side.
Old 11-24-2007, 02:42 PM   #25
Quote:
what exactly did it do when it turned out to be your TPS?
and did you get a code for it?
Old 11-24-2007, 04:49 PM   #26
Most of things mentioned will pop a code,MAF alot of times will not.
I would shoot for TPS sensor.
Or just find a friend that works at a Nissan dealership and run it on their Consult.
If you live near East TN i would check it for free.
I get in trouble for that alot at work unfortunatly
Afterlife is offline   Reply With Quote
Old 11-24-2007, 05:53 PM   #27
Do EGR clogs or problems usually (or ever) cause hesitations?
Old 11-25-2007, 08:11 AM   #28
Yes they can have you cleaned you EGR tube lately?
It's usually more like a small jerk when they clog though,but you can feel it.
Should have a light on if it's the EGR though.
__________________
Old 11-25-2007, 09:10 AM   #29
she had a code for it before, but it was about a year ago and never came back on after it was cleared. it looks like a misery to remove so I just ignored it
Old 11-25-2007, 09:42 AM   #30
The tube itself isn't too hard to remove,cleaning it out is the biggest pain.
__________________
Old 11-25-2007, 10:35 AM   #31
I agree! Took me some time to clear it. I replaced the injectors and the knock sensor at the same time, not sure which made the most difference, but runs much better.
__________________
2008 Maxima SL 13000 miles.
1996 Maxima SE 200,000 + miles
Automatic (rebuilt 124K), new injectors and knock sensor 180K. Warpspeed Y pipe and magnaflow cat.
Bose HU from 06 Pathfinder. Tokiko blues at 201.9K.
Tow Vehicle: 2003 2500HD 6.6 Duramax Diesel baby!
sparky1562 is offline   Reply With Quote
Old 11-26-2007, 03:24 PM   #32
hey guys dont mean you jack your thread or anything but i have a 96 maxima(134k) with something similar i thought it was due to my clutch because it felt like a slip
but when the car is in neutral and i step on the gas between idle and 2500 it feels like a bad miss. No lights are on in the car just changed the plugs to bosch platinum +2 plugs i dont really know to much about this car since i just got it but any help would be appreciated
SFox420 is offline   Reply With Quote
Old 11-26-2007, 06:41 PM   #33
Ditto....TPS is bad or out of adjustment. Test yours with the procedure in the FSM and replace it if bad. Make sure to adjust the new one, or you'll have issues with the transmission shifting.
__________________
GoldMax
'97SE plus Courtesy FSTB, Stillen RSB, Stillen cross-drilled rotors, Porterfields, Hella autobahn horns.
goldmax is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
