Go Back   Maxima Forums > Maxima Discussions > 4th Generation Maxima (1995-1999)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Timeslips Members Parts Guide Search Today's Posts Mark Forums Read ExperienceVendorsUsed CarsGarage TSB & Recalls
Search
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Search this Thread Display Modes
Old 11-18-2007, 07:10 PM   #1
Points: 9,407, Level: 65
Points: 9,407, Level: 65 Points: 9,407, Level: 65 Points: 9,407, Level: 65
Activity: 0.7%
Activity: 0.7% Activity: 0.7% Activity: 0.7%
Send a message via AIM to 96i30azn
Do not overfill brake resevoir!!!
So I finally went around to replacing my brake pads and rotors (PBR Ultimates). And when I got around to compressing the caliper on the FL wheel, Some brake fluid started dripping on the control arm. I was "oh ****, wtf did i pop?" I have read articles about how if you don't open the bleed screw, you may damage some ABS component but I've done this before and nothing ever went wrong. Then I realized the location was right at the reservoir and that my uncle, who likes to play it safe, always tops off fluids. Sure enough, when I opened the hood, the reservoir was overflowing. So I sucked the juice out with a syringe and wiped the dot3 off with alcohol and later rinsed the darn thing with water.
Moral of story - leave the fluids alone.
__________________
Infiniti Q45
96i30azn is offline   Reply With Quote
Old 11-18-2007, 07:20 PM   #2
Points: 3,356, Level: 36
Points: 3,356, Level: 36 Points: 3,356, Level: 36 Points: 3,356, Level: 36
Activity: 0.8%
Activity: 0.8% Activity: 0.8% Activity: 0.8%
Actually, there is nothing wrong with topping off fluid levels. A better moral to your story would be to make sure there is enough room in the brake fluid master cylinder reservoir before compressing any caliper piston.
This is a common mistake - usually made once (at least) by those of us who have done many brake jobs over the years. After a while, you just learn to check the fluid level first before pushing those caliper pistons back in.
nafddur is offline   Reply With Quote
Old 11-18-2007, 07:50 PM   #3
i has college
EnervinE's Avatar
Points: 6,948, Level: 54
Points: 6,948, Level: 54 Points: 6,948, Level: 54 Points: 6,948, Level: 54
Activity: 0%
Activity: 0% Activity: 0% Activity: 0%
Yup. My brake fluid level was about a centimeter below the MAX line before I changed my front pads, and at the point of compressing the 2nd piston (1st pad already installed = thicker pad = more fluid in reservoir), the fluid level was almost overflowing. Had to siphon some out afterwards.
__________________
: Illuminas : Progress : Muranos : 5spd swap : MEVI : NWP Spacers : Budget SS Y : Full SS catback :
I30 Auto-Dim Mirror & Armrest : Maglite Mod : AE Headlights : Red/Clears : 35% Tint : SE Conversion :
: LED'd interior : Sony CDX-GT31W & Speakers : Sony XT-100HD : RF Punch HE2 10" 800w : Kenwood 600w :
EnervinE is offline   Reply With Quote
Old 11-18-2007, 09:34 PM   #4
Points: 12,261, Level: 72
Points: 12,261, Level: 72 Points: 12,261, Level: 72 Points: 12,261, Level: 72
Activity: 0.0%
Activity: 0.0% Activity: 0.0% Activity: 0.0%
Send a message via MSN to 96blkonblkse
Yeah, unless you have an actual leak the brake fluid will never really get low, it will show lower on the resoivour because more fluid is required to push the piston out further as the pad wears down. Same goes when you upgrade to a bigger caliper such as the Z32. I think you will run out of fluid in the resoivour before the pistons are all the way out lol.
Ive seen that happening a lot though. People see the resoivour down think the fluid just got low, so they top it off, when they go to press the pistons back in while doing the brakes they start to notice a leak and pop there hood and find brake fluid spewing out everwhere lol.
__________________
03 E55 AMG - Obsidian Black/Black
Eurocharged Tune, Eurocharged 172mm Pulley, CM30 IC Pump, PLM HE, secondary cat delete, Lowering links
02 Maxima SE - Daily
Bolt ons
00 Durango - Winter
5.9, 3.92lsd, 33's, 3" lift, intake, exhaust, upgraded vb
96blkonblkse is offline   Reply With Quote
Old 11-19-2007, 03:34 PM   #5
Points: 8,611, Level: 62
Points: 8,611, Level: 62 Points: 8,611, Level: 62 Points: 8,611, Level: 62
Activity: 1.6%
Activity: 1.6% Activity: 1.6% Activity: 1.6%
Quote:
Nooo just do it right, if you leave the fluids alone your car will implode !!!
its recommended to remove the cap from the resevoir when turning the pistons back or compressing them, but yeah, never top up the brake fluid. but you may top other all the other fluids if you notice they are low
andrei3333 is offline   Reply With Quote
Old 11-19-2007, 03:40 PM   #6
Points: 21,327, Level: 91
Points: 21,327, Level: 91 Points: 21,327, Level: 91 Points: 21,327, Level: 91
Activity: 94.1%
Activity: 94.1% Activity: 94.1% Activity: 94.1%
Crusher103
Send a message via AIM to Crusher103
Quote:
thats the first thing I do and put a towel around the reservoir so if any does spill over it doesnt go anywhere
__________________
96 Black I30t A.K.A Big Black/97 Black SE A.K.A. The DD(build in progress)
YES my cars have more mods than yours. And one MIGHT be reliable.
Quote:
Originally Posted by NCSU_MAX View Post
Crusher doesnt need any more crazy a** ideas... he generates plenty on his own on a daily basis...
Quote:
Originally Posted by Conrad283 View Post
Nope, that's just crusher being crusher
Crusher103 is offline   Reply With Quote
Old 11-19-2007, 05:48 PM   #7
Send a message via AIM to QNO_A32
haha laughed my *** off when i saw your sig thing or whatever it is chrusher lol....good ish
QNO_A32 is offline   Reply With Quote
Old 11-21-2007, 08:56 AM   #8
Points: 9,026, Level: 63
Points: 9,026, Level: 63 Points: 9,026, Level: 63 Points: 9,026, Level: 63
Activity: 1.5%
Activity: 1.5% Activity: 1.5% Activity: 1.5%
brake fluid = Best paint remover in the world
(JK!, don't use brake fluid to remove paint, but if you get a drip somplace on a painted surface, it'll take it down to bare metal in 10 min.! )
Just before your pads wear out completely, the brake warning light will often come on due to low fluid. People tend to top off the reservoir, forget it, then replace the pads 5K later and squoosh brake fluid all over the place. As mentioined earlier, best to remove a little before compressing the piston back into the caliper...
__________________
You can always live in your car, but you can't race your house...
emoore924 is offline   Reply With Quote
Old 11-21-2007, 11:50 AM   #9
Godzilla
shiftnatredline's Avatar
Send a message via AIM to shiftnatredline
that or not give a **** when it over flows. once you pump the brake pedal after you're done its at the right level if you let it over flow alittle bit. brake fluid brakes down with water so its no big deal as long as you dont get it on a painted surface.
shiftnatredline is offline   Reply With Quote
Old 11-27-2007, 07:00 PM   #10
Points: 6,049, Level: 50
Points: 6,049, Level: 50 Points: 6,049, Level: 50 Points: 6,049, Level: 50
Activity: 2.6%
Activity: 2.6% Activity: 2.6% Activity: 2.6%
whenever I do my brakes, first thing I do is take the cap off the brake fluid res, then change pads, once u are done pump your brake pedal until it becomes firm, put cap back on res, and u r done!
vilmaxima is offline   Reply With Quote
Old 11-27-2007, 07:06 PM   #11
Ad·min·is·tra·tor
DanNY's Avatar
Points: 50,485, Level: 100
Points: 50,485, Level: 100 Points: 50,485, Level: 100 Points: 50,485, Level: 100
Activity: 40.4%
Activity: 40.4% Activity: 40.4% Activity: 40.4%
next time you push the piston back in the caliper crack open the bleed screw. that's the RIGHT way to do it. your brake fluid will never overflow.
if you don't all you're doing is pushing all the crap and crud that settled in the caliper back into the system.
__________________
DanNY is offline   Reply With Quote
MaximaOrg
Nissan Maxima
Paid Advertisement
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
Emails Backup
Search Engine Optimization by vBSEO 3.5.2
