Go Back   Maxima Forums > Maxima Discussions > 4th Generation Maxima (1995-1999)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Timeslips Members Parts Guide Search Today's Posts Mark Forums Read ExperienceVendorsUsed CarsGarage TSB & Recalls
Search
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Search this Thread Display Modes
Old 11-12-2007, 04:23 PM   #1
Wierd TPS and transmission problems please help
Hi everyone,
I've been having problems with my car lately. Few weeks ago my check engine light came on. I'm like wtf, checked the code and it was TPS(throttle position sensor). I checked the TPS with an ohmmeter by following the steps on haynes manual and the readings were within the spec(500 ohm closed and 4k ohm on WOT). I just cleared the code and didn't bother to get it checked since it was running as usual. After few days check engine light came on again and it showed different code-which was A/T fourth gear signal fault. Right now my transmission acting wierd and only first and third gears are working(I have an auto). I also checked code from transmission Control module with OD light blinking and it decoded as TPS. My MPG as gone down from 24 to 19.5 cause engine is in the 3K+ RPM range on the highway.
Right now I don't know what to do- should I just go ahead and change TPS?
OR is it something else? Please help cause I can't afford to waste money on unnecessary things anymore
nick_auto96 is offline   Reply With Quote
Old 11-12-2007, 04:32 PM   #2
Send a message via AIM to 99grnmaxgxe
Yes please change your TPS, same EXACT ish happened to me, I waited it off until the tranny started slipping. You don't want that. DO IT ASAP!
__________________
Used to be mine...
Not mine anymore
99grnmaxgxe is offline   Reply With Quote
Old 11-12-2007, 04:45 PM   #3
The Dirty Pearl
pmohr's Avatar
Points: 22,165, Level: 92
Points: 22,165, Level: 92 Points: 22,165, Level: 92 Points: 22,165, Level: 92
Activity: 2.5%
Activity: 2.5% Activity: 2.5% Activity: 2.5%
Quote:
Originally Posted by nick_auto96 View Post
Hi everyone,
The whole 4th gear thing is a sign of doom, basically. Got that on my last two transaxles right before they became inoperable. Change out the TPS as a first measure.
Are you still on the original solenoids? Nissan released a TSB about them and an updated set, could cause trans damage.
My first three transaxles were brought down by bad solenoids (or previous abuse. who knows. I know the lastone was bad solenoids). It caused the trans to slip until the friction material literally wore completely off of the clutch plate, and welded it to the steel plate (I have pics if anyone is interested, still have the plates sitting here).
If you're still on the originals, it's worth the ~$150 for piece of mind to change them out.
__________________
A32 CEL Decoder | FSMs | Howto Videos
pmohr is offline   Reply With Quote
Old 11-12-2007, 07:07 PM   #4
Thanks a lot everyone, I'll be ordering TPS tomorrow. I hope that it will solve the problem. I'll update this thread when I install new TPS
__________________
Current Car: Alpine white E34 525i with 5spd manual. http://forums.maxima.org/members-rides/553577-my-new-alpine-white-e34.html
Previous car: Deep Evergreen 1996 Nissan Maxima SE with Automatic
Mods: map&dome LED's, rewired fogs, 9004->9007, homemade mesh grill,
blacked out bumper lights, Koni/ Eibach with stillen FSTB
Lost her in an accident on Jan 14, 2008. She still lives on in my heart...
Old 11-12-2007, 07:20 PM   #5
Be careful installing it, the screws are REALLY hard to get out and most likely they will get stripped. You also have to put it in a certain way or it will not work correctly. To be safe I went to a shop that put it in for $34.
__________________
Used to be mine...
Not mine anymore
Old 11-12-2007, 07:34 PM   #6
Points: 10,151, Level: 67
Points: 10,151, Level: 67 Points: 10,151, Level: 67 Points: 10,151, Level: 67
Activity: 0%
Activity: 0% Activity: 0% Activity: 0%
Send a message via AIM to black_maxed95
how come on my old max (a 95 gxe) the tps had only one wire connector but on my new max (a 96 SE) it has two?
__________________
I like to "do it myself"
5MT SE 96er:
MEVI + NWP Spacers, Full Exhaust, Flywheel, lotsa more:
MOD LIST
Quote:
Originally Posted by ironwork View Post
i am knew to this forum am i am amazed at how costructive your arguments are. no flameing and well thought posts.
black_maxed95 is offline   Reply With Quote
Old 11-12-2007, 08:14 PM   #7
oops too late
Quote:
I already stripped the one of the screws so I'm screwed now.
__________________
Current Car: Alpine white E34 525i with 5spd manual. http://forums.maxima.org/showthread.php?t=553577
Old 11-12-2007, 08:16 PM   #8
Quote:
I think they upgraded TPS. The old one didn't had the seperate WOT connector and newer versions did.
__________________
Old 11-12-2007, 08:52 PM   #9
Activity: 0%
thanks, i was just wondering this as i was working on my intake/throttle body today on my new car
__________________
5MT SE 96er:
MOD LIST
Old 11-14-2007, 04:50 PM   #10
Points: 10,424, Level: 67
Points: 10,424, Level: 67 Points: 10,424, Level: 67 Points: 10,424, Level: 67
Activity: 0%
Make sure you tweak the setting on the TPS once you install it. The FSM shows how to do this procedure. The only tool you'll need is an ohmmeter and screw driver. You need to set it so the switch side of the TPS so the car knows when you are at idle (actually, the FSM says 800 RPM). If it's way out of adjustment, you won't be able to reset you codes in the AT controller, and the car might not drive as well as it should. It seemed to make a big difference when I adjusted my new TPS.
__________________
GoldMax
'97SE plus Courtesy FSTB, Stillen RSB, Stillen cross-drilled rotors, Porterfields, Hella autobahn horns.
goldmax is offline   Reply With Quote
MaximaOrg
Nissan Maxima
Paid Advertisement
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
Emails Backup
Search Engine Optimization by vBSEO 3.5.2
