idler pulley, belt tensioner assembly
Old 10-27-2007, 03:34 AM
ThurzNite's Avatar
My idler pulley blew up on me while I was driving. I was able to find on the ground a 14mm nut, round black plate, 1 washer, and 1 cylindrical piece about 1/4" long. Am I missing anything? What's the proper order of assembly? Which side of the pulley faces out?
Jae
ThurzNite is offline
Old 10-27-2007, 09:25 AM
m00njal's Avatar
I'll try to take a picture of mine if I have time today, as I don't remember off hand. If anything, you can hit up pick a part?
*edit* I'll be on aim all day if you need any help.
m00njal is offline
Old 10-27-2007, 10:30 AM
dot dot dot ...
NmexMAX's Avatar
Sam happened to me not too long ago. It's actually pretty self explanatory, IMO.
NmexMAX is offline
Old 10-27-2007, 03:27 PM
ThurzNite's Avatar
Alright, great news... I was able to recover all the pieces. Tuesday I heard a metallic friction noise, so Wed I placed an order @ Kragens. Picked it up Fri night just before my 250mi road trip. Well, just past midnight, I pull off at my exit, downshift to 4th, and heard a clunk followed by massive metallic noise... I knew the pulley bearing was shot. Plus, Battery and brake lights came on, telling me alternator wasn't running.
Luckily I pull into a Bar/restaurant parkinglot and as I roll past Security, the rest of my pulley falls out. I casually park in the back, assess the damage, and notice I'm missing the nut. Luckily, security picked up my pulley, washer, and nut. This morn I head back and swap in the new pulley and belts and I'm golden. Woop!
209k miles... slowly, seems like everything will eventually fail.
Jae
Old 11-21-2007, 09:09 AM
mystican's Avatar
Was the pulley hard to replace? Did you hear a whine before the pulley went bad?
mystican is offline
Old 11-21-2007, 12:20 PM
ThurzNite's Avatar
It was easy to replace, I did it in a parkinglot with 1 philips screwdriver to remove the plastic wheel well cover, a 14mm (or 12?) wrench to loosen the pulley bolt, and a 14mm socket with extension to loosen the top adjuster.
The noise was a metallic scraping noise.
Dr J
Old 11-21-2007, 12:51 PM
Licensed to Spell
ptatohed's Avatar
I have the exact order of the adjuster pulley in my notes at home. I think I even took pics. Just let me know if you still need it.
From memory, here's the order from back to front.
In the very back, you have the horizontal bolt facing away from the engine. In your case, this bolt should have remained captive. Next is the adjuster plate (the thing the aforementioned bolt slides up and down in) held on by three bolts. Again, this should have remained on your car. Next is a washer. After that is the actual adjuster rod. Next, I think there is another washer or a spacer. Then the idler pulley, text side out. Then that big black washer. Then a smaller washer I believe. And then the 14mm nut.
If your adjuster rod fell out, then make sure you still have the "wavey" washer for the top of it.
ptatohed is offline
Old 11-30-2008, 05:46 PM
jholley's Avatar
idler pulley assembly
I broke the adjustble tension bolt while replacing the belts on my 98 maxima today. I carelessy always give too much torque.
Is this the order how the pieces slide onto the idler pulley pivot bolt:
1. washer
2. adjustable rod
3. washer
4. 1/4" spacer
5. idler pulley
6. capnut
7. 14mm nut
jholley is offline
Old 12-01-2008, 12:35 PM
jholley's Avatar
I found the assembly digram:
jholley is offline
Old 12-01-2008, 02:08 PM
ajcool2's Avatar
If you did take a picture could you post it up? Im trying to install my idler pulley on my 3.5 and I know I'm missing some peices but dont know what they look like.
ajcool2 is offline
Old 12-01-2008, 02:18 PM
Doesn't the link in post #9 explain it good enough??
I have said picture Ptatohed mentioned as well, but at home.
The Wizard is offline
Old 12-01-2008, 02:26 PM
ajcool2's Avatar
It explains how it should be installed perfectly but seeing the actaul parts would help out alot. Its mainly the spacer I need to see.
ajcool2 is offline
Old 12-01-2008, 02:39 PM
Alrighty, I'll see what I can dig up when I get home.
Old 12-01-2008, 05:39 PM
jholley's Avatar
The 1/4" spacer (11932) lies between the idler pulley and the adjustable bolt.
After purchasing the adjustable bolt I assembled it using the courtesy nissan diagram and it worked fine.
jholley is offline
Old 12-02-2008, 01:33 AM
So far, I've found this one. I might have one more....
Old 12-02-2008, 02:00 PM
ajcool2's Avatar
Thanks man now I can finally put this thing together.
ajcool2 is offline
Old 12-02-2008, 04:34 PM
jholley's Avatar
The 1/4" spacer appears to be missing? It lies between the adjustable bolt and pulley.
jholley is offline
Old 12-02-2008, 04:49 PM
Hmmmmmm....My max was pretty much bone stock when I bought it, and the original belts were on it....so I doubt I'm missing it. However, it's very interesting that's there's an obvious discrepancy between my picture and the one you linked.
Also FWIW, I've never had any belt associated problems. Gonna have to try and find the second pic I was talking about earlier.
Old 12-02-2008, 05:31 PM
4th Gen Parts King
Maxima_Joe's Avatar
Everyone I have seen has had that spacer between the adjustable bolt and pulley as well. Without it the pulley would hit the adjustable bolt. Perhaps it was still stuck on your pulley?
Maxima_Joe is offline
Old 12-02-2008, 05:33 PM
Could very well be. That's why I wanted to find the second pic showing the profile of everything....
Old 12-02-2008, 05:40 PM
Sounbwoy's Avatar
You can look here as well:
http://www.flickr.com/photos/sounbwoy/2598979462/
http://www.flickr.com/photos/sounbwoy/2598978792/
The Assembly was purchased from Courtesy.
Sounbwoy is offline
Old 12-02-2008, 07:23 PM
DCP
DCP's Avatar
are any of your replacement pulleys plastic?
my oem one is metal, but i looked at a replacement from a chain store and it was plastic.
DCP is offline
Old 12-03-2008, 10:15 AM
Double0Max's Avatar
yea it really is..mine blew up on me also it is better to go and get a new or newer one that you have..
Double0Max is offline
Double0Max's Avatar
and grease on that sucka when you put it back
Old 02-08-2009, 09:09 PM
cditto's Avatar
I'm in the same situation as the others here...my idler pulley must have fallen off when the nut broke off or loosened off. Same warning lights, etc.
So now I'm working on putting in a replacement from Autozone, and I have all of the above parts EXCEPT the retaining NUT on the far left and the washer that sits between the shield and the pulley (3rd item from the left in the pic).
I went to Lowe's because folks here said "It's a 14mm nut"...well that can't be right. I took the 1/4 in spacer with me off the bolt as a "guide" and it's only 12mm. So I bought a 12mm nut and a 12mm washer. BOTH are too big because the threading is smaller than the area where the pulley and spacer sit.
So I said the heck with it and took off the whole assembly. Tomorrow I'm taking the slide bolt itself with me to find out what size the thread really is. Am I wrong in this? It's the factory bolt, I'm sure. Should I skip Lowe's and actually buy the nut and washer from the dealership? Seems like a waste for such a simple part.
Oh, and the Autozone pulley had a flat side and a beveled side...does the flat side go against the inside? Should the pulley basically line up perfectly with the other main pulley?
FINALLY, anyone able to explain what this part really does and how it works?
cditto is offline
Old 02-08-2009, 10:02 PM
ThurzNite's Avatar
Yeah, my kragen came just like yours, and I was lucky that I was pulling into a driveway as everything turned to hell and exploded... people in the parkinglot picked up all the loose parts for me.
You're better off returning the part and calling Dave or a local nissan dealership and getting everything in the picture. Even courtesynissanparts.com has it for a reasonable price.
The smooth side faced the center of the engine.
Dr J
Old 02-09-2009, 04:07 AM
No more Maximas...
pmohr's Avatar
If it's a 14mm head, it's most likely a 10x1.25 stud. I know what you mean, few people on here know the difference between thread and head size, it's somewhat sad. 'What size are the wheel studs?' '21mm!'. ...no.
Are you in a hurry to fix it, or do you have time?
The total for the nut and the washer are ~$5 before shipping at Courtesy.
What do you mean what it does? It's a belt tensioner.
How it works? You adjust the top bolt, it raises or lowers the pulley to tension the belt. It's a lot more straightforward than, say, the PS belt.
Washer: 11931-42L00
Nut: 08911-3401A
pmohr is offline
Old 02-09-2009, 07:34 AM
ThurzNite's Avatar
I took a lil offense to that. But good thorough information. By the sound of the question, I thought he wanted the easy way, which's a fully assembled pulley that's plug and play.
Dr J
Old 02-09-2009, 07:55 AM
cditto's Avatar
Washer: 11931-42L00
Nut: 08911-3401A
Thank you...I'm going to try Ace hardware first with the bolt and see if I can get one to match up... I'm guessing it's just a simple washer and nut?
For the "what does it mean" I figured it was a belt tensioner after seeing this thread, but I'm wondering why they use the term "idler pulley"...makes it sound like it idles the belt or something.
Thanks guys...I'll post back what I find in case others get stuck like me.
UPDATE:
Went to Ace Hardware. The washer and nut that sit at the end of the bolt (far left in the above pics people posted) are M10x1.25 like pmohr said. I bought 2 nuts and 2 washers...total was $1.50.
So now I should be all set...thanks again.
cditto is offline
Old 05-13-2009, 10:29 AM
deftflux's Avatar
I hate to resurrect an old thread, but I wanted to add some things in case anyone else has this problem.
BTW, thanks everyone for this thread, it helped me with my problem.
Firstly, I have a 2000 Maxima, but the idler pulley assembly appears to be identical. I recently replaced the drivebelt, and all of a sudden while driving the battery light came on and the lights got a little dimmer. Turns out the idler pulley was missing and so was the belt! I ended up picking up the whole idler pulley assembly at a local Nissan dealer for $73. Not too bad, considering that courtesy wants $53 before shipping. I also had to buy another new belt...
Anyways, the new pulley from Nissan is metal, not a cheap plastic one. The "assembly" kit includes everything except the metal bracket that bolts onto the engine. So it had the adjuster arm and nut, the bolt that holds the pulley, and here are the parts in the order they are put on the bolt after the bracket: washer, adjuster arm, spacer, plate, pulley, flatter plate, nut. I wish I took pictures, but I didn't...
Now here's the important part: I have a theory as to why this happens. See, I had some belt squeel before I replaced the belt. After I replaced the belt, it still happened, although not as bad. I thought it was probably the other belt (power steering). Basically, though, now I figure the bearings were going out on the idler pulley, considering that it's probably never been replaced since the car was built. (I got the car when it had 85k miles, it now has 162k and I know I never replaced it until now...) When bearings go bad, there is more friction, which means that there is more torque on the inner part of the pulley, which is supposed to be stationary. Now normally this wouldn't necessarily be a problem, but if you notice the pulley turns in a counter-clockwise direction, so that translates to counter-clockwise torque on that nut that holds the pulley in place. Now before I changed the belt, the nut was tight enough that the belt slipped before there was enough torque to break it loose. However, when I retightened it, for some reason I didn't think it was critical to tighten it really tight, thinking it was just to keep it from losing adjustment. However, I was apparently wrong. Moral of the story:
Whenever you adjust the pulley, tighten the center nut extremely tight. The factory service manual says 19-24 foot-pounds of torque (for 2000 model year) to tighten that nut. There's no way my torque wrench would fit in that space, so I just tightened it almost as tight as I could with a 14mm box-end wrench. Also, it might be worth it to replace the idler pulley when you replace your drivebelt if you don't know when it's been changed (or if you have belt squeel). You can get a pulley by itself for much cheaper (or replace the bearings for even less) than the whole assembly plus an extra belt like what happened to me.
deftflux is offline
Old 05-13-2009, 11:05 AM
ThurzNite's Avatar
Yeah, sounds like either it wasn't adjusted to the correct tension, or like you said, too loose. Sucks how little room there is to work in there!
Dr J
Old 05-13-2009, 11:30 AM
wxm
wxm's Avatar
Originally Posted by deftflux
Whenever you adjust the pulley, tighten the center nut extremely tight. The factory service manual says 19-24 foot-pounds of torque (for 2000 model year) to tighten that nut. .
Be careful not to round the bolt with too much torque. I would try loctite or even double nuts for an insurance.
wxm is offline
Old 09-01-2009, 05:15 PM
eoghan's Avatar
part number for idler pulley wheel 4th generation
Hi,im trying to locate an idler pulley wheel for my 1998 maxima qx v6 (2.0 petrol manual) I cannot locate the part number? where could I order it from ? im located in ireland..
eoghan is offline
Old 09-01-2009, 05:47 PM
How about your local Nissan dealer in Ireland??? No luck??
Old 09-03-2009, 05:00 AM
99custom's Avatar
make sure you add grease when you put it back
99custom is offline
Old 09-03-2009, 11:19 AM
ThurzNite's Avatar
Grease what?
Old 01-07-2010, 03:07 PM
B_Eaze's Avatar
Bump again...
Changed my alt and i'm putting everything together. Everything is done but the belt. my AC compressor can't be placed back in the same position because of an issue with a bolt so I'm bypassing it. I left the belt off overnight now my tensioner won't move up and down. completely stuck in the down position. I tried tapping a hammer on a prybar on the tip of the bolt to free it up but no luck. Took the bolt of the pulley to remove the whole assembly but the pulley still won't come off. Don't have a shop light so i'll do some more in the morning. Any suggestions on what I should do tomorrow? Put the nut back on and try to tap it free from the bottom? or to remove the whole assembly ?
hopefully Nissan has one in stock if I have to replace it
B_Eaze is offline
Old 01-08-2010, 06:22 AM
cditto's Avatar
The tensioner won't move up and down even when you use the screw at the top of it?
cditto is offline
Old 01-08-2010, 07:19 AM
B_Eaze's Avatar
yea, doesn't matter still won't budge. I took the pulley nut off and messed around with the top bolt but that shouldn't even matter once the bolts off.
B_Eaze is offline
Old 01-08-2010, 04:50 PM
Nismo32's Avatar
same thing happen to me. the 14mm is over tighten and also check behind the pulley the bolt make sure its aligned with the groove if its not than its pressed against the guide.
Nismo32 is offline
Quick Reply: idler pulley, belt tensioner assembly
