Is this motor mount looks ok ?
Old 10-26-2007, 04:39 PM
matrix11229's Avatar
I have some vibrations in N after I had my alternator and belts replaced in the shop (I had to leave the car there, and when I took it back the steering wheel vibrated in N and D). I put another alternator in but it didn't change anything.
After I loosen the belt , I got less vibration , but it's still there .
I wonder what the mechanic could remove and install a defective part instead. (I seen 4th gen frequently parking near this shop and I suspect it belongs to the boss...).
I looked at the motor mount below the air box and it doesn't look normal to me. I think some rubber parts are missing there.
matrix11229 is offline
Old 10-26-2007, 04:53 PM
f550maranello2's Avatar
looks normal to me..
f550maranello2 is offline
Old 10-26-2007, 05:30 PM
vqmaxman's Avatar
It looks normal and to tell if the mounts are bad have some one shift the gears and look at the mounts and see if it moves. Another way of knowing that you have bad mounts is that you have crack lines in the mounts.
vqmaxman is offline
Old 10-29-2007, 08:16 AM
kartiste's Avatar
Looks just like mine.
Kartiste
"Carry On, & Dread Nought"
kartiste is offline
Old 10-29-2007, 08:20 AM
wants an I35
ROCKART's Avatar
yea looks fine. way to check the mounts is to stand with the hood open while someone in the drivers seat switches from drive to reverse to drive to reverse and so on. if you see the engine moving a lot then its the mounts.
as far as vibrations go it could be a lot of things.
ROCKART is offline
Old 10-29-2007, 08:54 AM
Snypa's Avatar
i guess all our rubber mounts are gone,....mines the same too.
Snypa is offline
Old 10-29-2007, 02:00 PM
lexoid's Avatar
I've just checked my RH motor mount and it is gone. The rubber has deep crarcks. So should I go with OE mounts or buy this one: http://cgi.ebay.com/ebaymotors/Nissa...spagenameZWDVW
Anyone tried them?
lexoid is offline
Old 11-04-2007, 01:23 PM
chubbman85's Avatar
i brought some off ebay to (plan on upgrading to 6th gen max next year). the one for the right side (passanger) is not really a perfect fit, there is flat. the factory installed one is way thicker at the screw on side)
chubbman85 is offline
Old 11-04-2007, 03:37 PM
max ride 41's Avatar
yes, oem is is always thicker than e-bay chinese after-market. courtesynissan.com should have an oem for a reasonable price.
max ride 41 is offline
Old 11-04-2007, 04:56 PM
wants an I35
ROCKART's Avatar
not courtesy nissan, south pointe nissan !!
ROCKART is offline
Old 11-04-2007, 06:55 PM
maxima1239's Avatar
Yea dont ever get cheap ebay motor mounts. Stick with nissan oem parts.
maxima1239 is offline
Old 11-04-2007, 08:16 PM
ThurzNite's Avatar
I'd get ebay mounts and fill them.
Jae
ThurzNite is offline
AaronL
08-08-2020 10:31 AM
D Mason
06-21-2016 04:43 AM
Unclejunebug
04-02-2016 05:42 AM
knight_yyz
11-01-2015 01:34 PM
Quick Reply: Is this motor mount looks ok ?
