How To: Trunk Strut Install (No More Torsion Bars
Old 06-15-2010, 11:58 AM
  #41
grancouva2000's Avatar
does anyone reamber how many pounds support they used . my trunk has a spoiler,thanks
grancouva2000 is offline
Old 06-15-2010, 12:22 PM
  #42
Mod her. Ate her.
phenryiv1's Avatar
Originally Posted by grancouva2000
does anyone have the part num of the struts they used .thanks
From the first post...
Originally Posted by 2AZN2DMAX
I bought the struts for AutoZone for about $20 a piece (lifetime warranty). They measure 14" when extended fully and around 9" compressed (the black chamber is about 8" and the shaft is about 6" when extended). I have two numbers that I got off the struts and they are 29306 and 4259, I don't know which one they use for part look-up but I think it is the 29306. This strut has and open end (looks like an eye-lit hole) and the other is where you snap it onto a bolt with a ball on it. Make sure when you buy the struts that you have the one with the removable ball (easier intall).
I am still trying to figure out why I subscribed to this thread...I had not had an A32 for several years at that point...
phenryiv1 is offline
Old 06-15-2010, 12:47 PM
  #43
that is not a know part num for autozone.
Old 06-17-2010, 07:58 AM
  #44
dont anyone reamber what lbs struts they used
Old 06-23-2010, 01:10 PM
  #45
Clashez's Avatar
im goin 2 start this mod right a way
Clashez is offline
Old 07-03-2010, 05:32 AM
  #46
Maxima1984's Avatar
The one's I used were 380N, which is about 85lbs. However, without a spoiler, my boot still doesn't automatically open up when I hit the boot release.
Maxima1984 is offline
Old 07-14-2010, 12:11 AM
  #47
i did the struts in my trunk and when i push the button to open it goes wright up and i have a spoiler.
Old 07-15-2010, 07:12 AM
  #48
Maxima1984's Avatar
Did you mount your struts in the same mounting points?
Also, do you know how many lbs or N's your struts are?
Old 08-28-2011, 01:39 PM
  #49
Hillsboromax's Avatar
DAMN I like that mod.. But how would I do it in a 5th gen? seat belts r blocking in the trunk
Hillsboromax is offline
Old 08-28-2011, 01:51 PM
  #50
tigersharkdude's Avatar
Please dont bump old threads that dont even pertain to your car.
Also, this would work basically the same for your car (Im pretty sure) a few things may be different
tigersharkdude is offline
Old 08-28-2011, 06:43 PM
  #51
Cebby's Avatar
Glad this got bumped - I need to ditch my torsions for a stereo mod I want to do...
Cebby is offline
Old 08-28-2011, 06:46 PM
  #52
2AZN2DMAX's Avatar
Wow havent been on in a while since I sold the max but im glad I got a notification that my old thread was being used.
2AZN2DMAX is offline
Old 08-28-2011, 09:30 PM
  #53
mightyMax95's Avatar
GENIUS!!! i hadn't even thought of this! i was gonna ghetto up something like newer maximas.
mightyMax95 is offline
Old 08-29-2011, 05:48 PM
  #54
Polar's Avatar
I'm glad this got bumped, too. I was wondering what to do about the trunk not popping up very much. Too bad I can't open the pictures....
Polar is offline
Old 09-02-2011, 03:09 AM
  #55
MaxJammin's Avatar
this is awesome, i was just talkin bout this yesterday, deff next on my to do list
MaxJammin is offline
Old 01-10-2012, 07:40 PM
  #56
FunkMcOwnage's Avatar
I think I'm gonna need to do this to get enough clearance to put my new sub box in. I wish all the images weren't broken
FunkMcOwnage is offline
Old 01-19-2012, 11:32 PM
  #57
nismomaxgtr18's Avatar
OP, by any chance do you still have the original pics? This would be a great mod to do.
nismomaxgtr18 is offline
Old 04-28-2014, 12:45 PM
  #58
cscotty's Avatar
Looking to do this mod as well. Seems awesome. Original poster...do you have the pics that you can upload from the original post...or can anyone post pics and steps they've used to do this mod?
cscotty is offline
Old 04-09-2015, 12:25 PM
  #59
jholley's Avatar
Bumping this thread to give members new accessories for the parts needed. The extended length minimum is 13.5” with a compressed length maximum of 9.3”. Each strut has 90 pounds of force (400 newtons).
I ordered the struts and accessories from www.liftsupportsdepot.com
Strut 4529S10 (2)
Eyelet End fitting 8mm TDN622M6X10Z (2)
10mm Ball Stud M8 x 1.25 H93607AW (2)
You’ll need M8 washers and M8 x 1.25 nylon lock nuts to mount the 10mm ball studs.
jholley is offline
Old 04-09-2015, 12:27 PM
  #60
jholley's Avatar
For the shaft eyelet mounting I used this setup
M8 x 1.25 x 60mm length bolts (2)
M8 x 1.25 nylon lock nuts (2)
M8 washers (6)
5/16” x ½” length metal sleeves (2)
jholley is offline
Old 04-09-2015, 12:28 PM
  #61
jholley's Avatar
On the shaft end of the strut you’ll be replacing the 10mm steel ball socket with the 8mm eyelet end fitting.
It extends the strut length 1/8”. Compressed length is now 9.2” and the extended length is 13.9”
jholley is offline
Old 04-09-2015, 12:29 PM
  #62
DennisMik's Avatar
That is excellent information. Could you post a photo of how you mounted the other end?
DennisMik is offline
Old 04-09-2015, 12:41 PM
  #63
jholley's Avatar
I used that open hole that this member posted years back
Those holes are right above the rear trunk lining on each side.
Note: that member welded the 10mm stud onto the hinge sleeve to mount a 10mm ball socket fitting. On the 4529S10 strut I replaced the 10mm ball socket with an 8mm eyelet fitting. The bracket on the trunk hinge needs to removed. I used a stone grinder with my dremel tool.
jholley is offline
Old 04-09-2015, 01:14 PM
  #64
maximaham's Avatar
wheres the video,i see broken links,,,sorry
maximaham is offline
Old 04-09-2015, 01:25 PM
  #65
jholley's Avatar
The video travmaximas uploaded back in 2007 is no longer available. Only his photos still have a link.
The 4529S10 struts with 400N don't open the trunk fully upon release. Similar to the hood you have to raise the trunk manually and it stays open. It closes easier.
jholley is offline
Old 04-09-2015, 04:09 PM
  #66
DennisMik's Avatar
Thanks for the extra photo!
Old 04-09-2015, 06:17 PM
  #67
maximaham's Avatar
What struts did you use and wheres the write up?
Old 04-09-2015, 06:48 PM
  #68
jholley's Avatar
You'll need stronger struts for it to fully open during the release.
I would try these 49022S10W
They have 547 newtons (123 lbs.)
Don't forget the 8mm eyelets, 10mm ball studs, and nuts & bolts I listed in the above posts.
jholley is offline
Old 04-09-2015, 08:23 PM
  #69
Thank god this thread was updated! I have looked into this so many times but gave up since there were no exact specs and the pics had expired. Thank you jholley!
Roman777NYC
11-07-2015 10:13 PM
MaxLife17
09-08-2015 02:36 PM
Johnny9595
09-03-2015 05:18 AM
Hailstatejig
09-02-2015 06:52 AM
Maxboy23
08-20-2015 09:33 AM
Quick Reply: How To: Trunk Strut Install (No More Torsion Bars
