Shimmy at 75 mph +
Old 10-18-2001, 01:43 PM
maxnewbie's Avatar
Shimmy at 75 mph +
I am experiencing a shimmy when I drive 75 mph or higher. I had my tires rebalanced and it seems a bit worse now. Any ideas why?
maxnewbie is offline
Old 10-18-2001, 02:28 PM
mjb95gle
Re: Shimmy at 75 mph +
Maybe you have one or more bad tires?
Old 10-18-2001, 02:50 PM
paco's Avatar
yea u may have a bad tire or rim.......did ur rims balance out to 0-0........if 1 didnt have the rim and tire checked!
paco is offline
Old 10-18-2001, 03:14 PM
Stillen_I30's Avatar
are you on aftermarket rims? if you are make sure you got your hubcentric rings in there too. the balance can come out perfect, and still vibrate at above 70mph without those hubcentric rings.
Stillen_I30 is offline
Old 10-18-2001, 03:23 PM
camaro1698's Avatar
this si a problem most of the maximas out there, we think that the rack isn't set properly, balancing, new tires, alignment never helped me and I 've been trying to fix the problem for 2 years now
camaro1698 is offline
Old 10-19-2001, 05:56 AM
98se5spd's Avatar
A couple months back, every once in a while, my car began shimmying at 65+ mph. Some days it wouldn't other times it would..front end, tires, wheels, balancing all checked out.
I began noticing that the days that it didn't shimmy, was when I didn't have the front end bra on. When I removed the bra, no more shimmying.
Wind must have been getting under the bra...So now my custom fit, $65 Le-bra, sits neatly folded in my trunk..
98se5spd is offline
Old 10-19-2001, 07:37 AM
paco's Avatar
yea hes right......its weird some days my car rides smooth as hell and some days it shakes.......i dont understand it!!
paco is offline
Old 10-19-2001, 11:35 AM
Washington DC Maxima's Avatar
I have the sometimezy
problem too.. I am starting to believe my Springs may shift a bit.
Washington DC Maxima is offline
Miket2006
03-01-2021 03:55 AM
04-16-2020 05:15 AM
salty318
09-29-2015 01:21 PM
salty318
09-28-2015 07:22 PM
06maxima55
09-28-2015 04:29 PM
Quick Reply: Shimmy at 75 mph +
