Keyless entry???
Keyless entry???
I have a '97 parts car, GLE, and we want to try and add the factory keyless entry to a '99 SE without the C&C package. Is it just a module, or is the entire wiring harness different?
Check if there's a receiver in the trunk, near your power antenna. Check this thread: http://forums.maxima.org/showthread.php?t=407976
The good news is that your '99 should be prewired for it. Here's some of what you'll need:
- Module located near the spare tire jack on the antenna side of the trunk (diffrerent from 95-96 and 97-99).
- Brown relay located near the trunk latch on the body of the car (same 95-99).
- Trunk opener to work with keyless (same 95-99).
And here's the bad news - I added all of those items to my '99 and wasn't able to get it working. I read somewhere that someone who completed this successfully needed the BCM from the donor car as well - I haven't bothered to try that on my '99 since I'm afraid with the whole Transponder key business.
If you do get it working, definitely post up what you do! I'm almost ready to just give in and go aftermarket.
ah2002
03-09-2016 01:42 PM
