testing coil packs
Old 09-16-2007, 12:03 PM
kv2
kv2's Avatar
testing coil packs
so i think one of my cylinders is misfiring. i wanted to test the coil packs to see if they were the culprit or the plugs.
if i were to test each one for a change in engine noise/spped, do i physically pull up the coil from the socket or do i disconnect the electrical connector? i do this while the engine is running right?
thanks!
kv2 is offline
Old 09-16-2007, 01:39 PM
VQ30DETT's Avatar
http://forums.maxima.org/showthread....ting+coil+pack
this should help you out, i used this information to solve my misfire which was caused by a bad fuel injector
VQ30DETT is offline
Old 09-16-2007, 02:53 PM
kv2
kv2's Avatar
ok so i got the 0607 code now which says cylinder 2 misfire.
what can cause this? the spark plugs or coil packs right? anything else i should be aware of?
i am able to swap around the individual coil to different cylinders without doin any harm?
kv2 is offline
Old 09-16-2007, 03:10 PM
VQ30DETT's Avatar
http://forums.maxima.org/showthread....ylinder+number
i would ohm out the coils, no swapping. check fuel injector too, lastly check plugs
VQ30DETT is offline
Old 09-16-2007, 03:55 PM
kv2
kv2's Avatar
hm what seems to be bad about swapping coil packs around to test?
you and other instructions online say not to do so (the rear ones, at least). aren't they exactly the same thing?
kv2 is offline
Old 09-16-2007, 05:01 PM
lexoid's Avatar
Front and rear coils are different. But I don't see why you shouldn't change coils in the same bank. Beside coils itself, other possible causes for a missfire could be: a bad fuel injector, intake air leak, insuficient compression.
lexoid is offline
jmlee44
10-02-2022 02:13 PM
TallTom
50
07-08-2022 09:54 AM
tarun900
19
12-20-2021 06:57 PM
dshinn
09-26-2015 08:07 PM
zmcneely13
09-26-2015 02:26 PM
Quick Reply: testing coil packs
