The Air Conditioner is causing a leak in the car.
Old 08-28-2000, 05:00 PM
nforg's Avatar
I have a 1996 Maxima SE with 50,000 miles, and has been taken care of very well. A friend recently noticed that while I had the air conditioning blasting that water (or a substance like water, it was neither hot nor cold, just regular room temperature water) was slowly dripping on to their foot. The problem may not be because of the ac, but I simply assume it is, infact I am almost 100% positive it's because of the AC. I would just like to know, why this is happening, exactly what is wrong, and most importantly how do I fix it and how much is it going to cost. Thank you.
-Nate
nforg is offline
Old 08-28-2000, 05:14 PM
Slickismax's Avatar
That is just condensation from the AC. I don't think there is anything you can do about it, since that is supposed to happen. Just hope that it doesn't drip on your ECU, which is on the floor in the middle of the center console.
Slickismax is offline
Old 08-28-2000, 06:16 PM
Eagles Fan 4 Lyfe
Chris91SE's Avatar
-Nate
ive had this happen in every car ive owned including the max..it takes about 2 hours of ac on for it to occur in the max....like slickismax said its just condensation...i doubt there is much you can do about it...
Chris91SE is offline
Old 08-28-2000, 06:36 PM
ronskal
Yea it's definately normal and expected to have condensation from the AC inside coil but it should have a collector tray and overboard drain line.
It may be leaking at the collector or if you're in a super humid area this may be more than it can drain.
Old 08-29-2000, 07:57 AM
Max96's Avatar
Sounds like the evaporator drain tube may be obstructed. How does the cowl look? Is there all leaves and other junk like that in it? IF so, that stuff gets down into the evaporator box and clogs up the drain tube. If thats the case, (it usually is) the best fix would be to open up the evaporator case and clean all the junk out. Blow out the drain tube while you are at it.
Max96 is offline
sctludwig
09-01-2022 01:32 PM
cruce91
09-20-2015 10:23 AM
dcam0326
09-08-2015 11:02 PM
lux97Max
09-04-2015 05:42 PM
sdotcarter
09-02-2015 09:53 PM
Quick Reply: The Air Conditioner is causing a leak in the car.
