possible cv joint problem need assistance
last weekend i drove about 850 miles round trip. it was mostly highway driving at speed between 80-100.
now that i'm back home doin' my normal commute, i hear an odd noise at various speeds. the sound seems to originate from the front of the car and has something to do with the wheels/transaxle since i don't hear the noise while stopped, or when turning. i can notice the sound while coasting or during acceleration.
the hayes manual says it may be a constant velocity joint prob, or perhaps out of balance front wheels, or out of round front tires.
has anyone had a problem similar to this and can recommend a course of action??
Re: possible cv joint problem need assistance
1) Verify that all wheel nuts are tight.
2) Raise the car. If you have a floor jack you can raise the entire front end at once, and test both front wheel bearings. No need for jackstands, as you will not get under the car.
3) Grab the top of the tire (12 o'clock) and push away from yourself and pull toward yourself. Yank it to and fro in this fashion several times. If there is noticeable free play or a "clunking" sound, the wheel bearing may be damaged.
4) Spin the wheel. If it spins freely but makes ugly sounds the wheel bearing may be damaged. If it won't spin freely the brake may be dragging. This could indicate a sticking caliper.
5) Remove the wheel. Make a careful visual inspection of the brake and surrounding parts. Look for ...
- a stamped sheet metal baffle plate which has been bent and is rubbing the rotor.
- a pebble or other foreign body which is trapped and is rubbing the rotor.
- a brake shim which has slipped out of position and is rubbing the rotor.
Re: Re: possible cv joint problem need assistance
daniel b,
thanks for taking time to assist me. it seems as thought every other post has your name in it the subject. good thing you're generous with your time and are willing to share your experience.
i'll follow your recommendations and let you know how it turns out.
Re: Re: Re: possible cv joint problem need assistance
tires were rotated. still hearing the sound. will proceed with the next suggestions..
As far as I know, it's prob not a CV problem if you dont hear anything when turning. From experience with the various cars I've owned, I've noticed that every time I had a blown CV, you would get a loud ticking noise when turning the wheel to the left or right, most of all when it's extreme left/right. I may be wrong, but I figured my personal input might help. Good luck!
06-06-2017 02:01 PM
Unclejunebug
04-02-2016 05:42 AM
