mushy brakes - bleeding
Old 09-13-2001, 08:17 AM
iwannabmw's Avatar
Does anyone know if it is better to bleed the brakes with the engine running providing power assist or with it off. I've got stainless steel lines on a 97 SE and they feel mushy. I've tried bleeding them with the engine off and was wondering if anyone had any input as to the best procedure using two people. Thanks
iwannabmw is offline
Old 09-13-2001, 08:49 AM
Rit
Rit's Avatar
My guess is that it would be better to bleed
the brakes with the engine off. The instructions usually recommend that you "gently" depress the brake pedal, and this is more easily done without any power-boost from the engine running.
Rit is offline
Old 09-13-2001, 04:12 PM
iwannabmw's Avatar
Old 09-13-2001, 04:22 PM
yourmove's Avatar
The best brake bleeding recommendation is to purchase an "Mighty Vac"! You could do a search or contact www.lockhartphillips.com . This makes this procedure a one man operation and is simple. I purchased mine for (I Think)$39.95 and have used this many times without any problems!
yourmove is offline
Old 09-13-2001, 04:27 PM
I'm needing a caw
Jeff92se's Avatar
I made my own brake bleeder. It gives a constant fluid supply also.
http://forums.maxima.org/showthread.php?threadid=64046
Jeff92se is offline
04-16-2020 05:15 AM
06-06-2017 02:01 PM
leatherneck
09-30-2015 09:16 PM
HerpDerp1919
09-29-2015 02:02 PM
Socalstillen
09-26-2015 12:01 PM
Quick Reply: mushy brakes - bleeding
