Front Strut Bearings
Old 09-05-2001, 09:50 PM
radiohead75243's Avatar
Front Strut Bearings, Clunking Culprits
After hearing a clunking sound when the wheel was turned, I recently removed the front strut bearings and re-packed them with lithium grease. The noise disappeared completely for 2 weeks, but has since returned. It seems likely, especially since the re-packing temporarily alleviated the problem, that the bearings are worn and need replacement, but I'm not exactly sure how these bearings would exhibit wear. Am I missing the signs of bearing wear, or are there other possibilities, like a worn strut mount, for example, that could be causing this problem?
Thank you
radiohead75243 is offline
Old 09-05-2001, 11:29 PM
SLOW
Nealoc187's Avatar
Is your suspension modded? I tore up one of those bearings because I was an idiot and didn't have it seated correctly when I lowered my car off jacks. The bearing was destroyed. New ones are $20. It's the labor involved with replacing them that's the real bitc#.
Nealoc187 is offline
Old 09-06-2001, 01:15 AM
I have a stock suspension, and I didn't experience any problems during this procedure.
Old 09-06-2001, 03:27 AM
NickStam's Avatar
i have this same problem. Can you explain this in further detail (packing)?
NickStam is offline
Old 09-06-2001, 05:10 AM
Minister of Silly Walks
mzmtg's Avatar
Check it out:
http://www.motorvate.ca/auto/maxima/...ut_bearing.htm
mzmtg is offline
Old 09-07-2001, 02:36 AM
Briguy1971's Avatar
YES!!
YES YES YES! Oh Thank you thank you thank you thank you!!!!
I have been having this same problem and the few people I talked to said that I had to totally replace my struts and everything to get rid of it. I am so excited!!!
Briguy1971 is offline
Old 09-07-2001, 04:59 AM
Daniel B. Martin's Avatar
Originally posted by mzmtg
Check it out:
It is interesting to note that Frank, the owner of http://www.motorvate.ca/auto/maxima/...ut_bearing.htm , urges the use of spring compressors. This issue was debated in http://forums.maxima.org/showthread....threadid=63096
http://www.motorvate.ca is an excellent Web site for the D-I-Y mechanic. Lots of photos, lots of good advice.
Daniel B. Martin is offline
Old 09-08-2001, 03:58 PM
Re: YES!!
Just a word of advice before you embark on your front strut bearing(s) task: spend an extra $35-40 and replace the bearings, because my remedy of re-packing the original bearings only lasted 2 weeks before a relapse, and do not neglect getting an alignment right after you complete the job, as your alignment will be considerably off.
AcuraLegend
10-17-2016 08:47 PM
BkGreen97
04-02-2016 05:47 AM
AcuraLegend
09-22-2015 04:22 PM
dvcamp
09-18-2015 10:17 AM
Johnny9595
09-03-2015 05:18 AM
Quick Reply: Front Strut Bearings
