95 maxima car keeps stalling
Old 08-05-2007, 05:37 PM
95maxing's Avatar
Hey Guys,
About a month ago my car keeps stalling at low speed/stop lights.
This only happens occasionally but it's really annoying. When I approach low speed/stop lights rpm goes down and car stalls. Usually it starts right back but I have to put some gas on it to keep it running. I took it to a mechanic and he can't seem to figure out what it is. I don't have any check engine light on. he cleaned my fuel injector, throttle, replaces spark plugs, said my battery was good. I have no idea what da hell it is.
Anyone know what the reason might be?
I own a 95gxe by the way.
95maxing is offline
Old 08-05-2007, 05:49 PM
close but no cigar
Tmcgradyfann1's Avatar
is it a 5spd?
Tmcgradyfann1 is offline
Old 08-05-2007, 05:50 PM
95maxing's Avatar
no its an automatic
95maxing is offline
Old 08-05-2007, 05:56 PM
close but no cigar
i dunno maybe your MAF?
Old 08-05-2007, 05:58 PM
maximus_pr's Avatar
still check for any codes just in case
maximus_pr is offline
Old 08-05-2007, 08:11 PM
Paintguy84's Avatar
my 95 gxe 5 speed is doin the same, the rpms drop while rolloing to a stop but it doesnt shut off, it comes back up within a second.
Paintguy84 is offline
Old 08-06-2007, 09:58 PM
KillaJakez's Avatar
Had same problem. It was the cat. I had something flapping around inside it and when I braked, that piece of debris somehow positioned itself to block exhaust flow. The engine turned off due to exhaust backup. Go check your cat!
KillaJakez is offline
Old 08-07-2007, 07:43 AM
Rberga1's Avatar
Clean your EGR tube.
Rberga1 is offline
Old 08-07-2007, 08:10 AM
chrisZ's Avatar
Might want to check your coolant temp sensor. My car would stall at stop lights, etc. But did receive a CEL (code). Replaced the sensor and all was well again.
chrisZ is offline
Old 08-07-2007, 10:23 AM
95maxing's Avatar
is my computer broken or something...I mean obviously there is something wrong with the car but I get no codes...my mechanic did connect the computer to my car and said got nothing out of it...
also forgot to mention, My check engine light was on until 3 weeks ago when it decided to go away by itself...hence the reason why i can't figure out the problem..
95maxing is offline
Old 08-07-2007, 10:25 AM
close but no cigar
well usually it stores the problem into your ecu and you can still see what the problem was. so the mechanic should be able to see what it was 3 weeks ago
Old 08-07-2007, 11:03 AM
hybridc24k's Avatar
Im not sure but maybe it could be your fuel pump? Fuel filter? Wires? Have you done all your maintenance?
hybridc24k is offline
Old 08-07-2007, 04:44 PM
95maxing's Avatar
yes maybe its just time for my car to go...
95maxing is offline
Old 08-07-2007, 04:52 PM
Paintguy84's Avatar
i would clean the throttle body again, sometimes the gunk in there is very built up after not being cleaned for a while, my car was doin the same thing. It took 3 cans of tb cleaner but it works great now.
Old 08-07-2007, 07:54 PM
DoubleNaught's Avatar
I had the same problem on my 95 a couple years ago. It ran fine all winter but on the first warm day of spring it started stalling. I first thought MAF since it's affected by outside temperature, but it checked out okay using a multimeter. So then I spent alot of money and several months having different mechanics work on it, and it still wasn't fixed! So I got disgusted and decided it had to be the MAF. Of course Nissan wanted a fortune for a replacement, so I ended up finding an one at a junkyard off an Infiniti. Paid 70 bucks, put it on and problem was gone! I can't say for sure that's your problem, but try to track when it happens - i.e. does it stall more on hot afternoons than on cool mornings?, etc... Best bet is if you know someone that has a car like yours, switch out MAF's and see if it helps, before you actually spend the money on a replacement. Hope this helps.
DoubleNaught is offline
Old 08-07-2007, 07:58 PM
i has college
EnervinE's Avatar
TB, IACV, EGR, MAF, some other abbreviation.
EnervinE is offline
Old 08-15-2007, 05:12 PM
95maxing's Avatar
ok this is gonna be my final attemp..I'm going to replace the MAF sensor this weekend..I really hope this fixes it..
95maxing is offline
Old 08-15-2007, 05:40 PM
67whitegoat's Avatar
Check your battery connections. Make sure they are clean. tight, and in good condition.
67whitegoat is offline
Old 08-24-2007, 09:33 AM
95maxing's Avatar
Ok! I fixed it... It was the MAF all along..nice to have my car fixed spent about total of 2g's fixing this and that...
95maxing is offline
Old 09-07-2007, 09:00 AM
wayne937's Avatar
My daughter had the same problem with her 95 Nissan as what you described. A new MAF took care of it also. Maybe we were just lucky as I am sure that other things could cause this same problem.
wayne937 is offline
Lakersallday24
06-16-2019 01:35 AM
Quickgtp
04-13-2017 03:30 PM
acw
08-13-2015 12:50 AM
halfpol
08-05-2015 08:24 PM
Tanvirkamal
08-05-2015 01:32 AM
Quick Reply: 95 maxima car keeps stalling
