4th Generation Maxima (1995-1999)Visit the 4th Generation forum to ask specific questions or find out more about the 4th Generation Maxima.
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access
to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Houston...We have a problem (core support rust - pt.2)
So anyone that lives in an area with snow and corrosion, this is your 4th gens fate. I noticed a clunking yesterday and thought...Oh snap! I think my control arm bushings are shot. Well I went to check oil/ trans fluids as a part of my weekly inspection and noticed my radiator pimped down on the passenger side and the passenger side support bushing also missing.
hey dude, how much did all this stuff cost ya.. one of my good friends got this and hes been worried ever since his car is gonna fall on the ground or something....
__________________
95 SE (VQ35DE EATER) - 96 GXE (Weekend Fun) - 98 GXE (Daily Driver/Grocery Getter) = sold
Quote:
Originally Posted by irish44j
khantalha, in case you didn't see my other post - your signature is not appropriate for this forum and needs to be deleted. Please take care of it...
Lots of NEW/USED 4th Gen Parts , Click here, if dont see what ur looking for then PM me...
It was like $160 or somewhere around that for all of it. I have it all torn down at the moment. I will get some pics up later, and hopefully finish it this weekend. I planned on taking it to a shop, but rather at least try it first myself. Actually my step-dad is helping a lot too. Without his help, the car would be in a ball of flames in the backyard while I made s'mores over it. lol. jk.
And yeah..165,000 miles of NE Ohio winters and salt will do that, My car is a giant rustball...but bit by bit I am fixing that. She has to last until I earn my Degree.
wow, now your scaring me dude. i know my bushings are bad and i was told at the dealer my rad support was'nt too bad. i looked at it when it was up in the air and its still together, phew!!!! i did'nt know you could replace just the lower support, i thought you had to replace the whole rad support. where did you get the lower support?? please inform us of that and your progress.
This is for all the others out there that tried to fix it half way...
Pay close attention to my Nismo bungee radiator support!Lol. Also, if you look close, all those 3/8in holes are where you have to drill out spot welds. You really notice when you look at the pic above then below.
So all I have to say after today is...PITA.. PITA... PITA!!!
Holy Spot Welds Batman!! There were so many, like 20 per side. And there isn't a lot of places to be welded, just a lot condensed in a small area! And the 12mm in the front corners will snap, one broke through in the engine support, so saws all that. Three 14mm on each side, one on the back will spin with the nut broke free...saws all that one too. Sorry I wasn't more step by step, esp with the pix, but I had to rush, I MUST be done by Monday. But I can maybe comeback and add more later...phew! I'm goin' to bed. I'll add more after I get done (hopefully) tomorrow.BTW took my stepdad and I 6 hours to completely disassemble to the point of re installation.
-Please don't flame us, neither of us are or claim to be professional body repair men. This is a first for both of us...we are engine builders. Body work is WAY harder IMO.
Xtra .02 = I know I need a new A/C condenser...horribly! Just I can't have one here by Monday without spending $300, and I don't have that. That's definitely next. I will obsess about it now until its fixed. Plus I don't have a way to drain the existing A/C charge, and NO I'm not just releasing freely it into the air.
haha, you think you had to deal with alot of spotwelds!!! Try having to do the upper as well, and then having to do like 50 more just to use a junkyard upper! I think next time I do this for someone I think I'm going to just put the mig welder on the highest voltage setting and turn the wirefeed all the way down <-------- EDIT:that won't work, stupid me.
Installation begins:
These are the three bolts I was speaking of earlier..14mm the bottom one towards the rear of the car on both sides was a pain.
Impact bar, bracketry, etc..
Almost done...just some trim and lights
Finito
As I said, this was not an easy task. I do not recommend anyone doing this if they have little problem solving skills and mechanical abilities...and a good set of tools. Also once again, Thanks to my Step Dad Brian for all of his help and time. Total reassembly time was 5 hours, so this was a total of 11 hours work time.
Main tools:
- 3/8 and 1/8 drill bit (Or a Spot Weld Cutter)
- Dewalt 18V power drill
- Welder
- Saws All
- 10mm,12mm,14mm,18mm sockets (1/4 and 3/8 drive) AND Ratchet Wrenches (I swear these were made specifically for of our Maximas)
- flat and phillips screwdrivers
- Variety of Hammers and Chisels
- Truck bed coating, undercoating, rust converter, Rustolium paint, PB Blaster, AntiSeize
- wire brush set
- grinder
I bought all the parts from Nissan dealer.
Lower Core Support: 62530-40U00
(2) Bolts:11898-40U01
(2) Bushings: 11243-40U01
Approx - $160 for all if I remember correctly.
A shop will want from $500-$800 to do it for you.
I don't have the fogs in because the one is still recovering from a very personal meeting with a raccoon the size of small cow! (hence the crack on the right, lower side of the bumper cover.)
Thanks! It was a lot of work! I used Truckbed coating mostly. I used some rubberized undercoating, not much. It wasn't 3m or anything special. Whatever WalMart sells. can't remember the name.
so how do you break the spot weld? Need a welder to do this job?
http://www.ingallseng.com/graphics/P...ures/92900.jpg
You can either buy a spot weld cutter (link to pic above), or use a center punch, then 1/8in drill bit, then a 3/8in drill bit and pry with a chisel and hammer.
_the spot welds are mainly where you see the 2 vertical rectangular holes on each side of the radiator, by the sorry excuse for a power steering cooler. They are all around there, mainly connecting nonsupporting sheet metal.You will be able to see them as they look like "dimples" in the sheet metal. Some you REALLY have to look for. They will be in corners, and inside those rectangular holes too.
Thanks! You alls compliments are greatly appreciated to us! It was a lot of work! (As those of you that did it already know!) I couldn't imagine doing the whole support, Kudos to you that have!!
i had the same problem with the support rotting out. i wouldnt even attempt this on my own... much props to those that have done it themselves. the condensor has to come out i believe and its a lot of work,i took mine to a shop and its about $800 for the job. hate to spend that kind of money on maintenace but it had to be done. if yours is rotting out get it taken care of, you dont know when it can totally collaspe.
great job on that. So what kind of welder did you use? and how much for the welder?
I used a Small Lincoln Mig. not sure what model exactly, it was like 400 bucks for it. The wire was Fluxcore (I wanted to use gas, but couldn't get it until Monday and that wasn't an option). Harbor Freight had the wire and it was like $25 for a smaller spool.
Nice, I'm planning on getting a small welder, so I just wanted to know what kind you used.
__________________ 5SPEED swap finally done (3/30/07)
|Popcharger|5spd swap|AE headlights including corners|Kevlo911 STS|RAZO340|Cleared out tails|Ebay Fogs|Clear corners|H-tech on GR2s|Progress RSB|Warpspeed Y-pipe|FSTB|Custom Audi style LED headlights|Custom Catback exhaust|More to come| Shift_Having fun My cardomain site
Thanks! I learned the hard way...doing things the wrong way in my adolescence! Now its the right way or not at all, no matter what/ how much it takes, I'd rather only do it once!! Research and planning FTW!
Anyone having the rust problem but not bad enough for major surgery should check eastwood's website, they have many products for rust control that really work.
.... dammit.. jsut went and checked mine.. same prob.. not that bad.. but isee it starting.. well i guess soemthing else for them to do when the motor and tranny is out..
__________________ WTB: 00-01 shifter linkage/shifter, front mud flaps a32 or a33, real speaker grill (a32), white spoiler led bar, i30 cleared rear brake lights,RPM switch, Side Skirts (paradox/ionic
A write-up of this should be stickied. I'm sure all Snow trudging maxima's may one day run into this.... Unless if you guys are smart now and coat the thing.
