How to replace rear calipers on 98?
All,
I'm planning on replacing the rear calipers on my 98 this coming weekend and was wondering if there are any how-to's? Advice?
Also what is the proper bleeding sequence for a ABS equipped 98 Maxima.
TIA
TIA
It's actually very easy. Two bolts that hold it to the carrier, one banjo bolt and the e-brake cable. It shouldn't take you more than 15 min per side. Just make sure you bleed the system, and dont get any brake fluid on the paint, as it will eat right thru.
Good luck!
Danny
Good luck!
Danny
Have you ever changed brake pads before? If so you bleed out the brakes before hand and same procedure but you have a hose to take out.
Peace of cake. Did mine 2 months ago. Get them preloaded and save your self the wrasslin with the guide plates and pads falling out.
Originally Posted by TsingTsaoNYC
All,
TIA
TIA
Read the damn stickies!
http://www.autozone.com/az/cds/en_us...rInfoPages.htm
If the link doesn't work then go to autozone.com and click repair guide...
jskirwin
06-08-2016 08:49 AM
Huttig2009
09-25-2015 03:31 PM
RealityCheck
08-05-2015 06:18 AM
