Strut Mount question
Hello, my car pulls to the right past 30mi/hr and i can feel every little bump through the steering wheel. I went to get an allignment today, and the guys said that the cause of all that are worn strut mounts (i've had new tokico blues installed, but the strut mounts were re-used). SO, I have new struts, swaybar bushings/endlinks, and new LCAs/bushings, i had them check all of those as well as tie-rods. My left tire shows wear along the outer edge, the right is not as bad, but still shows some wear(new Bridgestone potenzas, btw). So looking around, i see the strut mounts with bearings included, but would that be enough to solve the problem?
http://www.trademotion.com/partlocat...=8&catalogid=1
DO NOT buy KYB strut mounts. Only get OEM. KYB ones die quickly.
http://www.onlyfactoryparts.com/index-main.htm
Buy everything from there or call DAVEB
Originally Posted by heynow
i can't seem to find any other place that has the boots that go on top of the strut...and that rubber piece that goes in between the spring and the strut (sorry, don't know the right names)
The Frye
09-02-2021 11:03 AM
dvcamp
09-18-2015 10:17 AM
