Do I Need new grommets/brackets for my radiator?
Old 06-16-2007, 08:40 PM
Karlzbad's Avatar
I can't find this anywhere, but my 98's radiator is pretty wobbly at the top, the bottom doesn't move. I'm wondering if this has contributed to the demise of my cooling fans. There's a lot of space in the grommets in the brackets which are what stop it from moving any further. I don't know, is it supposed to be like that? I'm searching all over for maxima radiator grommet or maxima radiator bracket and I don't find anything.
Karlzbad is offline
Old 06-16-2007, 08:57 PM
wirelessdude04's Avatar
yea mine too. The top moves around but didnt really notice it... Bottom is secure though
wirelessdude04 is offline
Old 06-16-2007, 09:33 PM
chillin014's Avatar
step 1. go to the dealership
step 2. order desired radiator bushings
step 3. pay them a measely 10 bucks
step 4. install.
chillin014 is offline
Old 06-16-2007, 11:28 PM
Karlzbad's Avatar
step 4. install.
You know I can't find radiator bushings anywhere not a single mention, that's why I'm asking if they even exist or you have to buy the whole bracket from Nissan, and if it's in fact not supposed to have movement built into it.
Karlzbad is offline
Old 06-16-2007, 11:32 PM
slinky87's Avatar
cut some rubber padding its the same thing but your radiator is fine moving a little bit, no damage can be caused from this so why bother?
slinky87 is offline
Old 06-17-2007, 06:52 AM
chillin014's Avatar
i'm telling you they do, because i replaced mine. There are 2 little brackets with rubber bushings that hold the radiator in place at the top. You can buy those rubber bushings and pop them in place of the old ones. the dealership has them.
Old 06-17-2007, 06:54 AM
<3's the all motor section
XJinCT's Avatar
maximaRs have 2 much tork and be rippin radiator bushings in half dawwwg.
XJinCT is offline
Old 06-17-2007, 07:02 AM
chillin014's Avatar
haha i know i shoulda replaced with poly
Old 06-17-2007, 07:11 AM
Karlzbad's Avatar
Isn't this like when you ask a customer service rep a question and they don't know the answer so they just answer some question you didn't ask?
Karlzbad is offline
Old 06-17-2007, 07:13 AM
chillin014's Avatar
yo, chill with the attitude, go check the dealership before they close.
Old 06-17-2007, 07:15 AM
Karlzbad's Avatar
yo, thanks for the response, I was talking about the other guy. My dealership's not open on Sunday.
Karlzbad is offline
Old 06-17-2007, 07:33 AM
XJinCT's Avatar
dude...it doesnt matter for starters. what? your radiator moves 3/4 of an inch making your coolant shaken instead of stirred. coolant dont like that ****?
also, think about it. the engine moves....alot. especially on a fwd car it pulls back. the engine has radiator hoses which go to the engine, if the radiator was put solid and had no play, it would pull and stretch the hoses and they would split. (SEE: EXHAUST SYSTEM FLEX SECTIONS for more information) see where im going with this? its normal, relax. spend your money on some double cheeseburgers instead of radiator mounting grommets and its all good.
XJinCT is offline
Old 06-17-2007, 07:45 AM
chillin014's Avatar
hahah^ **** man...you funny.
on the real...i'm cravin' some double cheese burgers.
mine used to be loose and i just bought the bushings cause they were cheap and I needed something to do. but yeah..coolant dont like that sh*t.
Old 06-17-2007, 01:59 PM
Karlzbad's Avatar
Man, how hard is it to get a simple straight answer in here now. If you know, if they're supposed to be like that or not then say something, otherwise go f--k yourself and your wigger speech.
Karlzbad is offline
hcarter1112
42
07-18-2022 03:35 PM
Miket2006
03-01-2021 03:55 AM
Unclejunebug
04-02-2016 05:42 AM
jchronis2552
09-23-2015 04:57 PM
RWCreative
09-21-2015 11:01 AM
Quick Reply: Do I Need new grommets/brackets for my radiator?
