Battery Post Corrosion....Prevention?
Old 06-10-2007, 07:59 AM
zagato27's Avatar
I've been having a bit of a problem with battery post corrosion on all my cars. I'll pop the cables and take a wire brush to the terminals but it seems to come back. Is there something I'm not doing? Coating the terminals with ?????? Thanks in advance
zagato27 is offline
Old 06-10-2007, 08:05 AM
f550maranello2's Avatar
u need Vaseline....
f550maranello2 is offline
Old 06-10-2007, 08:06 AM
drewsblackmax's Avatar
yep, just rub some vaseline on the termanals and it should be good to go
drewsblackmax is offline
Old 06-10-2007, 08:08 AM
zagato27's Avatar
Originally Posted by f550maranello2
u need Vaseline....
You know, I was thinking of this but was a bit worried about conductivity. Also was thinking of a product that was a bit more "automotive" . If used, would you coat the posts and the cables after attached or coat the posts first then attach the cables? Cheers
zagato27 is offline
Old 06-10-2007, 08:36 AM
Maxima880's Avatar
I kept getting a greenish corrosion that kept returning no matter what I used. I tried cleaning with baking soda then coating with vaseline, dielectric grease, and regular automotive grease. Nothing would keep it away for any length of time until I bought a can of CRC Terminal Cleaner and a can of CRC Battery Terminal Protector. Not a hint of corrosion for about six months now.
Maxima880 is offline
Old 06-10-2007, 10:10 AM
99grnmaxgxe's Avatar
There's also this red grease you can coat it in.
99grnmaxgxe is offline
Old 06-10-2007, 10:16 AM
abomb1987's Avatar
yea wat he said.. just go to wal mart in the automotive section, near the car batteries there is a little red can you can buy
abomb1987 is offline
Old 06-10-2007, 10:53 AM
zagato27's Avatar
OK! It's off to Advance Auto later this afternoon......I'm doing "honey do's" at the moment
Thanks for info! Cheers
zagato27 is offline
Old 06-10-2007, 10:54 AM
zagato27's Avatar
Thanks! I'll check this one out too. Cheers
zagato27 is offline
Old 06-10-2007, 05:36 PM
zagato27's Avatar
Bought the CRC Battery Cleaner and the CRC Terminal Protector. Used the Cleaner and it does a nice job. I'm letting everything dry tonite and then I'll use the Protector. The guy at the auto store said that the Protector comes out red and sticky....says I won't have to worry bout corrosion again
zagato27 is offline
Old 06-10-2007, 06:13 PM
i has college
EnervinE's Avatar
My dad swears to those terminal rings made of felt. He used those and applied generic terminal anti-corrosion gel on the terminals and connectors when he bought his car in 1995. No corrosion whatsoever for 250,000 miles.
EnervinE is offline
Old 06-11-2007, 12:26 PM
MaximaDvr's Avatar
^ yeah autozone or the like makes some kind of terminal covers (they may be felt) i'd try those. Supposed to work good.
MaximaDvr is offline
Old 06-11-2007, 04:41 PM
z32drifter's Avatar
Ditch the lead-acid battery and go with a gell cell or dry battery. One of the reasons I orignally switched to an Optima battery.
z32drifter is offline
Old 06-11-2007, 07:53 PM
TunerMaxima3000's Avatar
I usually clean, apply dielectric grease on the inside of the terminal end and on the terminal, then install, and apply a battery terminal protector. Never had this problem on any of my cars, not a bad idea to reapply the protector/ clean and reapply every oil change.
TunerMaxima3000 is offline
DJLAX152
05-04-2021 11:46 AM
markevans999
09-10-2015 04:29 PM
Colossus
09-09-2015 05:46 AM
Quick Reply: Battery Post Corrosion....Prevention?
