Tire rotation question
All,
Should I rotate my tires or should I leave it to the shop? I have a torque wrench 10-200 lbs. I'm asking this question because the last time I had my tires installed, the dude at the shop broke one of my lug nut stud.
My tires are Yoko Avid TRZ. Are they directional or non-directional? In what way should I rotate (or have them rotated)? Much appreciated.
i would just say try a new shop. at least where i got my new tires they do free rotate and balance for the life of the tires and if they pulled some **** like that (which they did on my civic back in the day) i would just go to a new shop....
and i did when they did to the civic, havent had a problem yet.
I once bought all season tires from Sears and they over tightened my lugs, it was a PITA removing them. If you have the time I would do it myself, that way you can eyeball your pads, rotors and brake lines, unless the shop offers free rotation for the life of the tires. Also, if the shop breaks your studs they should replace them at their expense.
Assuming you know how to properly change a tire, I vote for doing it yourself. Those places that say they do it for free always make you wait forever. You don't need a torque wrench to do this.
If your tires are radials, you should rotate them front to back, same side.
Another good reason to rotate your own tires is because it is very easy to clean your wheels while the tire is off the car, especially the back of the wheels (which probably haven't been cleaned in years). Makes you wheels look great (for awhile).
Ever since they broke my lug stut, I've never gone back to them. They told me that it's "OK" to drive around in short distance without 1 lug nut ... And they told me to wait 1 day to repair my stud ...
Anyway, when I came back, the dude wanted to charge me $50 ... I was like ... wtf. So I talked to the manager and drove off without paying a dime.
Btw, the place was a Merchant's Tires. I believe they are affiliated with NTB
Yeah, I bought a new set of tires at Merchants, and bought into their whole "free rotation" scheme. Five thousand miles later, I made an appointment to have the tires rotated. Showed up on time, sat in their waiting room for almost an hour, and they said it would be "some time" before they could get to my car. I said, "That's why I made an appointment to have this done." They said they were busy.
Reminded me of that Seinfeld where Jerry reserves a rental car and they don't have one when he arrives. "Anyone can just take reservations. The whole trick to the reservation is to keep the car here."
never heard of the place you went to but i would have gone ape **** on them if they tried to charge me.
And that is the correct rotation pattern, if they're directional. If not, then cross the rears, bring fronts back. That's how most every FWD is rotated (and Nissan's recommended rotation pattern), cross the non drive wheels, move the drive wheels back.
Now here is a pretty good scenario:
On my car I bought it with 2 new front tires that do not match the rears. Front are some no name sport tires put on at the dealer and the rears are Good Year all seasons. The rear tires are shredded (unevenly worn). Do you rotate at all or no go?
Sorry if I am hijacking at all
When rotating, until you get a good matching set or at least 4 tires that are in good condition, I'd just swap one side over to the other (assuming none are directional). LF-RF, RF-LF, and the same with the rears.
Originally Posted by pmohr
Unevenly worn by alignment or balance?
MR2 T'd
07-09-2021 05:06 AM
