Engine Teardown trouble
Old 05-29-2007, 05:30 AM
slinky87's Avatar
if anybody has done this before i need to know what kind of socket that gets the damn main caps off so i can pull the crank shaft if anybody knows this, THANK YOU in advance
slinky87 is offline
Old 05-29-2007, 05:49 AM
eng92's Avatar
They would be either e-torx or 12-point. Do you have a picture?
eng92 is offline
Old 05-29-2007, 06:41 AM
slinky87's Avatar
slinky87 is offline
Old 05-29-2007, 07:27 AM
slinky87's Avatar
bump
slinky87 is offline
Old 05-29-2007, 07:54 AM
eng92's Avatar
They are e-torx.
I am thinking E14 or E16.
Measure and check this page
http://www.wihatools.com/torxspec.htm
eng92 is offline
Old 05-29-2007, 09:45 AM
speed racer's Avatar
Slinky. Why you tearing down the block?
speed racer is offline
Old 05-29-2007, 10:42 AM
slinky87's Avatar
cauce im having it hot tanked before i rebuild everything im not half assing rebuilding this engine mine as well do it right the first time
slinky87 is offline
slinky87's Avatar
slinky87 is offline
Old 05-29-2007, 12:51 PM
slinky87's Avatar
anybody know where i can find this socket the idiots at autozone as usual have no idea what im talking about
slinky87 is offline
Old 05-29-2007, 02:31 PM
OnEBadAsSi30's Avatar
They're also called "External Torx" Or E-Torx that Eng92 made...just to simplify for the people at "Dangerzone"
OnEBadAsSi30 is offline
Old 05-30-2007, 10:31 AM
VQ30DET
Zero-K's Avatar
When I ordered mine, it was called a 10mm female torx
Zero-K is offline
Old 02-28-2009, 03:47 PM
timbrooks77's Avatar
Well what is the answer.. what is it im in the same boat I dont know what i need plz help
timbrooks77 is offline
Old 02-28-2009, 03:53 PM
HM_Motorsports's Avatar
External Torx. Craftsman carries a set in most Sears stores, Advance has the set I bought in stock by Gearwrench, PN: 80582
HM_Motorsports is offline
Old 02-28-2009, 04:20 PM
any idea what size? i would rather buy 1 I wont be needing the rest of them
Old 02-28-2009, 04:42 PM
also I cannot start a new thread
Old 02-28-2009, 08:55 PM
I can't help you on the size, however, if you're this far into a motor, I'm assuming that either automotive mechanics is either a hobby you really enjoy or you are doing it out of necessity to keep your car running. In either case, these type of fasteners are becoming more and more popular and buying tools now wouldn't be a bad idea. Tools are a great investment. Just as a for instance, my 1988 Jeep has E-torx for the brake caliper pins. Go figure.
PS Of course, I am addicted to tools and spend almost as much on them as my cars, so maybe you shouldn't take my advice
Old 02-28-2009, 09:03 PM
No more Maximas...
pmohr's Avatar
It's because you're a newb. If you read the FAQ, you'd know this.
Use the newbie thread, don't bump old threads.
Also no reason to bump a two year old thread here. You obviously searched, just not well enough:
http://forums.maxima.org/all-motor/5...-vq-studs.html
pmohr is offline
bryants95max
10-02-2015 12:52 PM
Socalstillen
09-20-2015 11:46 PM
seesole
09-14-2015 12:38 PM
markevans999
09-10-2015 04:29 PM
Quick Reply: Engine Teardown trouble
