you need to change your fuel filter when....
Old 01-18-2008, 01:19 AM
cefiro8701's Avatar
http://youtube.com/watch?v=1gRzFwqu3CM
black gas comes out of it...
...and your car stalls once in a while.
cefiro8701 is offline
Old 01-18-2008, 03:03 AM
Garrick's Avatar
That's awesome. How many miles did you have on it?
Garrick is offline
Old 01-18-2008, 04:29 AM
Sold
JSMax's Avatar
mmmmmm yummy.
Imagine all the crap that is now in your engine.
Regular maintenance ftw.
And maybe a bottle of fuel system cleaner on the next fill up.
JSMax is offline
Old 01-18-2008, 09:50 AM
cefiro8701's Avatar
40k...
it was a bytch to change.
after a while my car started stalling at the light...i knew what was the culprit..
i really hate changing it...but i think i may have figured out an easier way of doing it.
Old 01-18-2008, 10:14 AM
sodie14's Avatar
and whats that "easier way to do it"?
sodie14 is offline
Old 01-18-2008, 10:31 AM
cefiro8701's Avatar
hire someone with smaller hands...
jk.
i have medium sized hands...
i used needle nosed pliers to pinch the hoses right where the filter ends...
it displaces the pressure to that part making it abit easier...
i doubt its profound...i doubt its new...its probably really common but its been two years since i've done it and i've forgotten the tricks to doing this.
Old 01-18-2008, 10:32 AM
wants an I35
ROCKART's Avatar
after reading several posts about how hard it was going to be, as well as hearing from 305blackmax that it will be extremely difficult to get the hoses off for the first time, mine was actually surprisingly easy.
I did it with MOHFpro90 and Silmax00 in about 20 minutes. no leaks !! (we had the airbox off tho, makes it a lot easier to get at)
ROCKART is offline
Old 01-18-2008, 11:00 AM
97SMG's Avatar
Am I missing something here?? We are talking about replacing the fuel filter for the Max right? It should only really take like 10-15 min and there is really no trick to it.....
97SMG is offline
Old 01-18-2008, 12:35 PM
Garrick's Avatar
You'd think so. But with big hands and being lazy after doing a 5 hour overhaul something this easy has now become "Crap how the hell are these two hoses comin' off!"
Garrick is offline
Old 01-18-2008, 01:03 PM
97maximaman's Avatar
I havent done a fuel filter in, ummm, ever. Had the car 7 years in the family and never really came across as being needed.
97maximaman is offline
Old 01-18-2008, 01:50 PM
Husker Z's Avatar
I think a lot of people forget to do the fuel filter. It is easy to forget. I would get it changed asap, you might notice a little more pep in your car's step.
I had mine changed on my last grand prix at 167,000 miles and it was the original fuel filter. It wouldn't come off with wrenches, so I had to cut it off and fabricate a new section of the fuel line. What a PIA.
Husker Z is offline
Old 01-18-2008, 01:57 PM
M in KC's Avatar
Two pairs of forscips one one the supply, one on the discharge to minimize the fuel draining all over the place. If you need to replace the flexible fuel hose at most you need a couple of dollars worth. Good insurance to boot. Most of the time its the factory original stuff that is present anyway and ought to be replaced.
M in KC is offline
Old 01-18-2008, 03:49 PM
cefiro8701's Avatar
it would be much easier to replace the fuel hose than to pull the filter off with your bare hands...
...turns out it wasnt the filter causing the stalling-
MAF.
440$ down the drain.
Old 01-19-2008, 08:02 AM
Sounbwoy's Avatar
100,xxx fuel filter change...
http://www.flickr.com/photos/sounbwo...7600904583001/
Sounbwoy is offline
Old 01-19-2008, 12:55 PM
andrei3333's Avatar
207.000+ KM, never had any issues or stalling with it though...it filters better when its dirty, until it completely clogs, i do not think it affects the fuel pressure enough to over heat the fuel pump tho...i believe the sediment to be fuel tank rust and other components deteriorating.
andrei3333 is offline
Old 01-19-2008, 08:53 PM
KRRZ350's Avatar
IByourCARdoesntHAVEantilockbrakes
KRRZ350 is offline
Old 01-20-2008, 11:26 PM
ThurzNite's Avatar
What color is fuel supposed to be?
What brand are y'all using?
Dr J
ThurzNite is offline
Old 01-21-2008, 12:46 AM
The self-oil changing max
mevjen's Avatar
Dr J
Not chunky and brown, that's all I have to say...
mevjen is offline
Old 01-21-2008, 03:14 AM
Maintenance Monster
dgeesaman's Avatar
I can see I'm not the only one who found rust in their fuel filter.
dgeesaman is offline
Old 01-21-2008, 05:11 PM
andrei3333's Avatar
which begs the question what grade steel is the fuel tank made of ?
its not supposed to rust, but it does, rather slowly, but still...I think i was wrong when i said i never had any issues with the dirty FF...I remember the first winter i owned the car, on really cold days/nights (ie; -10C or lower) it would crank, and almost catch on fully, the rpm would go wild and die unless i hit the gas...not that i think of it after i replaced the FF it never happened again...
Whats the freezing point of gasoline ? and does it become thicker at -10C or lower ? cause i think with an almost clogged filter the very thick gas flows a lot slower...
Old 01-21-2008, 08:22 PM
Pyrex42's Avatar
I work part time at jiffy lube. N i hate doing maxima fuel filters n altimas. old gms are even worse all they do is rust.
oh if u want better fuel economy. get a 2 or 3 step fuel system cleaner. the 1 that hangs and goes into a vacuum line ie; brakebooster. the liquid stuff not aerosol
Pyrex42 is offline
Old 01-21-2008, 09:31 PM
TunerMaxima3000's Avatar
as long as you relieve all the fuel pressure, this job is not bad at all. Mind you it did take about 10 cranks, starts, etc to relieve the pressure.
if you're really having trouble, pour some hot azz water on the hoses it will help. but honestly guys this is an easy job.
TunerMaxima3000 is offline
Old 01-21-2008, 10:09 PM
a.k.a. STuNtMAN
JonBlz's Avatar
i put a Z32 fuel filter in my max nd its lovely absorb much more dirt nd everything
JonBlz is offline
Old 01-22-2008, 10:04 AM
oVeRdOsE's Avatar
Me too a 300zx tt. Of curse my old filter was dirty (same as the video), but a get a better throttle response with the new filter.
oVeRdOsE is offline
Old 01-25-2008, 07:06 PM
Dynasty47x1's Avatar
How much does jiffy lube charge for that?
Dynasty47x1 is offline
The Wizard
24
10-01-2015 08:47 PM
JoshG
51
09-21-2015 10:41 PM
bumpypickle
09-20-2015 08:22 AM
aminus21
09-12-2015 04:53 PM
sdotcarter
09-02-2015 09:53 PM
Quick Reply: you need to change your fuel filter when....
