LSD Tranny
thats awfully vague. you should be more specific. and try searching. and this may help:
http://forums.maxima.org/showthread.php?t=328969
PM Ptatohed. He just did a ton of research on this topic, and it's all fresh in his head. His car is in the shop getting a VLSD tranny as we speak. And I know he'll be happy to help.
Or use the free search, it will teach you everything you need to know.
I have a 5 speed, but I'm 50% sure my diff is getting messed up, but I live in florida and I have no idea where to find an lsd tranny and wat cars are they from. Ive read that they are from canadian maxes and I30, and possibly the altima. however I really dont understand the different types of lsd tranny and which one is better
Your right, the vlsd's are in canadian max(es-super rare) and 5peed I30's. IMaybe these links will help. I got them using the free search, its pretty helpful.
http://forums.maxima.org/showthread....ght=maxima+lsd
thanks alot, I have been searching and i cant find anything. I can see this is going to be difficult
www.car-part.com is where i found my 2001 vlsd ae tranny.
I've rebuilt a number of the 4th gen trannys. Far and away, the most important factor is the condition of the bearings inside. A standard 4th gen tranny with good bearings is stronger than a 2001AE with worn bearings. I urge you to at least get the tranny inspected by a tranny shop (have them spend an hour to open it and poke around) before installing it. Many used 5 speeds are in dire need of a rebuild, and if you put a tranny like that in your car you could shred the gears on a hard launch.
Yes, there is a vin on each tranny.
Dave
I actually managed to get mine off ebay.....Dude selling it stated that there was something wrong with his transmission because his axle kept popping out. He had taken it to different mechanics and they all would keep replacing the axles. Oh man did I jump on this deal right away. I called him, had him pull off the listing cause I knew he was a fool. I paid the poor guy $100..............Half a year later no problems........
I'm guessing every time they replaced the axles, they were putting the wrong ones one.(Non LSD) Other than that maybe they weren't installing them to where the snap ring was engaging, but not sure.......
just a question out of curiosity what option do we have when the VLSD decided it doesnt want to be an LSD anymore? I believe I heard Quaife is going to stop making LSDs for the max and Phantom Grip is not the best of options, also Quaife said that the diff will only work on a non LSD tranny are they just trying to safe guard people from making silly mistakes or it actually will not work on a tranny that has had an LSD in it?
quaife stopped making maxima diffs a long time ago. the transmission case on the VLSD trans is completely different, the quaife won't work in it.
you can replace the differential, or get an open diff trans and put a quaife or phantom grip in it. i don't advocate the use of phantom grips though.
Got auto, got lsd. Youre definately making the right choice here, lsd is soooo much better than open (I drove open for a while before getting the lsd with my new tranny). Ugh, should have switched to manual while at it
Are you putting it in yourself?
