Go Back   Maxima Forums > Maxima Discussions > 4th Generation Maxima (1995-1999)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Timeslips Members Parts Guide Search Today's Posts Mark Forums Read ExperienceUsed CarsGarageVendor Directory
Search
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Search this Thread Display Modes
Old 04-05-2007, 11:55 AM   #1
brakes sticking
ok heres the deal...
replaced front pads, rotors and calipers. I still have sticking issues w/ my brakes. They are rubbing up front and I dont know what else to check. Just to clarify, I know it is the front brakes that are rubbing. any thoughts?
__________________
On a slow path to modifications...
nismo-max500 is offline   Reply With Quote
Old 04-05-2007, 01:45 PM   #2
Points: 11,772, Level: 71
Points: 11,772, Level: 71 Points: 11,772, Level: 71 Points: 11,772, Level: 71
Activity: 0%
Activity: 0% Activity: 0% Activity: 0%
Send a message via AIM to ImmaSquashYou
change ur fluid?? Could be the master cylinder thats pushing out on the calipers. Don't know why it would do that, but that could be an option..
__________________
ImmaSquashYou is offline   Reply With Quote
Old 04-05-2007, 01:55 PM   #3
Send a message via AIM to heynow
did you bleed each caliper? Proper bleed?
heynow is offline   Reply With Quote
Old 04-05-2007, 01:58 PM   #4
It might not be your brakes, it could be the dust plate behind the rotor that is scrapping, that happened to me so you might want to check that
Keatz is offline   Reply With Quote
Old 04-05-2007, 08:32 PM   #5
Points: 8,611, Level: 62
Points: 8,611, Level: 62 Points: 8,611, Level: 62 Points: 8,611, Level: 62
Activity: 1.6%
Activity: 1.6% Activity: 1.6% Activity: 1.6%
Also there are 2 springs on each front caliper that push the pads apart so they are not rubbing the rotor when the breaks are not engaged
Did u reinstall these springs ?
andrei3333 is offline   Reply With Quote
Old 04-06-2007, 04:47 AM   #6
Maintenance Monster
Points: 12,837, Level: 73
Points: 12,837, Level: 73 Points: 12,837, Level: 73 Points: 12,837, Level: 73
Activity: 0%
1) Verify the caliper slider pins move freely. The grease in these often gets dried out and causes excess pad drag.
2) Brake pads ALWAYS rub on the rotors. There should be no pressure between them, but they will always appear to be in contact, and when you spin the wheel you can feel it. This is normal.
dgeesaman is offline   Reply With Quote
Old 04-06-2007, 05:41 AM   #7
Activity: 1.6%
My bad yes you are right, but I thought those two pins were there to prevent that. So isn't it bad that the pads are always rubbing the rotor's ? wouldn't the pads die quicker like this ?
i understand thats how nissan designed them but i am not understanding this design.
Also i noticed that before i replaced my front pads the break fluid was a bit down, approximately 1/4 away from FULL level, I assume this is because the caliper is pushing the pads against the rotor and as the pads wear out the caliper pushes just a little more and the fluid goes down. THANK god i never topped it up because when i replaced the pads the fluid was at the exact MAX line. So it is a useful tool to measure when to change your brake pads by looking at the brake fluid level ?
Old 04-06-2007, 05:52 AM   #8
Points: 8,887, Level: 63
Points: 8,887, Level: 63 Points: 8,887, Level: 63 Points: 8,887, Level: 63
Activity: 1.8%
Activity: 1.8% Activity: 1.8% Activity: 1.8%
The fluid level is set like that from the dealer. Unfortunately, a bunhc of people keep telling folks to "top up" their brake fluid like it is motor oil. The pads are not rubbing against the rotors all of the time, they are just very close. There may be some minimal contact but not enough to create significant wear. Those springs you were referring to help to minimize that contact when the brakes arent applied but cant be used with certain aftermarket pads.
As for why it is designed that way, braking needs to be immediate, especially when you are dealing with a hydraulic system. If there is a wide gap between the pads and the rotors, then braking response would be drastically reduced (think about how you had to pump your pedal when you changed your pads).
Did you flush yoru fluid? It is often neglected and most people dont realize it is supposed to be clear and not brownish (or god forbid greenish).
2da mizzax is offline   Reply With Quote
Old 04-06-2007, 06:09 AM   #9
Activity: 1.6%
No, i did not flush the fluid, i am afraid to even open the bottle because i dont want to contaminate it.
It is on my to do list though, along with a coolant flush. the thing is that i dont want to flush the coolant because if my thermostat fails i will need to flush the coolant again, so since i just did the brakes i think i rather flush the brake fluid first and then do the coolant.
My coolant looks like crap in the resevoir bottle with weird dirt in it and possibly some other gremlins. The brake fluid through the see through bottle does seem kinda dark its definitely NOT transparent as far as the colour its hard to tell.
What is more important?
Old 04-06-2007, 06:35 AM   #10
Activity: 1.8%
its not a matter of importance. Coolant needs to be changed ASAP if it looks "crappy". If you flush it (or get it flushed) and the thermostat fails, you wont have to flush it again. you simply drain some out, change the thermo and pour the stuff you drained back in.
Brake fluid flush is cheap if you are doing it yourself. all of $5. You will need a helper or you will need to buy a set of speed bleeders.
Old 04-06-2007, 06:44 AM   #11
Activity: 1.6%
Alright, im going to get both done next week then after the long weekend, screw this i want my car to be like new.
Just that i have to keep reminding myself that its a 10 year old sedan and things will tend to break down more often then not and that rust is starting to get to it underneath the car not the body yet. So thats what makes me hesitanat to spend more money on this car
Old 04-06-2007, 06:57 AM   #12
sky jumper
Quote:
so what is the deal with puke green brake fluid? I've seen this on other cars. a friend's 2k blazer had nasty greenish fluid, so I helped him flush it, and 4 months later it was puke green again.
what causes this? I'm assuming contamination, but contaminated with what?
Old 04-12-2007, 04:39 PM   #13
well the whole break burning thing is more than likely its a sticky caliper, because ive had that problem with about 3 of my cars including my max, basically the caliper is pushing out but not pulling back the piston is getting stuck, so yea i would check which wheel has the least pad left on it and thats your bad caliper, replace it, problem solved
samax89 is offline   Reply With Quote
Old 04-12-2007, 05:10 PM   #14
Activity: 1.8%
I have seen the same thing on a few GMC trucks. Copper corrosion (although the wrong shade of green). I thought it was algae from too much water being absorbed. Only other thing I can think of is that GMC may have had a factory brake fluid that was green in nature. I heard of Castrol making a certain brake fluid that was green and that may have been GMC's factory fill. Over time the dye/solutes may have fallen out of solution.
__________________
Anyone willing to trade a Koenigsegg for a Maxima?
MaximaOrg
Nissan Maxima
Paid Advertisement
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
Emails Backup
Search Engine Optimization by vBSEO 3.5.2
