So I'm thinking about buying a Y-Pipe
Old 04-11-2007, 01:28 AM
dhaney's Avatar
so I'm thinking about buying a y-pipe, but i need to fix some o2 sensors and codes so i can pass smog. can i get a y-pipe before I fix these, or is it even harder to pass smog with the y-pipe on. can you pass smog with a y-pipe on, or is this a very stupid question.
Also, how much is the average price of y-pipes. What is your favorite and why?
Do I need any other parts to install it, or just the pipe itself. How long does it take to install? Thanks for the help. Just a couple questions. thanks. Is there any bad things about having one. Does it make your car sound ricey at all? I know these are stupid sounding questions, but I don't care. Thanks again
dhaney is offline
Old 04-11-2007, 02:19 AM
killerVQ30DE's Avatar
killerVQ30DE is offline
Old 04-11-2007, 02:27 AM
shadyonedeath's Avatar
Oh, Hi Dhaney!
shadyonedeath is offline
Old 04-11-2007, 02:32 AM
Maximoneypit
NCSU_MAX's Avatar
to answer your questions:
1. I would replace the sensors by installing them in your new y-pipe and then install it. You will have to drive around a little before inspection to heat up the pipe otherwise you might not pass emissions since the aftermarket pipe eliminates 2 pre cats.
2. pricing - bout 100 used. anywhere from 150-350 new (Warpspeed, Budget, Stillen, Cattman). I love my WSP.
3. Pipe should come with gaskets, hangers, and bolts
4. Install depends on how rusty your old exhaust is (1-3 maybe 4 hours) Also depends on how mechanically inclined you are.
5. With just the addition of a Y-pipe you prob wont notice much in exhaust tone.
Grant
NCSU_MAX is offline
Old 04-11-2007, 10:01 AM
markd248's Avatar
I'd replace the o2 sensors do the inspection then install the Y-Pipe. I installed my Warpspeed Y a week ago it took about 2 hours with the car up on ramps and by myself. Go to the Exhaust Sticky it has a lot of useful information for you to help with the Y-pipe.
markd248 is offline
Old 04-11-2007, 10:03 AM
dhaney's Avatar
ok. thanks guys. all questions answered.
dhaney is offline
Old 04-11-2007, 10:14 AM
Black Lion
maxprivate's Avatar
you will pass emissions no problem as long as codes are gone with y pipe. i had greddy sp1 along with budget y pipe from Canada and passed no problems. by the way my y pipe is for sale pm me if you are interested.
maxprivate is offline
Old 04-11-2007, 10:29 AM
1FSTMAX's Avatar
fix your o2 sensors first... then go do a smog check, make sure you pass, and then think about installing a y pipe.
I have not been able to pass a smog check with a aftermarket y pipe installed in either my 97 or 99.
1FSTMAX is offline
Old 04-11-2007, 12:12 PM
Black Lion
maxprivate's Avatar
i dont know why you didnt pass. maybe something to do with the state you are in.
Old 04-11-2007, 12:31 PM
MorpheusZero's Avatar
If your car is cold you might not pass smog. The precats are there to work before the main cat warms up, and eliminating them (which is why i'm no longer so hot on ypipes) means your car will pollute a LOT when it's cold.
MorpheusZero is offline
Old 04-11-2007, 01:54 PM
maxima985spd
if i were you i wouldn't buy a y-pipe because you wont pass inspection
not kidding.
ok, im kidding buy one.
Old 04-11-2007, 05:01 PM
dhaney's Avatar
are any of the 02 sensors eliminated by installing an aftermarket y-pipe. anybody know of anybody whose selling one. and whats an evap purge cntrl valve.
dhaney is offline
Old 04-11-2007, 05:06 PM
2da mizzax's Avatar
why dont you go read the stickies or the 34534509358094 threads on Y pipes?
2da mizzax is offline
Old 04-11-2007, 05:11 PM
JeremiahMaximaSE's Avatar
I passed inspection with mine!
I passed my inspection w/ a y-pipe, hi-flow cat, & a flowmaster exhaust in Connecticut only about a week ago. Just FYI! Lata.
-Jeremiah "J$"
1995 Nissan Maxima SE
JeremiahMaximaSE is offline
Old 04-11-2007, 05:34 PM
Can't believe the OP got so much help considering he has asked nothing original and not even bothered to read the other zillion Y-Pipe threads.. Even asks if someone is selling one.. sounds like :attention
Old 04-11-2007, 07:43 PM
dhaney's Avatar
because i haven't been on in a while and I can't use the search function. I kinda forgot where it would be
dhaney is offline
Old 04-11-2007, 08:16 PM
99BlackMaxMS's Avatar
LAME excuse...because the search function is on the top toolbar under free search. Its not the greatest...and ive heard for the $20 donation its rly worth it. I will eventually donate when I need to do serious work on my car.
99BlackMaxMS is offline
Old 04-11-2007, 08:22 PM
1FSTMAX's Avatar
I'm in cali so go figure. And it didnt matter if my car was cold or not, it wouldn't pass.
1FSTMAX is offline
Old 04-12-2007, 12:07 PM
Offset Is Everything.
MrDicks95SE's Avatar
dhaney- no, none of the 02 sensors are eliminated with an aftermarket pipe. and also make sure whether you are a fed spec or cali spec. a great site to check out is http://maxmods.dyndns.org/ evap purge control valve is part of the evaporative emissions stuff. not really sure what it does but it has to do with emissions. if youre showing a code, definitely get that straightened out. any type of cel will fail smog checks. check out this site: http://forums.maxima.org/showthread.php?t=104931
MrDicks95SE is offline
Old 04-12-2007, 03:38 PM
nissanMAX2NV's Avatar
I just ordered the warpspeed y pipe. I am installing this weekend.
I am running a stock cat and Megan racing cat back exhaust. definately worth it.
I paid 199 for the y pipe. It is an easy install for the average wrencher. I have never had trouble passing emissions yet (without y pipe on).
nissanMAX2NV is offline
Old 04-12-2007, 04:01 PM
MaximaDvr's Avatar
I am SO tempted to buy one. I think it's just a matter of time before I convince myself to get one.
MaximaDvr is offline
Old 04-12-2007, 04:24 PM
maxima985spd
wowwy good for you, you'll be the 10000000t8th person to buy one
Old 04-12-2007, 04:27 PM
MaximaDvr's Avatar
I think I'm detecting some sarcasm here. Not sure why. I'm also having trouble making sense of that 'number.'
matts95max
09-09-2023 01:52 AM
crazyespn
09-03-2015 01:30 PM
iflexsteel
09-02-2015 08:04 AM
A32goldylocks
09-02-2015 06:39 AM
Lowered_a33
09-01-2015 07:49 PM
Quick Reply: So I'm thinking about buying a Y-Pipe
