MAF sensor needed ? ? ?
Old 04-08-2007, 06:04 PM
NookieMax's Avatar
I recently replaced the harness to the MAF because the old one was cracked, but I'm still having studdering issues.
If I give the car time to warm up and I take it easy on her, it seems to be ok, but randomly it'll start to studder like it's going into idle mode and back to regular. My CEL keeps giving me the MAF code.
so maybe my MAF sensor is bad?
is there a way to test the sensor?
does anyone have a good sensor I can buy?
thanks guys
NookieMax is offline
Old 04-08-2007, 06:09 PM
dot dot dot ...
NmexMAX's Avatar
www.car-part.com
NmexMAX is offline
Old 04-08-2007, 06:17 PM
willard00's Avatar
now its time for the lol. what is the exact code? i know there is a way to test the MAF by testing the voltage or something...but i dont know what the voltage is supposed to be. maybe someone else will chime in and help out with that...
willard00 is offline
Old 04-10-2007, 07:10 PM
NookieMax's Avatar
Originally Posted by NmexMAX
I'm guessing it would be listed as an Air Flow Meter?
anyone have any idea what resistence the sensor should read? is there another test?
Old 04-10-2007, 07:15 PM
dot dot dot ...
NmexMAX's Avatar
Voltage test is better.
In the Haynes/Chilton/FSM.
If I were you, I'd get one off of that site and call it good. They can be had for less than 45$ shipped.
In the meantime
http://forums.maxima.org/showpost.ph...4&postcount=15
NmexMAX is offline
Old 04-10-2007, 08:40 PM
maximacruizer's Avatar
expensive but here ya go http://parts.autopartsonlinecanada.c...ir+Mass+Sensor
maximacruizer is offline
Old 04-11-2007, 06:16 AM
NookieMax's Avatar
cool, thanks for the info guys.
I think I'll pass on the parts from Canada just because of the price, but I'll test the sensor and re-do my connections as well.
Old 04-12-2007, 04:12 PM
NookieMax's Avatar
I tested the MAF with a voltmeter today and it was right on target with the numbers provided, thanks NmexMAX.
I'm going to drive around and wait until I have problems again and test it then again.
I'm thinking that maybe the wires I twisted together are expanding when they get hot and causing a bad connection, either way, at least I'm getting somewhere now.
Old 04-12-2007, 04:24 PM
MaximaDvr's Avatar
MAF Sensor
Ha, i just made a similar post in another thread about this. Basically, i suggest cleaning ur MAF sensor before buying a new one. I cleaned mine and it worked wonders. You can get a can of MAF sensor cleaner from the auto parts store for like 6-8 dollars. Here's a link to a video showing you exactly what to do. I cleaned my by disconnecting the rubber pipe at the TB since I was cleaning that anways...I think it was quicker too.
http://videos.streetfire.net/video/4...6f015c3dac.htm
MaximaDvr is offline
Old 04-12-2007, 04:34 PM
'96 B-rad's Avatar
Could a bad maf sensor cause my car to stall when I switch to reverse or from reverse to drive?
'96 B-rad is offline
Old 04-12-2007, 05:13 PM
2da mizzax's Avatar
I may have one for sale.
2da mizzax is offline
vingodine
45
05-21-2016 12:46 PM
smplyamzng
12-13-2015 01:19 PM
TonyJr
08-20-2015 12:14 AM
vanebecker
08-19-2015 09:45 AM
Quick Reply: MAF sensor needed ? ? ?
