08-31-2008, 01:29 AM
#1961
i think dreamcatcher is on the right track, speed limiter i believe is in the ECU that wont let the car accelerate anymore, not really sure about that but i think its worth looking at.
08-31-2008, 10:50 AM
#1962
Quote:
Originally Posted by DreamCatcher
Is it a US version? Does it have a speed limiter?
Yes the car is US version. Ive heard people on here say they didn't have speed limiters on them.
08-31-2008, 12:07 PM
#1963
Quote:
They do have speed limiters. This is how you can remove them:
http://www.vqpower.com/v2/readarticle.php?article_id=38
This can also be found in the "Mechanical/Maintainence" sticky.
08-31-2008, 03:47 PM
#1964
only the gxe model came with a limiter, gle and se don't have them. i have a gle and can get up to about 140 by running up to red line with od off and the switching it on...takes a looong time. try getting up to red line in 4th and the shifting into 5th.
08-31-2008, 04:58 PM
#1965
Yea I'm trying to figure out why the car is weak around 6000k-redline, i mean in 1st 2nd 3rd it is, this isnt your average over rev, it like dies at 6krpm, and struggles to get to redline
08-31-2008, 05:14 PM
#1966
might be air flow issue, clogged injectors, weak coil etc. plus the stock intake manifold is not very hp productive in high rpms at high speeds.
08-31-2008, 05:19 PM
#1967
Quote:
Originally Posted by Rob20
Knock sensor -98 maxima auto 170k miles
i want to know if this will fix my problem or not. I recently got the codes from my car and it only said that my knock sensor was bad. Sometimes the car will just die on me out of nowhere.. sometimes while changing gears.. while going slow..in park, at the stop light.. my usual rpm on drive is around 500-600rpm in first(is this the iddle speed?..yes im a noob :P) so anyways i was wondering if i replace the knock sensor on the car will it fix my problem? is there a good chance that it could be. is my RPM normal
also my brake pads dont have any anti rattle springs am i suppose to have them? I have tried many things to stop squealing from my car could this is the problem?
put a 470k ohm resistor in the ks harness plug, reset the codes and see if it helps. if it does than yes, you need a new ks. 500-600 rpm might be a bit low at idle - which is in N or P. the rpm will drop a bit in D if you have an AT. normal idle rpm is about 650-700rpm.
squealing from brakes most the time comes from crappy pads or dirt - spray some brake cleaner on the rotor and pads and see if it helps.
09-01-2008, 01:24 AM
#1968
how exactly do you put the resistor in the harness plugZ? is there a special way? where is the harness plug, 470k ohm resistor where can i pick one up, is it expensive. reset the codes throught the code reader thing? reset as in erase code? normal rpm in P is like 800-900 drops to like 500-ish in D..tonight i had it in park and rpm was weird 700 to 500 moving around then dropped to like 300 looked like car was going to die then it rose to 400 wtf is wrong with my car  . close to giving up...and ram it against a semi.. o also can a bad knock sensor turn off my car?
and i switched to OEM akebono brake pads and squealing has dropped dramatically almost completely. price diff was like $50 thought..
btw sorry for so many questions i am a car noob ++
Reason: addwd
09-01-2008, 04:08 PM
#1969
get on the 4th gen forum and you'll see 2 threads, one about the 470k resistor which'll tell you exactly how to do it. and a second one about the iacv cleaning - this migh solve your idle issues.
the resistor is under $2 at radioshack just make sure it's 470k ohm. a bad ks won't shut the car off. is your check engine light on? can you get codes pulled/cleared at a local autozone?
the ks harness plug - follow the cable from your ks up the line, first plug on it is the harness connector.
09-01-2008, 07:59 PM
#1970
hey, is a 95 a fourth gen Noob....
Maxima wiring harness is way to hard to change.
09-01-2008, 11:16 PM
#1971
noob means you're new and most likely don't know much, yet
pull the starter and get it tested at a parts store - they'll tell you what's up for sure.
09-02-2008, 07:53 AM
#1972
Power steering
I wanna to change my power steering fluid, I read a couple of threads on this topic, my question is they say I have to put there Dexron II or Dexron III such as Mobil 1 ATF or Amsoil ATF, isn't it the automatic transmission fluid or this exactly what I have to put there?(Jus want to be on a safe side)
And how exactly do I emty the power steering system, which hoses do I have to disconnect?
09-02-2008, 06:17 PM
#1973
Hey all, I have a very embarassing question to ask. I currently own a 98 Maxima SE. I'm wondering, how do you turn the AC on? It may seem like a stupid question, but I'm not sure how the digital fan settings work. It will go as low as 18C, but thats it. Even then it blows luke warm air at best. Now I've put up all summer with just keeping the windows down, since the weather hasn't been too bad with all the rain... but this rash of hot weather has made me wish it was working. It could very well be that 18 is as low as it goes, and the AC should be on, its just out of refrigerant, but I'd rather ask a free online question than take it to a shop for a test. Thanks a lot guys!
09-02-2008, 06:53 PM
#1974
I have a 99' SE 5spd with the Bose headunit. Does this thing have an AUX port in the back somewhere? I'd like to hook up my mp3 player. Thanks guys.
09-02-2008, 07:02 PM
#1975
it doesn't but iirc there's a write up in the stickies on how to add it.
09-02-2008, 07:11 PM
#1976
Ok well I don't know very much at all about cars, not saying I don't like them...I love certain cars for there look or how they perform....but my big brother (alicious) loves cars and so I wanted to learn. My question to start out with is what do you think the top ten things are that I should learn first about cars?  thanks
09-02-2008, 08:27 PM
#1977
J30 > A32B>A32
yes it is the same as the fluid in your automatic transmission.
Quote:
yes you are probably out of R-134a. the system is designed to automatically turn on the A/C as required by your temperature setting.
__________________
Maxima parts catalog
98 I30t Silver on black A/T here | 79 Camaro sold
96 Granite Pearl (AKA Purple) A/T gone
92 grey VE A/T gone | 92 maroon VE A/T gone
92 white VE M/T gone | 92 grey VE A/T gone
Quote:
Originally Posted by Benstoked
he is worth his weight in platinum plugs
09-03-2008, 06:31 PM
#1978
I recently went to get my 95 SE inspected, and was told I needed my steering rack/pinnion was leaking. And it would cost $800 to fix. Is this reasonable and something that is usually expensive?
09-04-2008, 11:29 PM
#1979
Try to find out how much the part costs. This will give you a better idea of what they are charging for labor....
I have a noob question you you. My 95 will not turn over.  The starter is good.. Battery is good . Battery terminals are clean and tight.But.. I'm not getting power from the black/red wire at the starter solenoid. what should I check next?? Just bought the book today so I hope that will help narrow it down too. Thanks and Aloha!!!
09-04-2008, 11:41 PM
#1980
u need a upgraded Intake plenum...they are called MEVI and 00VI..and the search option will be ur best friend
__________________
95 SE (VQ35DE EATER) - 96 GXE (Weekend Fun) - 98 GXE (Daily Day/Grocery Getter) = sold
myspace.com/shady_aftermath_
Quote:
Originally Posted by irish44j
khantalha, in case you didn't see my other post - your signature is not appropriate for this forum and needs to be deleted. Please take care of it...
Lots of NEW/USED 4th Gen Parts , Click here, if dont see what ur looking for then PM me...
09-06-2008, 02:52 AM
#1981
Got the Maxima running today. The back two screws were loose on the ignition switch.. Thanks for all the input you noobs!!!!!
Na much love. Next time you see a Taurus pass you it just might be a SHO.. Aloha....
09-06-2008, 11:30 AM
#1982
in the cylinder firing order where is cylinder number six? my check engine light is on and it's telling me that cylinder #6 is misfiring.
also are there any thread on how to replace your O2 sensors and your EGR system?
09-06-2008, 12:03 PM
#1983
where to buy new cupholders
Hi everyone! I'm new here obviously. I just bought an older (1997) maxima and I love it. Except for one thing. The cupholders in the front are just the size for soda cans but aren't big enough for water bottles or anything even slightly bigger. The cupholder thing seems to pull right out, so I was wondering if there is any kind of aftermarket piece I can buy to replace it with bigger holes for bottles.
Thanks!
Susie
09-07-2008, 02:30 PM
#1984
new question
I own a 1995 maxima gxe and for the time being, its off the road. I want to rebuild the engine before i upgrade to turbo/nos. are there any good write ups or something that could help me along the way? ive never rebuilt a v6 before. and im hoping that its not much harder.
please & thanks
-bryan
09-07-2008, 05:40 PM
#1985
Ok since theres not an all motor noob thread, I'll post this here. I'm planning on putting 3.5 cams in my 3.0 and I had a question about the install. I know you need the adapters, but I've read that they also needed to be drilled, about 183 deg. Is this true, and how would I go about doing this?
09-10-2008, 08:36 AM
#1986
