04-24-2007, 08:41 AM
#121
Ignition Coil Boots?
Can I replace the ignition coil connection boots ( http://www.autopartsauthority.com/pa...1&make_code=NI) or do I have to replace the entire ignition coil? I was told by a mechanic that only the boots need to be changed and not the entire coil. Any clarification greatly appreciated.
Thanks!
04-24-2007, 10:56 AM
#122
Hey.....
Been searchin the forum for a while now to find this answer but i needed to know...
i got into a minor car accident over a month ago, and now my front bumper is a little misaligned. the notch that was under the headlight is now out and i was wondering what where the steps to removing the bumper and putting back on correctly so that everything lines back up again? i didnt just want to start tryin to figure it out and end up lookin like a fool(dont have alot of time for trial and error at the moment and dotn want to go to a shop) so i would rather ask first.. THANKS
04-24-2007, 12:26 PM
#123
Quote:
Originally Posted by DomoMaxima98
Hey.....
Get the Haynes manual. Goes through uninstall and install. You'll probably need a new bumper tho. Unless you don't want a new one of course.
__________________
SHIFT_my daily driver
LED Tails for sale- please pm me
04-24-2007, 12:39 PM
#124
^^ Thanks... don't want a new one right now just wanna make the one i have look good for now.. it has some marks on it from the accident but ima just do some research and wait before i start doing any modifications.. and when i do it will be engine mods first...
i know they sell them at Autozone so ima just go and pick up a copy.. i was lookin to see if anyone could take me thru it step by step for free tho lol...
04-24-2007, 03:25 PM
#125
Follow up question to post #121
When I drive the car it feels fine, but when I stop and accelerate it feels like the car is missing. Is this related to the ignition coils? I changed two coils last summer.
Thanks for any help / advice!
04-24-2007, 07:24 PM
#126
test your coils and see if they are all working correctly.
__________________
04-25-2007, 09:56 PM
#127
Quote:
Originally Posted by dgeesaman
Did the car ever have the Bose system at any point?
Dave
I don't think so. The speakers I pulled out were Panasonic, of the cheap paper cone type.
I fixed the worst of the sound problem with a bit of tuning in the head unit. Still not overly impressed with the bass response, but at least they don't sound like they are going to explode.
Still not sure if replacing the head unit would help, or if I should go full on with an amp and sub.
04-25-2007, 11:10 PM
#128
Quote:
Originally Posted by Byronape
Ok, I have an audio problem.
When I picked up my Max, it had a Pioneer basic style head unit already installed. I recently installed a set of Pioneer 4-ways in the doors and rear deck.
Here's my problem. I know that I won't ever get great bass out of the 4-ways, but when ever I adjust the sound so that I get any, the speakers sound like they are about to blow. I turn down the bass and the mids and highs sound great. When I set everything to reasonable levels, the bass still sounds like crap.
Would getting a better head unit improve things? I know that I won't get great bass without an amp and sub, but my last two cars had decent bass and clear sound without an amp or sub. I'm not looking to rattle the glass out, just enough to enjoy my music.
take out the speakers and check if u did nto cross the +/- wires, in reverse u loose base (operating bi-polar). if not then take out the pioneer head unit, inspect the wire harness and see if any +/- SPEAKER TERMINAL wires were crossed at that point...
__________________
Toronto Maxima Enthusiasts Club (TMEC)
Keepin' it all JBL
04-26-2007, 10:19 AM
#129
Quote:
Do you have a link on how to test them?
Thanks!
04-26-2007, 03:03 PM
#130
Thanks!
Manual tells you how to do it.
__________________
04-26-2007, 07:37 PM
#131
recently my clutch pedal has become very easy to depress n there is alot of slack i guess u could say before the clutch is engaged, wat would you say this is and if the clutch is still being engaged and disengaged should i be concerned
04-26-2007, 09:36 PM
#132
I own a '96 Max and I'm having trouble opening my trunk, the valet switch isn't turned on, the only way I can open it is if I have someone pull and hold the trunk lever on the floor on the drivers side while someone else pulls up on the trunk. Could my trunk be too heavy because of the spoiler? It's a stock spoiler.
04-26-2007, 09:45 PM
#133
no its not too heavy it was designed to open with the spoiler on, check the trunk latch / lock -- lubricate in necessary
04-26-2007, 10:43 PM
#134
Quote:
haha really??! its a stock spoiler. The trunk is designed to open with the spoiler on. You probably just need to replace the latch or the arms could be messed up. My guess is the latch does not open when it needs to.
__________________
04-26-2007, 10:57 PM
#135
i just remembered, when i had my trunk problems while trying to figure out / fix the problem i accidentally switched the safety switch inside the trunk, so i would hear the latch release, but the trunk would not open -- oh boy that took a while to figure out
04-27-2007, 07:38 PM
#136
was having problems with my clutch and i cheked my fluid which was empty so i filled it . I still have alot of play in my pedal tho, should there be any play nin the pedal or should the clutch grab right when the pedal is only slightly depressed????
04-29-2007, 12:24 AM
#137
Shifter
Thanks for letting us "newbies" have a chance. My question is what have people done with the automatic shifter in there maxima? The stock one, well, is pretty boring. What have people done?
04-29-2007, 02:31 AM
#138
umm replace it with a manual looking one
04-29-2007, 10:43 AM
#139
Quote:
Different shift knob or lower it. I changed mine but guys give crap cause they think I want to look like a manual. I do not want to look like a 5spd, just that the stock auto shifter is boring. Here's what i did with it:
__________________
04-29-2007, 11:49 AM
#140
Heres a new question, I've decided to do a vq35 swap and have been combing through the threads to get all the general info. I can. One question still stands out that I can not find an answer to. If you are planning this swap, wanting to t/c or s/c it and put forged heads and rods in should you also replace the crank with a forged one? Also with this setup would it be benefical to stick with the vq30 ecu or the vq35 for tuning purposes? Thanks in advance for your help
04-29-2007, 11:54 AM
#141
Looks VERY nice! What did you do with the overdrive button? and the shifter interlock button?
04-29-2007, 12:06 PM
#142
o/d button was wired up to a dash button
__________________
04-29-2007, 01:43 PM
#143
I'm new here so I can't post this in its own thread, but...
I'm looking at a used 1995 Maxima (GXE, I believe) with 95K miles on it for $2999. It has an automatic transmission. What are some things that I should look for when inspecting the car? Are there any common trouble areas or problems that I should look for?
Al
04-29-2007, 01:50 PM
#144
Quote:
I'm looking at a used 1995 Maxima (GXE, I believe) with 95K miles on it for $2999. What are some things that I should look for when inspecting the car? Are there any common trouble areas or problems that I should look for?
rear brake noises are very common for all the 4th gen's, I personally have replaced the rear calipers, rotors, pads, all the e-brake cables to get rid rear brake noise. The e-brake cables on these years have a tendency to lock up and cause caliper problems like sticking and rusting. Also check to see is the check engine light is on, sometimes the knock sensors go bad and set it off. Neither of these problems are that expensive or hard to fix.
04-29-2007, 01:53 PM
#145
Quote:
How much do you think any of those repairs would cost? Thankfully, this lot gives a 30 day/1000 mile warranty. So if anything is bad, they'll fix it, I reckon.
Also, would it be advisable to have the car inspected by a mechanic prior to purchase (assuming it test drives fine without any apparent problems)?
04-29-2007, 04:24 PM
#146
I personally did all the repairs to my car they price as follows: calipers $125.00 ea, rotors $50.00 (premium) $35.00 (standard), pads $60.00 rear set, all three e-brake cables will run around $300.00 total. And it is a very good idea to get a mechanic that you trust to give it an inspection before any vehical purchase. The other thought of the warranty, while they should fix the problem they will probably try to do the cheap fix till your warranty is up. But test drive it first and make sure everything is on the up and up, who knows there might be nothing wrong with it, but run the kelley blue book on it and find out where it stands, a 95 with only 90,000+ miles on it sounds like it should go for more than 3 grand from a dealer. So make sure you give it a good inspection and you really know what you're getting into. Oh and the as far as the knock sensor goes that will cost you about $170.00 for the sensor alone, and you have to take of the IM to get at it.
04-29-2007, 05:26 PM
#147
I've never had problems with rear calipers, yea they can stick but I've never dealt with it. I've never had noises back there nor have I ever heard a lot of people saying that they create problems. Don't think that buying a 4th gen means you need to fix the rear brakes when you buy it that's crazy. You should inspect all that stuff if you can tho.
No you do not need to take of the IM to replace the knock sensor. That's bull. Dealers and mechanics go by that because the book says so. Waste of time. Everybody on here who has done it has had the IM on. You just need to get in there.
Having a mechanic would be nice but I'm not sure if you want to pay the mechanic each time you want a car inspected. Inspect the car yourself, make sure it feels good and the engine feels good. If it's a rough ride then be careful.
__________________
04-29-2007, 06:26 PM
#148
http://consumerguideauto.howstuffwor...n-maxima-2.htm
Those reviews are on all maxima 4th gen's and they all say the same thing about brake noise, just because your's doesn't doesn't mean that its not a common problem. The question was asked if there were common problems with the car and that is one, I never said he had to replace the rear brakes, I said to look for that problem. Also I HAVE replaced my knock sensor and I had to take the IM off, just because you found a way around it doesn't mean it's bull. The repair manuals, haynes and the fsm both tell you to take it off. Check out the site and the reviews before you go all jumping down my neck about rear brakes, he asked for common problems and I gave it to him, no need to be hostile.
04-29-2007, 06:34 PM
#149
Those reviews are on all maxima 4th gen's and they all say the same thing about brake noise, just because your's doesn't doesn't mean that its not a common problem. The question was asked if there were common problems with the car and that is one, I never said he had to replace the rear brakes, I said to look for that problem. Also I HAVE replaced my knock sensor and I had to take the IM off, just because you found a way around it doesn't mean it's bull. The repair manuals, haynes and the fsm both tell you to take it off. Check out the site and the reviews before you go | | |
