Painting interior
Painting interior
Hey guys, I decided to paint my interior black, so i picked up some plastic paint. I cleaned all the pieces and started spraying them with Kylon for plastic.
My problem is I just picked up a paper towel and wiped some dust off a piece i painted a few days ago, and the towel started to turn black. So I rubbed the piece (with very little force) to to see if it was just excess paint, and slowly the more I rubbed, the more the paint started to fade.
Whats the problem here?
I dont want people getting in the car and having their clothes turn black, what do I do?
Maybe wrong type of paint. Did you prep your work prior to painting. I know when I did mine I did a light wet sanding, primed, then used Duplicolor. About 8-9 months now and no problems.
Well this should be common sense. You cleaned the pieces but did no other prep work. Worked with paint before? You didn't sand anything, you didn't prime anything, and you didn't clear coat anything. Most likely you didn't clean well enough and the paint isn't sticking too. Take some actual time and do this correctly. If you don't then it will look like complete **** and will fade quickly.
haha fine then don't prime it. I'm just telling you what the best way to do it is. You posted why did it fade and yet you won't listen to my answer. I did all the steps and it looks fantastic and hasn't chipped or faded in a year. Go about your own way if you'd rather.
What you should do is go get some adhesion promoter. It can be purchased at any autoparts store and can really help you out. Put 2 light coats of the promoter, followed by 2 coats of paint, and 1 coat of clearcoat. Hope this helps, GL!
i did mine without primer. you dont need it if you spend a good amount of time sanding and prepping the surface. i dont know why the towel would turn black...i didnt use plastic paint though. i used wheel paint. and ive had no problems with it. maybe the sun had heated up your car and the paint couldnt take the heat or something? im not really too sure. if you end up doing it over, use some wheel paint.
I didn't use a primer either. I cleaned and sanded everything pretty good, but I used a vinyl paint. Well I used it on my door panels and dash. I used the Krylon plastic paint on the hard plastic pieces. I did use adhesive promotor though. I think that is what helped the most.
Well the pieces arent in the car yet, so I dont think its the sun. I did use duplicolor vinyl and fabric paint on some pieces, and they are doing the same thing.
I tried wiping them with a swiffer thingy, and some paint did come off, but again its like a dust. After doing that the paint wasnt coming off on my hands. Maybe dust settled on the pieces?
The problem is he didn't use any primer and or adhesive after sanding which is a must.
That's the bottom line, there wasn't enough adhesion to the surface. Doesn't take a rocket scientist to figure this one out.
Now since you skipped a vital step. You must 1. remove all the paint you applied to your panels and start over the proper way. 2. You could try and add some layers of clear coat or some protective adder to the already painted surface (I wouldn't suggest).
What I do suggest is starting over again if you really want this to look perfect and professional to WOW the friends.
It isn't really the lack of prep he did, it is the cheap paint he used. If it was a problem with sticking then it would be the lack of prep i.e. sanding, cleaning, and even priming, but if it is just the fact that it is rubbing off, you used cheap paint and you didn't clear it. If it comes from Wal-mart, DON'T USE IT. I work in the paint industry and there is a difference. Go to a Sherwin-Williams Automotive or Keystone or do a search for a local SEM dealer near you.
Steps to painting any kind of plastic... well really anything
1. Clean surface with a good chemical cleaner, not just windex or soapy water. But not something extremely hot or cold to where it will crack or melt your plastic pieces.
2. Lightly sand it.
3. Another good cleaning with a chemical cleaner.
4. 2-3 light coats of a good bonding primer. (I use XIM, which I sale, it is the best bonding primer I have ever found, smells horrid but awesome stuff.
5. Lightly mist a cost of base. Followed by 4-5 light coats of the base color.
6. (Depending on sheen level your wanting) At least 2-3 light coats of clear, more depending how much sheen you want it to have.
2. Lightly sand it.
2. Lightly sand it.
2. Lightly sand it.
HE didn't use any primer or anything. He just cleaned, sanded and went straight to painting.
What I am saying though is his problem wasn't the primer so much. It was the paint choice he made. If it was chipping or flaking or just not adhering at all, then it would have been not priming it. But he isn't having that problem, his problem is that it is rubbing off and fading.
Ok no it's not the paint. If it's plastic paint that's what it designed for. I'm not sure why everyone wants to ignore primer. Do you have a problem with it or something? Put a f*cking coat of primer on, do the paint and put a coat of clear. Then see if you have the same problem. If you do then I'll admit I was wrong. Or you guys can keep arguing about nothing. Your call.
3 people so far have said they didnt use primer and it turned out great...soooo my guess is PRIMER IS NOT THE PROBLEM. im willing to bet that everyone that didnt use primer also didnt use plastic paint or vinyl paint either...i know i used wheel paint because it adheres better...but thats just me
I am agreeing with willard. Primer is recommended, but not necessary. If you clean it with a good chemical cleaner and brillo pad or sand paper you will be fine. His problem was the paint. Like I stated before, cheap paint and no clear coat. Even a quality paint won't need a clear coat. I have sprayed every piece in my car at one time or another and have NEVER had a problem. You use cheap products, you get cheap results. I can **** in a can throw some acetone, MEK and xylene in there and put "Perfect for any type of ABS, fiberglass, metal or wood surface." Again, you buy cheap, you get cheap results, perfect instance, duplicolor. Buy a quality product i.e. SEM, PPG, Sherwin-Williams, or Dupont. It isn't even that much more, I get a can of almost any color for under $8.00. And all my pieces have turned out flawless, just like I had them professionally painted. My suggestion to you would be, since it is already faded, sand it down and get your surfaced roughed up, put a primer over it, and then put your base coats and a couple clears.
The best part is all this confusion isnt even over a maxima hahaha, its over a mustang.
Anyway, like i said before....i wiped it with a swiffer thingy, and some paint did come off, but like before. It was a light dusting, and after doing that no paint rubbed off on my hands. Maybe i may still need a clear coat, but i guess ill find out in time.
Originally Posted by Cdg2125
haha ok I'm done with this thread than. You all say primer is not the answer yet tell him to redo it and use primer...
Originally Posted by willard00
so what your saying is mine is going to rub/chip off too? cause i only washed and sanded. no promoter, no primer. funny...its been almost a year and there are still no flaws.....
Whats everyone getting all worked up for. lol
Originally Posted by InsneDrmr
When I said cleaned, i meant sanded and cleaned and you dont need to prime plastic. Clear coat is the only thing I didnt do.
Reason it is rubbing off is you didn't clear it.
But like a few people are saying the Profesional way to do it is clean,sand,clean,adheasion promoter,primer, wet sand, clean, basecoat, clearcoat.
that is how i did my interior.
litch
123
01-04-2024 07:01 PM
04-16-2020 05:15 AM
REDinLV
10-18-2015 05:31 AM
