HELP Needed. ... Car won't start
Old 02-04-2007, 12:21 PM
shilov's Avatar
I stopped at a liquor store this afternoon and when I got back to the car it wouldn't start. Wouldn't crank. Something electrical. When I turn the key, the relays next to the fuse panel click as if I didn't press the clutch (I'm not sure it is the same relay are clicking) and nothing happens. Any suggestions? I checked the battery and it was fine.
Any help is greatly appreciated.
shilov is offline
Old 02-04-2007, 12:31 PM
MOHFpro90's Avatar
Are you still at the liqour store?
Anyway, Did you try a jumpstart? WHat about the starter or alty? Check your fuses also. Other than that, someone else will have to help you.
MOHFpro90 is offline
Old 02-04-2007, 12:40 PM
shilov's Avatar
I just got home to get the tools. I'm sure the battery is fine. It's only 1 month old and the lights are bright when I turn them on. I'll check the voltage though. I go through the fuses and next thing is the starter. Do you thinkl it's a good idea to try disengaging it from the flywheel and try turning the ingition on to see if it turns?
shilov is offline
Old 02-04-2007, 12:56 PM
2da mizzax's Avatar
sounds like the starter. why not push-start it?
2da mizzax is offline
Old 02-05-2007, 07:02 AM
shilov's Avatar
Good call. I tried pulling the starter out and turning the ignition on. It rotated with some sparks comming out of it. I also notticed that the connector nut was a little loose on it. I guess it could've been some loose wires that got fixxed when I was pulling it out or the connector. Anyhow I didn't want to mess with it an 30 deg cold and whent to Autozone and got a new starter. Works fine now.
Thanks everyone for the help.
shilov is offline
Old 02-05-2007, 01:02 PM
UncleBen's Avatar
I have 99 maxima the starter starting to make this extended noise every time it start up since about 90k miles then at about 110k it just went out and won't start.. This is a known problem with the maxima.. i just replace the starter and it all good again and it is now 130k mi still going strong.
UncleBen is offline
Old 02-21-2007, 09:20 AM
ramonroad's Avatar
If you turn the key, but nothing happens, its probably not the starter. However, if the starter is making a grinding noise try this first. Just remove the starter, clean it and regrease it. The noise is eliminated and the starter should work fine.
If the key is turned, but nada, it could be the ignition switch harness which is above the steering column. This costs anywhere from $23.99 - $48.99, depending on where you buy it. It's easy to remove the steering column cover, the panel beneath the steering wheeel to get to and replace the harness. If it's not the harness, it might be the key swtich itself. This costs about $130 to replace.
ramonroad is offline
Old 02-21-2007, 10:03 AM
shilov's Avatar
I believe when the starter gets stuck and doesn't rotate, it might draw too much current from the battery and the safety cuircuit kicks in (relay clicks to the left of the steering wheel) so you don't get your engine on fire.
shilov is offline
Lakersallday24
06-16-2019 01:35 AM
kjlouis
11-24-2018 06:09 AM
MAXSE5SPD
08-23-2015 12:06 PM
BobMax
08-15-2015 12:35 PM
Balkins
08-12-2015 06:39 AM
Quick Reply: HELP Needed. ... Car won't start
