VB Mod
VB Mod
hey maxima nation i'm planning on the VB Mod for my next upgrade does any1 has the pros and cons on this? or is there any website i can go to to read up on the reviews?
95 GXE
Short ram intake
2.5" Custom exhaust
Y-pipe with down pipe and headers
4" Exhaust tip
Hi flow cat
95 GXE
Short ram intake
2.5" Custom exhaust
4" Exhaust tip
Hi flow cat
Originally Posted by icedout
i have the vb modd done in my max,as far as i can see there are no cons to it just all pro man.I think the site is maxiumtuning.com has some info on it.One of the best mods you can do imo for the auto.
Originally Posted by Fr33way™
What exactly are you looking for?
It will not help "low-end". It increases the firmness in shifts and decreases the amount of time that the tranny shifts.
Tranny cooler is cheap insurance to keep the wear on your tranny to a minimum.
It will NOT be .4 quicker. I am not auto so perhaps someone else can chime in but it will not make up nearly half a second.
If I knew I would have. I am 5MT so I am not too involved with automatics.
I don't want this to get into a street racing thread but:
-If you can, race from a dig only.
-If you plan to do this alot, consider getting a 5MT. If you didn't know, besides the gear ratios a manual transmission makes more power to the ground because there is less frictional loss (less moving parts) from the engine to wheels.
If you have any streetracing questions PM me. The 4th gen forum isn't a place for benchracing (not that you were).
i agree on the 5mt but i'm going to be teaching my mom and girlfriend how to drive soon, then maybe pass along my 4th gen for maybe a 4th gen engine swap or 5th gen maxima, and i do more regular driving than racing, but im just doing this because i was called out
95 GXE
Short ram intake
2.5" Custom exhaust
4" Exhaust tip
Hi flow cat
95 GXE
Short ram intake
2.5" Custom exhaust
4" Exhaust tip
Hi flow cat
The VB will lessen the 1/4 mile. I don't know about how much but I have some base work done now on with my current setup using the PLX R-300 software. You can actually look at the graph and see how long it takes to shift from 1-2 and from 2-3. Its very consistant. I'm sure once I get the VB the shift will take less time. I'm hoping the graph will prove this.
I have this mod and it's not .4 faster. However, it does shift firmer than stock and you could feel it since the tc won't slip as much as stock.
The cons, however, is that since the tranny won't slip as much, you could feel a power dip right after the shift. This won't be felt with turbo/sc cars, but if you are stock and you are being honest, you will feel it.
I have mine installed at Maximum Tuning and after driving around with another Maxima, I am a bit leaning towards having it stock again (but it does not bother me much so I am still keeping it). I have a tranny cooler installed at the same time, so be prepared for a long warm up if you are driving in sub-zero weather. One time the tranny actually shifts back from locking the tc (the "5th" gear") to slipping the overdrive (the "4th" gear) since it was really cold outside (-20 F windchill).
zzznightmarezz
09-21-2015 06:32 PM
