how many oil qts?
Old 01-28-2007, 02:01 PM
jxkim's Avatar
how many oil qts?
just changed my oil yesterday and put in 4 qts of castrol gtx 5w30
today i checked the level and it seemed to be MAX or barely over. i was thinking it would be below and i would have to add some more. my friend told me i should put 4.25 qts. tried searching online but couldnt find anything.
on http://www.motorvate.ca/mvp.php/511
the guy put it 4 liters which is less than 4 qts if im right? help me out.
jxkim is offline
Old 01-28-2007, 02:17 PM
kcryan's Avatar
Barley over your fine. I think it actually takes about 4 quarts.
kcryan is offline
Old 01-28-2007, 02:22 PM
2da mizzax's Avatar
4.25 with filter change. (depending on which filter you install) and 4 litres is more than 4 qts.
2da mizzax is offline
Old 01-28-2007, 02:33 PM
buzpuck11's Avatar
My car took 4 quarts with a filter change. I also used GTX5w-30.
buzpuck11 is offline
Old 01-28-2007, 02:36 PM
Sounbwoy's Avatar
4 liters = 4.226753 quarts
Sounbwoy is offline
Old 01-28-2007, 02:46 PM
jxkim's Avatar
used nissan oem filter
guys at pepboys were like "YOU NEED FIVE. its a v6" good thing i didnt listen to em
jxkim is offline
Old 01-28-2007, 02:57 PM
willard00's Avatar
i used 5 quarts of gtx last oil change.
willard00 is offline
Old 01-28-2007, 03:34 PM
kbmaxima's Avatar
5 qts? drain and refill correct amount
kbmaxima is offline
Old 01-28-2007, 04:42 PM
willard00's Avatar
ive always used 5 qrts. read in more than one place that correct amount for our cars is 4 1/2-5qrts....dont know why everyone on here thinks its only 4?
Old 01-28-2007, 04:45 PM
Wild for Width
Fr33way™'s Avatar
5 quarts will stress the seals.
Fr33way™ is offline
Wild for Width
Fr33way™'s Avatar
And it is 4.25.
Fr33way™ is offline
Old 01-28-2007, 04:52 PM
kcryan's Avatar
FR33 is dead on with the 4.25
kcryan is offline
Old 01-28-2007, 05:11 PM
jxkim's Avatar
5 qts is how much i put in my last car, crown vic v8 4.x liter engine.
but dont know why you would need more?? someone?
interesting, barely related point: dirty oil pan/engine? use some engine cleaning? u can throw in 1 bottle of transmission fluid instead of engine oil. it wont do any dmg and will slowly clean it out. i think you maybe have to do this for 3,000 miles more than once. heres the article: last part "the facts..."
http://autotechrepair.suite101.com/article.cfm/040206
jxkim is offline
Old 01-28-2007, 05:20 PM
kcryan's Avatar
^Bad idea
I suggest Auto-Rx
kcryan is offline
Old 01-28-2007, 05:22 PM
ImmaSquashYou's Avatar
everytime i change my oil i buy 5 quarts. I use mobil 1 fully synthetic with K&N oil filters. I put in 4 quarts. Drive around come back n check the dipstick. Usually put in about 1/4 to 1/2 quart.
ImmaSquashYou is offline
Old 01-28-2007, 05:26 PM
f550maranello2's Avatar
its 4.25 quarts MAX... thats all u should be putting in...
f550maranello2 is offline
Old 01-28-2007, 05:35 PM
B!tch We Got a Problem
Gismo-T's Avatar
Why, have you neglected doing your oil changes?
When I do mine, I use either Nissan or Napa Gold filter w/1 qt.
Lucas Synthetic Additive & 3 1/4-1/2 qts. Castrol GTX 10w30.
Gismo-T is offline
Old 01-28-2007, 05:39 PM
kcryan's Avatar
Best method, after a bunch of changes you get a free one (minus filter) because of the leftovers
kcryan is offline
Old 01-28-2007, 05:41 PM
kcryan's Avatar
When I do mine, I use either Nisson or Napa Gold filter w/1 qt.
Lucas is a no no, it has a tendancy to foam up, and fomay oil doesnt lubricate well. Their syn stuff is better, but still your better off without it, GTX is great oil and doesnt need anything (although i would put some LC20 in it, if interested google lubecontrol) Also, i would run 5-30 regardless of climate, it cant be too thin upon startup.
kcryan is offline
Old 01-28-2007, 06:34 PM
Gismo-T's Avatar
I use Lucas maybe every 3rd oil change. (never had problems)
Have you ever tried LC20?
Gismo-T is offline
Old 01-30-2007, 04:39 PM
rjtiobol's Avatar
Ive been using 4 qts for 204,000 mile.
wow 63 oil changes
rjtiobol is offline
Old 01-31-2007, 07:04 AM
jxkim's Avatar
yea i dont know why but 4 qts topped it off for me. i had that extra .25 rdy but decided to go with the oil dipstick rather than the norm. you think its caused by some sludge buildup or something?
jxkim is offline
Old 01-31-2007, 07:11 AM
Maxima Owner
MaximaSE96's Avatar
MaximaSE96 is offline
Old 01-31-2007, 07:54 AM
maxima_kenny96's Avatar
I always use 5, never had a problem.
maxima_kenny96 is offline
Old 01-31-2007, 09:22 AM
Q8BallMAXIMA's Avatar
I always use the manual specs. for oil. If you fill it higher than the 4.25 qt, you could potentially blow out seals.
Q8BallMAXIMA is offline
Old 01-31-2007, 09:32 AM
Maintenance Monster
dgeesaman's Avatar
The other reason too much oil is a problem is potential foaming. Foaming in the crankcase will lead to major temperature rise and lubrication problems.
Dave
dgeesaman is offline
Old 01-31-2007, 09:58 AM
Maxima Owner
MaximaSE96's Avatar
Diff cars require more...my friends M3 is liek 7 qts or somethig redunkulous
Old 01-31-2007, 11:15 AM
Fuhget About It.....
maximafrenzy's Avatar
When I put in 4.25 it looks like I put too much, also another Maxima friend hipped me to Supertech oil at Walmart, it runs good and is cheap. Any1 care to comment.
maximafrenzy is offline
Old 01-31-2007, 12:05 PM
Cdg2125's Avatar
The point is that you could have a big problem. If you won't listen to everyone telling you that you can blow the seals then o'well. When it happens then maybe you'll put in 4.25. That's for everyone, not a shot at you or anything.
As for the post from maximafrenzy, you posted your answer. "Cheap" is the only word that matters in that post.
Cdg2125 is offline
Old 01-31-2007, 12:26 PM
2da mizzax's Avatar
Supertech is actually a good oil. As are their filters.
Old 01-31-2007, 12:44 PM
You think so, I don't use it cause its cheap, what am I saving $10? I do not notice any difference in performance, my car actually rides pretty strong, shiiit it feels like a beast!!!
Old 01-31-2007, 01:17 PM
kcryan's Avatar
Supertech isnt bad, but be aware, you wont notice a difference if i put crap oil in your car, but your car sure will, so thats not a good way to judge oil...nor is its color after X number of miles FYI.
kcryan is offline
Old 01-31-2007, 01:40 PM
buzpuck11's Avatar
I used to put about 6.5 qts. in my previous car, Subaru SVX, so 4 seems like so little, but it will save me money on oil changes, so I don't mind. Also nice and easy to buy a gallon jug.
Old 01-31-2007, 02:07 PM
Thats the thing my cars performance hasn't changed since I switched from GTX, at least I noticed it feels strong and if the oil was bad it prob. wouldn't. I am not any kind of pro, but I can feel what my baby feels.....
Old 01-31-2007, 02:31 PM
Maintenance Monster
dgeesaman's Avatar
Oil has only a minute effect on horsepower output. The real difference is wear over the long haul.
Dave
Old 01-31-2007, 02:51 PM
Dave
So what your saying is switch to GTX because of better wear for my motor? I've seen many ppl here recommend GTX but I never thought twice, until my buddy sug. supertech, he said its the same but if not better.
Old 01-31-2007, 04:42 PM
Maintenance Monster
dgeesaman's Avatar
I'm not sure why so many people are so wound up about oils. There are many good oils, at all different prices. But each person's idea of 'good' is different. People argue all day long about oils (see bobistheoilguy.com) and either you argue about lab tests (which only apply to real life in a limited way) or they argue about your personal experience, which even with the most experienced people is still scientifically insignificant. About the only thing that is agreed is that pure synthetics are best, but conventionals perform well enough that most people will never see any difference even over the full life of a car. So really it comes down to value and how much you feel like spending.
There are many synthetics out there, and they definitely do better for wear than standard oils. But it's at a price, and the extra cost (especially for oils in the $8-10/qt range) is questionable at best. Among cheaper non-synthetics, I think the difference is very small - Castrol, Valvoline, Quaker State, etc, all make a good oil. They market like crazy to maintain the perception that the differences are big.
As long as you don't use something that is plain wrong for your application, you will have good results. By far it's more important to use the appropriate viscosity and change it regularly than what kind you use.
Dave
Old 01-31-2007, 05:01 PM
MaximamixaM's Avatar
yeah, look at the oilguy website. THey have alot of fanatics that run tests on used oils. Even the cheapies-like supertech-should last 3000 miles and be ok. some of the cheaper ones break down faster and are more worn out after 3000 miles than their peers, but if you change frequently you are ok. Personally, you could change at 2000 miles and be well protected if you wanted to.
The worse thing that you can do for an engine is to start it after a cold start-that's where the majority of the engine wear comes from-but no one's gonna say don't start your engine. And the big key maybe filters-and supertech are better than most-or so they say on the internet.
MaximamixaM is offline
Old 02-01-2007, 04:43 PM
Crooper_Hedder's Avatar
If the outside temp never gets below 20F, is there any benefit of using 5w30 over 10w30? I always use Castrol GTX + Nissan OEM filters.
Crooper_Hedder is offline
Old 02-01-2007, 04:50 PM
jxkim's Avatar
werd. i just did my first oil change since i got my max. started using gtx and oem as well. 10w is thicker so worse for colder temps. i would think maybe using the same 5w every oil change would be better than swithcing back and forth.
jxkim is offline
Quick Reply: how many oil qts?
