Snapped a lug nut stud...what now?
Old 01-12-2007, 04:27 PM
bearded's Avatar
I just broke my lug nut off with part of the stud still in it while trying to take my tire off. Is this a hard/expensive fix? Should I even bother trying to take it to the shop that put the lug nuts on crooked and have them fix it? Thanks.
bearded is offline
Old 01-12-2007, 04:32 PM
dot dot dot ...
NmexMAX's Avatar
Go to autozone, buy a new stud, install it.
Not more than $5, take wheel off, bang them out, put new one in its place, tighten the lug, loosen the lug, tighten again, loosen, then install.
NmexMAX is offline
Old 01-12-2007, 04:51 PM
bearded's Avatar
Thanks for the reply NmexMAX.
So you can just bang the studs out with a hammer? I install the new stud by screwing in and tightening the lug nut?
bearded is offline
Old 01-12-2007, 04:56 PM
dot dot dot ...
NmexMAX's Avatar
I usually use an old shirt/rag and put it over the hammer. Or just use a mallet.
Had a headache after I changed all my studs one day :
NmexMAX is offline
Old 01-12-2007, 05:22 PM
Maxima Owner
MaximaSE96's Avatar
stop ur whining.....I had to do all my fronts for install of longer ones.....its not bad
MaximaSE96 is offline
Old 01-12-2007, 05:28 PM
nismology's Avatar
Agreed.....whiner...
An impact wrench makes the job so much easier.
nismology is offline
Old 01-12-2007, 06:30 PM
I Broke OT
86maxima96's Avatar
can't it be bad to hammer on the joints/axle like that?
86maxima96 is offline
Old 01-12-2007, 07:49 PM
J_Ketzer's Avatar
Find some washers which fit around the new stud, too. The stud will probably be too long to pull through with just the lug nut, so you can stack some washers on it. You'll see what I mean when you put the new one in.
J_Ketzer is offline
Old 01-12-2007, 08:22 PM
Maxima Owner
MaximaSE96's Avatar
yeaaaaaaaaaaaaaa......oh yea the washers is a def.
Old 01-13-2007, 12:46 AM
nguyen925's Avatar
if you dont know what your doing just buy the studs at autozone or something and get a body shop to replace them/it for you. it shouldn't be expensive..
nguyen925 is offline
Old 01-13-2007, 11:38 AM
dot dot dot ...
NmexMAX's Avatar
Yup.. whining again .
I had to do all 20
NmexMAX is offline
coolsun
Wheels/Tires
11-13-2016 05:01 PM
knight_yyz
11-01-2015 01:34 PM
dcam0326
09-26-2015 05:20 AM
camako
09-22-2015 04:27 PM
Quick Reply: Snapped a lug nut stud...what now?
