Hose threatened? (picture)
The hose being bent by the bar is in concern. #1, what is the black piece it is connected to, and #2, is there a way to adjust that piece to be out of the way?
Or is it really not a problem/in danger?
Those big hoses are holding that piece in TIGHT. The bracket metal just slips around the piece.
I'll try bending the hoses around. Took it for a 4k rpm test drive and it didn't get touched, but I'll figure out a precaution. Thanks for the info.
when i looked at mounting my fstb, i noticed the mounts offset the bar either closer to the firewall & the brackets or if i switched the mounts to the other strut towers it would be offset toward the radiator away from the brackets. so of course i mounted it that way, away from anything.
its in the stickies guys jeezz. . . you with the proper jet size set to spray right at TDC, or at the lastest its spraying into the cylinder when the piston is at 1* ATDC.
Guranteed 9's everytime.
doesnt anyone check the stickies anymore
bigfrank
10-01-2015 12:51 PM
HerpDerp1919
09-29-2015 02:02 PM
